a300d stupidity
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    a300d stupidity
    I there
    Received a a300d blue board bd3 model board, enter the store , not giving image , just gave a very fast little reflow with the hot air , it gave image no problem , so contacted client and gave him 3 prices for fix , one for chip replacement , another for reballing same chip and for does who have pratically no money due to economical problem , i also due reflow , this client wanted the reflow due to the cost , i've reflowed it , and shunted the pins to turn it on , but dysplayed no image .. i took it was strange , also because fans were not spinning .(it should when pressed ON) so i lift the IGP and resoldered back .. SAME ISSUE , fan dont spin and no image . ok so i relfash bios , same thing . interchanged the 4022 chip with a 4026 but the same .. so after some schmeatic reading , what was controling fan was the KB , so since fan dont spin , i replaced KB controler , after that fans start spinning , but still no image , so i returned to the 4022 chip , but the same fan spin but no image .. so now im a bit stuck here ..when i shorted the pins of CN8 to turn it on it could touched another pin ,, but they are only 4 .. 2 for kb one 5 volts and one ground .. so in any case if i would touched accidentaly another pin , KB would be fixed after replacement and machine should be giving image .. but no .. this machine is driving me crazy , cheked all coils and states and all seem ok .. So in this moment im open for sugestions ..
    board model . DABD3GMB6E0 REV:E THIS IS A BOARD WITH SB AND IGP ONLY , THERE IS NO MXM SOCKET AND NO EXTERNAL PCI X GRAFICK CARD.
    wait for some sugestions .
    sincerely
    jonathan
  • spleenharvester
    • Mar 2010
    • 903
    Re: a300d stupidity
    Is there an NEC Tokin cap behind the CPU?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      Re: a300d stupidity
      after all lots of reading and measurings , its only possible beeing a IGP problem , replaced the IGP with one i found here , WORKING
      thk anyway guys
      • angel-boy
        • 550
        • Romania
        Re: a300d stupidity
        I have the same problem with this board,
        the laptop video card work but with lines, after reballing , power led is off after 2 seconds
        i test with another graphic board, working, after some hour test again,and same like first board, power led on , and off after 2 seconds
        i buy another graphic board, now the power led is on , the 2 led that light "toshiba" is on , but no image ?
        shoul i try bios ?
        some help ?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3610
          • slovakia
          Re: a300d stupidity
          u kill igp with your reball. that cause short and another components like mosfets or capacitors can be bad.
          NEVER start reballed laptop if u not check resistance of it.
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            Re: a300d stupidity
            agree 100%
            • synapsea
              • May 2015
              • 6
              • Shkoder
              Re: a300d stupidity
              Can you tell how much is the right resistance ohm on the ati or nvidia chip .
              how an i find, this value is on schematic ?
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                Re: a300d stupidity
                you can't , regarding that if you read resistance on the component above the chipset , cannot be less than 3 ohm . meaning if its less that 3 ohm , there is a big chance of the internal die to be in short.
                • angel-boy
                  • 550
                  • Romania
                  Re: a300d stupidity
                  realy dont understand what i kill ?
                  i make reballing at EXTERNAL PCI X GRAFICK CARD
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    Re: a300d stupidity
                    well , imagine that the internal die of the chip was way to hour used !! , once you reball , you must apply 3X heat , one for remove chip , another for clean , and the last one to resolder it back .. so it simple die.
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1488
                      • portugal
                      Re: a300d stupidity
                      alltough is a bit common IGPS staying shorted after some heat applyed , specially if to much heat as well.
                      • angel-boy
                        • 550
                        • Romania
                        Re: a300d stupidity
                        i make reballing at EXTERNAL PCI X GRAFICK CARD , that is original of laptop, not working,
                        - i have another board, the laptop starts , i put the laptop away, after some hour i tested again, and no image
                        - i buy another board, the laptop have no image.
                        I did not heat the mainboard, only graphic external card.
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          Re: a300d stupidity
                          so we are telling you , you killed the pci grafic module not the motherboard itself .
                          • angel-boy
                            • 550
                            • Romania
                            Re: a300d stupidity
                            how i kill the graphic module ? i have 3 board, only one i make reballing, other 2 is like factory
                            explain me this - - one graphic card , the laptop starts , i put the laptop away, after some hour i tested again, and no image,power led start and off in 2 second,
                            i did not make any repair at this board, first time was ok,
                              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:20 PM
                            • Jaime Morillo
                              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                              by Jaime Morillo
                              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                              The TV was stuck on the logo and I couldn't access the update menu.
                              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                              The image result was good, but the image is inverted.
                              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                              08-18-2025, 11:38 AM
                              HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                              09-06-2024, 10:56 AM
                              HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
