Asus Vivobook F712E, no power, no charging, works only with battery, help!
  • Ariu
    • Dec 2020
    • 138
    Hello, i have a asus notebook, that doesnt power on at all or charge.
    it works only with battery plugged in without charger.(no schematic available)
    BQ24780S ic already replaced with a good one but same issue, 0V on the source and gate of 1. mosfet.
    No short on 1. and 2. mosfet.
    i am able to measure only 3.2V on the CSR.
    BQ24780S voltages:
    1. ACN ->3.2V
    2.ACP ->3.2V
    3.CMSRC ->0V
    4.ACDRV->0V
    5.ACOK->0V
    6.ACDET->0.66V
    24.REGN->6V
    when i inject 19.5V on the CSR the notebook doesnt power on.
    Does anyone already faced and solved this kind of issue?
    Please help.
  • mon2
    • Dec 2019
    • 14662
    Review the ACDET->0.66V​ measurement. This is a raw voltage derived from a dual resistor based voltage divider. You should see a high side resistor that will be the adapter voltage (~19v) on one side and another resistor on the low side. The common middle connection between the 2 resistors offer a safe and lower voltage for the ACDET. This voltage must be 2v4 or higher to be considered to be worthy of powering the logic board.
    Once this voltage is at least 2v4, the rest of the voltages should kick in.
    • Ariu
      • Dec 2020
      • 138
      Thanks, but i do not understand why ACDET ->0.66V , but when BQ24780S ic is desoldered , ACDET is over 2.4V and that should be right according to voltage devider.
      The charger ic itself is fully functional, beceause is from a spare board and the charging circuit was fine.
      • mon2
        • Dec 2019
        • 14662
        Measure the resistance of the high and low side of the parts on the ACDET line. Based on the last post, they should be ok but confirm. ACDET is a high impedance input to the charger IC so the voltage level should not be impacted when the charger IC is onboard.
        ACOK is not OK but that is most likely due to the ACDET voltage being too low.
        Confirm if you have a voltage on the SMBUS SDA / SCL lines. These require an always on +3V rail which may be defective.
        Based on the 3v2 voltage on ACN/ACP - the battery is supplying this voltage? What is the voltage of the battery at the battery connector?
        • reformatt
          • Feb 2020
          • 1497
          Some Acer/Asus designs have a switch inside the DC Jack which often fails. IIRC, it disables ACDET till that switch is closed. Just a thought.
          • Ariu
            • Dec 2020
            • 138
            All the measurements that i posted in the 1. post are with the charger connected without battery.
            no scl or sda voltage on smsbus line.
            R1 86k and R2 17k.( i tried also replacing R1 866k and R2 133k from the spare board and i get only 0.25V on ACDET line)
            On the battery Connector i have 0.256V , thats fine without the battery connected.
            when i inject 2.5V on ACDET pin then 19.5V is passing through the 1. and 2. mosfet.
            i also noticed that a capacitor is connected in parallel mode to R2 (low side of ACDET) maybe this is causing this?
            • mon2
              • Dec 2019
              • 14662
              Yes, remove that cap. Unable to find schematics for this Asus so you are our eyes and ears on this case. Test again.
              • Ariu
                • Dec 2020
                • 138
                Problem solved. I removed a resistor that was also on that ACDET line but not R1 or R2 and now Notebook is working and charging fine.
                i will take later a picture of the removed resistor that caused this strange issue being 0.66V on ACDET line.
                Perhaps someone will have same fault in the future.
                thanks mon2
                • reformatt
                  • Feb 2020
                  • 1497
                  The designs I’ve encountered have a FET that is biased on normally and pulls the ACDET line down. The gate of that FET is turned off once the switch inside the DC jack is closed and pulls it to ground. Without a schematic hard to know for sure, but DC jack is common failure on Asus and Acer laptops in this respect.
                  • Ariu
                    • Dec 2020
                    • 138
                    That resistor was causing the failure pulling low the ACDET line.
                    i am not sure what value muss have that resistor because no schematic available but the important thing is, Notebook is fully functional without any issues.
                      ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                      09-07-2024, 02:50 AM
                      ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                      09-07-2024, 04:30 AM
                      ASUS VivoBook VivoBook 14 Notebook 14 Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook VivoBook 14 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VivoBook 14 boardview and VivoBook 14 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-07-2024, 04:10 AM
                    • Gregoriy Kim
                      Asus Vivobook M3502Q, no power through USB-C, works on battery.
                      by Gregoriy Kim
                      Hello everyone!
                      Need help with Asus Vivobook M3502Q, Ryzen 5.
                      First time working with failed power supply via USB-C ports. no schematics available.
                      Symptoms:
                      suddenly turned off and does not turn on,
                      Upon first observation, turned out both CSD87501 mosfets had unsoldered due to overheating.
                      Manually charged battery and laptop works on battery
                      Soldered 2 new CSD87501 on board, but it didn't solve the issue.
                      there is 3.3V and 1.6V from TPS65994. and it talks to charger, so charger sends 20V, but no load. There is 20V...
                      04-13-2025, 03:25 AM
                      ASUS VivoBook S531FL-BQ127T Notebook S15 Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook S531FL-BQ127T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S531FL-BQ127T boardview and S531FL-BQ127T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 10:56 AM
