1708 EMC3164 macbook have power issues
This topic has been answered.
  • itzusman
    • Jun 2024
    • 16
    • PK
    Hi Masters.
    My 1708 EMC3164 macbook have power issues. First it was working fine but a bit slow in booting. Net day i turned it on and it didn't powered on. And i tested with usb meter it suddenly @ 20v it takes 2.6 ampares and cpu gets hot. Then i checked the baord and PPBUS_G3H was short to ground. I injected 1v to it it takes 350ma and cpu gets warm. After opening L7410/20/30 there was inly L7420 line was short then i injected 3v to PPBUS_G3H and it takes 2.5 amps and U7420 got hot and i desolder it. Now after that in the start it takes 0.580 amps and goes to 620-30 mili amps. And then drops to 310 to 330 mili amps. No display. Fan starts slowly and gets fast by time.
    L7410/20/30 0V
    PPBUS_G3H 13v
    Cpu gets hot by tiime and fan gets fast
    Usb c meter 20v 580ma to 620ma
    "The macbook came for bios password"
    Any suggestions .
    Please.
  • Answer selected by itzusman at 07-13-2024, 08:03 AM.
    mon2
    • Dec 2019
    • 14698
    U7420 needs to be onboard. This is one of the multiphase power supply controllers. Each such controller contains internal high and low side mosfets. They will switch on/off to dial down the PPBUS_G3H high voltage to a safe voltage for the CPU.
    On this note, never never inject a high voltage onto any board. The highest voltage for injection should be the lowest voltage used by the board. So keep it 1 volt or lower. The reason being that the injection voltage can reach the CPU. In your case, 3v may have reached the CPU or GPU and killed it.
    Remove all power, no battery. Measure the resistance to ground of inductor L7420. What is the resistance value?
    Suggest to measure the resistance to ground of each inductor on the board. You are checking for a potential short on the board which can cause the local power supply rail to turn off.
    Check the power sequence charts below. Also, the CPU should be powered up with a heatsink and fan for normal diagnostics.
    Click image for larger version  Name:	A1708_power_sequence1.png Views:	0 Size:	279.8 KB ID:	3308375
    Click image for larger version  Name:	A1708_power_sequence2.png Views:	0 Size:	249.8 KB ID:	3308376
    Click image for larger version  Name:	A1708_power_sequence3.png Views:	0 Size:	166.6 KB ID:	3308377
    Click image for larger version  Name:	A1708_power_sequence4.png Views:	0 Size:	156.7 KB ID:	3308378
    • mon2
      • Dec 2019
      • 14698
      • itzusman
        • Jun 2024
        • 16
        • PK
        Thanks for reply.
        Ok i will check and report back. Power sequence values
        • itzusman
          • Jun 2024
          • 16
          • PK
          I have tested it again . and i opend all 3 inductors
          L7410/20/30 and cheked voltages. On the U7410 / 20 / 30 Side it is giving about 10 volts it looks high voltages for CPU_VCC_GT and then i give 1 volt to the cpu side and connect charger and it gives display but didn't comlete boot at the final stage it restarts. And on the power supply it consume 1v 800 ma.
          How much voltages should be on CPU_VCC_GT
          And what cand cause 10 volts on U710/20/30 output?
          • mon2
            • Dec 2019
            • 14698
            CPU and GPU will always be a very low voltage. Both are heavy current consuming devices and for this reason, the semiconductor, by design will operate at a very low voltage of 1 volt or even lower.
            Having such a high voltage on the noted rails means that at least one of the high side mosfet is leaky and allowing for the high voltage to enter this region. To produce a safe and lower voltage (buck regulator design), there will be a high side and a low side (to ground) mosfet. Each will switch on / off to create a lower and safe voltage for the powered device(s).
            In your testing, do you see the Apple logo during power up? Try booting in Safe mode if you do.
            • piernov
              • Jan 2016
              • 4439
              • France
              Crappy multimeters won't understand the fast switching of the MOSFETs, nothing wrong there.
              No way iGPU survived getting PPBUS_G3H *then* 3V from lab PSU anyway.
              • itzusman
                • Jun 2024
                • 16
                • PK
                I opened all 3 inductor s l7410/20/30 thease are open voltage. 2 of sic635 ics are short i have pulled them out. And now it is third one that is making 10volts. Now is it possible that ISL95828 is also faulty? Now i have conected a buck converter 1.07v 5amps. It shows display even it installes os. But when it comes to final booting display turns off. Click image for larger version  Name:	20240717_072225.jpg Views:	0 Size:	1.91 MB ID:	3312530
                • Flasman90
                  Macbook Pro DFU Restore Issues
                  by Flasman90
                  I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                  - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                  - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                  08-30-2025, 10:27 AM
                • cheebster
                  Macbook Air 2020 A2179 Internet Recovery and Battery Issues
                  by cheebster
                  Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
                  The 10 of them show the exact same behavior;
                  They auto power on, to internet recovery spinning globe, fans to 100%.
                  Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
                  Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
                  All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
                  10-09-2024, 06:23 AM
                • envym
                  MacBook Pro 2018 with Activation Lock
                  by envym
                  Hi everyone!
                  I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                  I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                  06-27-2025, 08:54 AM
                • pb1911nt
                  MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
                  by pb1911nt
                  Hello forum,
                  I'm still relatively new to the world of electrical repairs.
                  I have a Macbook here that I can't figure out
                  When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
                  I removed the logic board and took a few measurements.
                  But I can't really figure it out.
                  At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
                  09-07-2025, 11:35 AM
                • tobeend
                  Bypass mdm macbook m2 ventura
                  by tobeend
                  1. RESET MACOS WITH IPSW
                  a. Power off MacBook, press and hold the power button to enter Recovery
                  b. Open Disk Utility, remove Macintosh HD
                  c. Reboot, connect to the network to Activate Mac.
                  d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                  d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                  e. Release the other keys, but keep holding the Power key for another 10 seconds
                  f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                  05-26-2023, 07:18 AM
