a1708 - 820-00840 - No Power 20V-0.03A Not stable.
  • saisoni20
    • Feb 2022
    • 111
    I have got A1708 has 20v-0.03A (turning ON-OFF) No Power. Input Amp is turning on -off.
    I have PPBUS_G3H - 13V.
    Voltage is fluctuating at L7030 with input 0 t0 7.8V.
    Someone can help me with this?
  • mon2
    • 14191
    Remove the fuse on ppbus_g3h and check if the power cycling stops. Is the ppbus_g3h voltage stable without a load?
    Remove all power and check the resistance to ground of each inductor on the board. Checking for a lower than normal resistance on the rail.
    • saisoni20
      • Feb 2022
      • 111
      after removing fuse power cycling stops.
      ppbus_g3h​ is stable 13V
      indusctor L7900 -PPVCCPCH_S5G and L8060 -PP1V_S5G is showing me 0.3 ohm
      • mon2
        • 14191
        The CPU may be shorted but check as follows - remove all power. Meter in lowest resistance mode (if manual meter type).
        Place one meter probe on the downstream / consumer side of the fuse PCB pad (fuse should remain off the board). Place the other meter probe onto any of the inductors that is used for the CPU power supply. You are checking the resistance between the PPBUS_G3H rail and the low voltage inductor to confirm if the high side mosfet is leaky or not. What is the measurement? If the resistance is low, then the high side mosfet has leaked and injected a high voltage onto the low voltage CPU and components.
        Perform this check with other inductors on the board which also use the same high voltage of PPBUS_G3H to create a lower voltage rail = buck regulator type.
        • saisoni20
          • Feb 2022
          • 111
          They all are 150k between PPBUS_G3H rail​.
          • saisoni20
            • Feb 2022
            • 111
            mon2 is it CPU?
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
