A1708 peculiar bms problem.
  • 100FIX
    • Jul 2024
    • 5
    • Nigeria
    Hi, I have a mbp a1708 2017 that I am trying to fix.
    (1.) It turns on fine on ac power when bms flex is unplugged.
    (2.) I noticed when battery & charger is unplugged and reconnected, it turns on only after a few minutes but doesn't stay on battery power i.e. it turns off as soon as charger is unplugged and doesn't turn on until (2.) is repeated. During this time, health information and charging information are displayed and normal and battery charges but laptop turns off as soon as charger is disconnected.
    I have reballed u7000, problem persists.
    What could be the problem?
  • mon2
    • Dec 2019
    • 14368
    Check the voltage to ground of each pin on the battery connector or BMS flex when they are connected. Appears that your BMS flex is defective.
    • 100FIX
      • Jul 2024
      • 5
      • Nigeria
      I have tried with a known working flex and battery, same result.
      • mon2
        • Dec 2019
        • 14368
        Measure the voltage of each pin on the battery connector. The TVS ESD diodes that are on the smbus lines are of concern (SDA / SCL).
        • 100FIX
          • Jul 2024
          • 5
          • Nigeria
          Voltage on sda, scl on mobo side reads about 3.5v. For battery side, I tested with working battery from similar laptop already.
          I removed the tvs diode on sda/scl/gnd already (awaiting arrival of replacement part). Issue persists.
          • mon2
            • Dec 2019
            • 14368
            Not at my desk and about to enter the Netflix zone. Remove all power. Meter in resistance mode. Measure the full path resistance of the battery charge current loop. We need to know and compare the measured resistance against the schematics. If the resistance varies then this is an issue. Share the resistance. Since you cannot reach the hidden balls of the isl charger ic, measure at one of nearby caps on the SRP / SRN contacts.
            • mon2
              • Dec 2019
              • 14368
              Measure the resistance across capacitor C7020. This is to determine the resistance seen by CSOP / CSON balls of the charger IC. For a normal unit, this resistance should be ~2 ohms.
              • 100FIX
                • Jul 2024
                • 5
                • Nigeria
                Sorry for the late reply. Had a problem with my meter test probes, all the values were off, so I had to get a replacement.
                I have checked values on c7020, it is exactly 2ohms. Do you suggest i replace u7000?
                (I have also recieved the replacement tvs diodes and installed it.)
                • flat-earther
                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                  by flat-earther
                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                  Windows also shows ''Plugged in'' when charger is not connected.
                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                  If I let battery run out and say it has 3% Windows will...
                  06-24-2025, 09:32 AM
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                • NanoTesting
                  Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                  by NanoTesting
                  I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                  With charger it turns on, fan spins but gives no image.
                  Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                  Reflashed BIOS, same problem.
                  Replaced both main mosfets.
                  Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                  10-30-2024, 10:48 PM
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
