Dell latitude 5440 does not turn on after a short 5v
  • antibotan
    • Feb 2020
    • 42
    • Ukraine
    La-m401p
    The board after a short circuit of 5v, everything was done and replaced the faulty components, the duty voltage rose, the board turned on from the battery, but the power supply does not see, or rather from 5 yuv does not raise to 20v
    t was replaced by tps65994, but it did not lead to a positive result, I did not find any schemes for this board, maybe someone has already encountered such a malfunction
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    check all coil for short and all power rail is present
    • antibotan
      • Feb 2020
      • 42
      • Ukraine
      I repeat, it turns on from the battery, and so there is no short circuit anywhere else
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Board number: VAW30 LA-9832P Rev1.0 (A00)
        • antibotan
          • Feb 2020
          • 42
          • Ukraine
          no!
          La-m401p
          • antibotan
            • Feb 2020
            • 42
            • Ukraine
            Maybe someone has a scheme for a board or at least a similar one? I would be very grateful
            • trepachka
              • Oct 2022
              • 424
              I have this motherboard available outside the computer. If you need me to take measurements in certain areas of the motherboard, let me know.
              You mentioned tps65994 chip. I would try to see whether all pins make a good connection with the motherboard. Remove the chip, tin the pins again, use good amount of flux, then resolder the chip. After you do that, get the schematics on the tps65994 chip. See if the voltage reaches the chip, check all caps around it.
              • trepachka
                • Oct 2022
                • 424
                Also, make sure the battery is attached. These Latitudes are notorious for misbehaving when batteries are nowhere to be found.
                • antibotan
                  • Feb 2020
                  • 42
                  • Ukraine
                  I changed 65994 several times, tried different ones, the voltage coming to it is 5v, 3.3v, 1.5v, but 19v never rises, the laptop turns on from the battery
                  • antibotan
                    • Feb 2020
                    • 42
                    • Ukraine
                    with or without battery, it doesn't raise 19v, battery starts it up
                    • antibotan
                      • Feb 2020
                      • 42
                      • Ukraine
                      Here are my measurements
                      • antibotan
                        • Feb 2020
                        • 42
                        • Ukraine
                        Measure who is what voltage with the connected type-c at this point
                        • trepachka
                          • Oct 2022
                          • 424
                          Were you able to figure out the issue with the motherboard? I am in a similar predicament. Computer is stuck @ 5V, drawing 0A current. Everything appears to be fine. I replaced both the PD chip and the ISL chip just in case to no avail.
                          • imedbox
                            • Jun 2022
                            • 11
                            • Algérie
                            You fix it? ihave the same probleme the labtop want charge with the power supply! my bat is decharged then i can test it with battry it power on!
                            i got this after flash bios "32mo" i revert to the original then not charge or power on, befor it power on and chargin!
                              DELL Latitude 5440 Notebook 5000 Specification for Upgrade or Repair
                              This specification for the DELL Latitude 5440 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5440 boardview and 5440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5440...
                              09-07-2024, 07:19 AM
