Please advise what to buy for NAND programming for MacBook?
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    I'm thinking about buying a programmer for NAND for MacBook! Tell me what else is relevant to buy today for this? my gaze looks at JCID p11f, p13, p15. Is it worth prepaying?
  • kenzo2
    Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
    by kenzo2
    I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
    I need dump file MACBOOK PRO A2159
    TSB4232(256)
    TSB4229(256)
    Thanks​
    01-11-2025, 04:18 AM
  • tech_guru
    Macbook Pro 2019 A2141 NAND Shorted
    by tech_guru
    Hello. If you could please help me understand what I am doing wrong...
    This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
    I also replaced the tps power ic for the ssd.
    Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
    Today, 08:04 AM
  • kuba2102
    Macbook Air M2 A2681 NAND upgrade error 35
    by kuba2102
    Hello people. I have undertaken an upgrade from 256GB to 512GB. I have another A2681 board that I sourced NANDs, resistors and capacitors from. Yet when I try to restore the firmware in FDU mode I get the error 0x23 (35) (error formatting the NAND). Could it be the faulty NAND or I have missed something? Thank you...
    07-03-2025, 12:20 PM
  • Karmet
    MacBook Pro 16" 2019 NAND Swap
    by Karmet
    I couldn't find a post related to this, so if it exists please point me in that direction.
    I have a 2019 MacBook Pro 16" 1TB with a dead embedded NAND. I've seen some information about how it is possible to swap NANDS from certain boards, but it has to be a matching set.
    I have a MacBook Pro 2017 logic board 820-00923-A 1TB on hand that is new in the box. It should be possible to match up the NAND 0, 1, 2, 3 chips and transplant them onto this 2019 board... in theory. Has anyone approached this, or has success in doing this?
    07-24-2023, 10:48 AM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
