HP 4720s Laptop does not respond to the power button
  • khaahk
    • Dec 2013
    • 812
    • Estonia
    Re: HP 4720s Laptop does not respond to the power button
    Lower left corner - seen worse working, think it shouldn't be cause for not working.
    U90 should be near 2 coils L56 and L58, also near FETs U82.88,91,92, maybe opposite side of the board but close. From the internet pictures i presume it is on the opposite side of the coin cell region.
    Small stupid question: have you tried removing the coin cell for 5 min?
    • n3v3n
      • Jan 2014
      • 12
      • Croatia
      I did remove battery, but it was less then 5 min.
      Regarding U90 I'll do my best to find it today when kids go to sleep.
      • 4m0k
        tinkerer
        • Nov 2010
        • 4
        Any luck with this one?
        Got the same problem with 4720s - random shutdowns in BIOS or while loading OS.
        My first thought was it's an overheating issue but after some fiddling around it seems more like a "faulty capacitor" kind of problem. Like a PSU with bad caps which, started from cold state, runs for a couple of minutes but then starts to shut down more and more often.
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          i have the same issue with the same model of laptop
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            "started from cold state, runs for a couple of minutes but then starts to shut down more and more often."
            sounds like a bad chipset IC
