asus fa506c element identification
  • pablos13
    • Jan 2015
    • Polska
    Hello
    I am looking for a photo of the Asus FA506c motherboard
    DANJIMB18A0
    What is the value of the resistor in the photo and is there anything else missing
    Regards​Click image for larger version
  • mon2
    • 14317
    Remove all power. Meter in resistance mode (not diode mode). Place a meter probe on one side of this missing resistor. Place other meter probe on any of the nearby 8 pin flash chip. Note the resistance. Continue to probe each and every pin on this 8 pin flash IC.
    Then repeat using the other side of the missing resistor. One of the pins should report a resistance of 0 ohms. Which pin is on this memory IC?
    Suspecting that the resistor will be ~33 ohms but confirm the pin # of the flash IC. You can also measure the other nearby resistors which are placed for the same intent - to stop signal ringing events on the data lines of this memory chip.
