This iPad pro logic board is not repairable, right?
  • SSBDADC234
    • Dec 2023
    • 6
    • korea
    Click image for larger version  Name:	2024-08-14 02 28 05.jpg Views:	0 Size:	78.6 KB ID:	3328612
    iPad Pro 11" 2nd model.
    Itunes No. 9 error occurred, so I removed NAND. And I checked the components.
    Among the rails that power the NAND, PP1V8_EXT_SW1 is abnormal. The diode value is very low at 0.040. This power rail is the rail that comes from the CPU, not the PMIC, and on a normal logic board, the diode value is 0.300.
    When I inject an electric current into this rail, the CPU and encryption chip generate heat.
    Should I say the CPU is damaged?
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    by ohren
    09-08-2023, 05:24 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • Rab1
    Ipad 8th gen logic board making buzzing noises
    by Rab1
    Just to ask what could possibly be causing the logic board to make low buzzing sounds? Thanks.
    04-05-2025, 11:15 PM
