A1989 black screen
  • laptopcenter
    • Mar 2019
    • 90
    • haifa
    A1989 black screen
    Hi
    I have the same problem, black screen, but because there is a burn in the flat screen itself, is it possible to implant a direct connection wire?
  • laptopcenter
    • Mar 2019
    • 90
    • haifa
    The problem with backlight only I see mac logo
    • mon2
      • Dec 2019
      • 14487
      Use ipa alcohol and clean up each of these connectors. Some contacts are not clean on J0200. Clean up each and test again.
      • laptopcenter
        • Mar 2019
        • 90
        • haifa
        I am cleaning it but there are some burn on the line of backlight, so I need to repair it and need to know where the point is on the flat
        • mon2
          • Dec 2019
          • 14487
          You can certainly wire directly onto the SMD backlight connector(s) but you must be very good at soldering and with a steady hand. Double check your work to be sure there are no shorts to nearby connector pins. If there is a short, the high backlight voltage of 25-45 volts will enter the display low voltage pins and cause other damage.
          • laptopcenter
            • Mar 2019
            • 90
            • haifa
            Is it possible to clarify the location of the point where the connection will be made between the flat screen because I do not have data sheet
            • mon2
              • Dec 2019
              • 14487
              Hard to tell from the pics on which side of the cable is at fault. You are asking about the wiring of the cable that enters the display assembly? I think that you should be able to purchase replacement cables for the display assembly. You can check on Aliexpress.
              • laptopcenter
                • Mar 2019
                • 90
                • haifa
                I found the cause of the problem of the light not appearing on the screen of the device and there was a burn in the coil responsible for connecting 5 volts to the screen and I connected a light copper wire instead of the burned coil and the problem was solved Thank you who contributed with me to the topic
                • mon2
                  • Dec 2019
                  • 14487
                  Well done (by those that still have great eyesight I would certainly use my 4k microscope to attempt this one.
                  • HTR-Informatique
                    by HTR-Informatique
                    02-09-2025, 06:51 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • VcemPzd
                    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                    by VcemPzd
                    Hello everyone !
                    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                    04-28-2025, 10:14 AM
                  • DaniK
                    Acer Aspire E5-574-52RH - black screen
                    by DaniK
                    I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                    Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                    Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                    Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                    The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                    Symptoms are:
                    - random black screen after displaying Acer logo...
                    02-21-2024, 06:27 AM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
