Hp G72 Issue help needed.
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Hi I got a HP G72 (DA0AX1MB6F0) here initially it would not switch on. No leds not even the led on Dc jack. I have seen this issue of no led on dc jack before on some CQ60/61 and its always been corrupt bios.
    Anyway the 3.3v and 5v are fine as is the supply to the SIO, I reflashed bios and still same issue. I noticed the SIO was outputting #RSMRST and a few other signals without the powerbutton being pressed but still nothing else happening. I swapped out the KBC from a spare board and now the laptop powers up by itself it wont power up by pressing the powerbutton just starts itself after about 1 minute.The #rsmrst stays at 0v then jumps to 3v. It then displays on screen and immediately shuts down.
    It will not startup again without removing the adapter and reinserting, the cycle then starts again. Im gonna try swapping out the KBC again tomorrow but was looking for input and ideas.
    Many thanks
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Re: Hp G72 Issue help needed.
    Update: I changed out the KBC again and laptop powers up when button pressed and does not power down by itseself anymore. So it looks like the KBC was the issue.
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • Dev Goose
      Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
      by Dev Goose
      Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
      What Happened
      The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
      12-13-2024, 03:13 AM
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
