820-01987 20V 0.1AMP - 0.9 AMP
  • alfredposadas09
    • Aug 2020
    • 343
    • Philippines
    this unit was no power stuck at 5v .. i check PP3V3_G3H shorted line i replace q7680 and short gone.. i have 20v now and 0.1amp - 0.9amp.. what should i check next? still no chime sound no fan spin
  • mon2
    • Dec 2019
    • 14280
    Check the voltage to ground of PPBUS_G3H @ F7000. Check both sides of the fuse. If this voltage is not 12-13v then remove all power. Meter in resistance mode. Measure the resistance to ground of F7000 fuse. If there is a low resistance, flux and remove F7000 fuse. Power up again to confirm if the ISL9240 side of the fuse pad (removed fuse) is able to create a stable voltage for PPBUS_G3H.
    • alfredposadas09
      • Aug 2020
      • 343
      • Philippines
      hi sir i measured 12.31v both pads.. what should i check next??
      • alfredposadas09
        • Aug 2020
        • 343
        • Philippines
        i have voltage in P3V3G3H_VSW but i dont have voltage on P5VG3S_VSW
        this is the diode reading
        P3V3G3H_VSW=0.3V
        PV5G3S_VSW =0.3V
        • mon2
          • Dec 2019
          • 14280
          The missing rail does not appear to be shorted but confirm it in resistance mode as well. Remove all power. Meter in resistance mode. Measure the resistance to ground of PV5G3S_VSW.
          Confirm that this rail is being enabled by checking the voltage to ground of P5VG3S_EN_DLY.
          Also check
          P5VG3S_EN @ R7613.
          SMBUS_3V3_BATT_SCL
          SMBUS_3V3_BATT_SDA
          • alfredposadas09
            • Aug 2020
            • 343
            • Philippines
            Also check
            P5VG3S_EN @ R7613.
            SMBUS_3V3_BATT_SCL
            SMBUS_3V3_BATT_SDA
            PV5G3S_VSW =3.7k ohms
            SMBUS_3V3_BATT_SDA=0.890 diode/12k ohms
            SMBUS_3V3_BATT_SCL=0.890 diode/12k ohms
            • alfredposadas09
              • Aug 2020
              • 343
              • Philippines
              L8102= 0.043 diode reading/88.2ohms
              I do CPU coil measuring this line i have these values... Based on Flexbv the correct value is 0.124 but I am only getting 0.043. U8110 generated the PP0V95_S0_CPUVCCIO_REG_R and its vin supply is PP5V_G3S_CPUREG_MISC.. maybe I got a bad CPU? What do you think? do I jump on basics?
              • mon2
                • Dec 2019
                • 14280
                Need the voltage to ground for the following (not diode mode measurements):
                P5VG3S_EN @ R7613.
                SMBUS_3V3_BATT_SCL
                SMBUS_3V3_BATT_SDA
                The CPU diode measurement looks low but the resistance to ground is ok. Wait on other comments but post the requested voltage measurements (not diode) of the above.
                • alfredposadas09
                  • Aug 2020
                  • 343
                  • Philippines
                  P5VG3S_EN @ R7613. = 0v
                  SMBUS_3V3_BATT_SCL = 3.3v
                  SMBUS_3V3_BATT_SDA = 3.3v
                  i lift L8102 on pad 1 i measure 0.4v diode , on pad2 cpu side i still measure 0.004.. i still dont have 5vg3s_en @r7613 the diode reading in this line is 0.4v...​
                  • alfredposadas09
                    • Aug 2020
                    • 343
                    • Philippines
                    is it possible to replace cpu in MacBooks?
                    • alfredposadas09
                      • Aug 2020
                      • 343
                      • Philippines
                      P5VG3S_EN @ R7613.
                      SMBUS_3V3_BATT_SCL
                      SMBUS_3V3_BATT_SDA
                      hi pl daniels told me the measurement in FLexBV is wrong .. i read 88ohms in cpu so i guess cpu is good
                      • alfredposadas09
                        • Aug 2020
                        • 343
                        • Philippines
                        P5VG3S_EN @ R7613.
                        SMBUS_3V3_BATT_SCL
                        SMBUS_3V3_BATT_SDA
                        I try to jumper se032 to force the MacBook to dfu mode but it doesn't detect even a glimpse of signs of dfu mode
                        • mon2
                          • Dec 2019
                          • 14280
                          Is your DFU setup known good? The USB cable is of quality? We use 100W rated TBT rated cables, to be safe.
                          What is the voltage to ground of ALL_SYS_PWRGD?
                          • corrize
                            A funny fuse story – Lumix LX100 II
                            by corrize
                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                            10-19-2023, 09:58 AM
                          • jesterace
                            Samsung UE46ES8000 Blown fuse but no other signs of short
                            by jesterace
                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                            09-11-2024, 03:14 PM
                          • jshhh
                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                            by jshhh
                            Hi guys,
                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                            Anybody know how to remove this type of fuse?
                            (The fuse is toward the bottom of the image labeled F2)...
                            06-17-2025, 01:35 AM
                          • Babbar
                            by Babbar
                            04-12-2024, 01:12 AM
                          • drykid
                            Matsui 175S microwave fuse replacement
                            by drykid
                            I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                            Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                            12-21-2020, 01:15 PM
