Acer V5-471G Can't Read BIOS
This topic has been answered.
  • acata
    • Jun 2021
    • 53
    • Indonesia
    I have Acer V5-471G Can't Read BIOS.
    BIOS IC is new and the old one also in good condition.
    I already tried several BIOS DUMP, but Is still can't enter BIOS.
    Once the laptop turns on, it just goes directly to os.
    PIN 1 3.3V
    PIN 2 3.0V
    PIN 3 3.4V
    PIN 4-6 0V
    PIN 7 3.4V
    PIN 8 3.4V
    19.5v in 0.6a
    5v ok
    3.3 v ok
    1.2v ok
  • Answer selected by acata at 08-08-2024, 08:46 PM.
    reformatt
    • Feb 2020
    • 1491
    Select Restart in Windows while holding the Shift key (or go to Settings/Updates and Security/Recovery/Advanced Start-up). From the Select UEFI settings in Advanced Troubleshooting.
    • Bonzas
      • 472
      • Indonesia
      PIN 1 3.3V
      PIN 2 3.0V
      PIN 3 3.4V
      PIN 4-6 0V
      PIN 7 3.4V
      PIN 8 3.4V
      19.5v in 0.6a
      5v ok
      3.3 v ok
      1.2v ok
      try this.
      remove hdd or ssd from your laptop, remove cmos battery also. When first booting, you should press F2 quickly. when you can enter bios, you need disable fast boot if your bios have this option
      Hope this work
      • reformatt
        • Feb 2020
        • 1491
        • acata
          • Jun 2021
          • 53
          • Indonesia
          This one works so far.
          But I still can't turn off the fast boot.
          I have already tried another version of Acer v5-471 BIOS but I have had no luck
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            Some models of Acer need you to define an administrator password before allowing changes to these options. Try that.
            • EbrahimSiami
              Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
              by EbrahimSiami
              I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
              **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
              **What I have tried so far:**
              1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
              07-02-2025, 02:31 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • James194zt
              Acer Nitro 50-640E Corrupted BIOS Dump
              by James194zt
              My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
              All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
              04-28-2025, 03:29 PM
            • ub6ib969
              Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
              by ub6ib969
              Model Number: PO3-650
              Part Number: DG.BK4AA.006
              Serial Number : 33400117730
              BIOS IC : XM25QH256C
              I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
              07-02-2025, 03:51 PM
            • ebyte64
              Bios request for Acer P214-52-58CH
              by ebyte64
              Good day.
              I would like to request a bios for the following laptop?
              Model: Acer P214-52-58CH
              Model No: N19Q7
              S/N: NXVLHE0H11204BA27600
              SNID: 11201936276
              Symptoms: Laptop powers on but no picture on screen.
              I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
              09-25-2024, 05:59 AM
