A2251 Accidentally Ripped Ribbon for Fingerprint Reader/Power button
  • abajor
    • 178
    Just wondering if I'm totally Fragged. I was trying to release the adhesive holding the t151 flex connector for J4900 and it ripped like paper. As far as I understand it the finger print reader is matched to the board? Is there any way to work around this?
    This machine has a shorted U9080 (ELC180) which needs to be replaced.
    Thanks-
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • triplefour
    OOPS! HISENSE 50R6E accidentally ripped off a panel edge tab.
    by triplefour
    Hey guys...Ruined my day today at a clients house. Had repaired his back light and was in the process of putting it back together when I slipped up and tore off one of the edge tabs. One on the left side about 3/4 the way down. TV worked and showed picture but about 3/4 the way down the screen there is a horizontal bar where the picture is very noticeably brighter. I remember hearing something about being able to rip these tabs off to fix certain panel issues. What are my options here? Thanks!
    10-02-2022, 12:27 AM
  • Rubenlily
    Quick question about the ribbon
    by Rubenlily
    Hey,
    So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
    When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
    08-17-2023, 11:09 AM
  • Scincidae
    UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
    by Scincidae
    I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
    I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
    04-24-2022, 06:00 PM
  • abajor
    A2251 820-0194 CD3217B12 (U3100_W) donors/replacements
    by abajor
    I have an A2251 820-01949 which had a failed TPS62180.
    I was fortunate enough to find the video on "Exploding USB-C" https://youtu.be/CAGnMR1aVuE?si=O1oYvAyNMeAr4dv4 what was shared here on the topic.
    I was wondering if there are any cross compatible models that have been discovered?
    We have an apple ID locked A2179 Mac AIR it's CD3217B2 has different lithography and looks slightly gray but I'm assuming it's the same chip in principal, but I am also aware that for some inexplicable reason mac flashes these chips firmware depending on their location on the board....
    06-27-2024, 01:10 AM
