Socrom 820-01598
  • Dark_
    • Apr 2023
    • 12
    • Países Bajos
    Socrom 820-01598
    I wanted to ask a question, but I have not been able to find information on why this, I am somewhat new looking for faults in macbook and I have come across this part of the schematic card in the image appears Board ID and a series of resistors in PULL-UP to the rail PP1V8_AWAKE, R4710,R4711 and R4712 go MISO, MOSI and CLK of this eeprom U4770 to T2, but on the board are not installed and seeing the schematic part that says BOARD ID.
    I don't understand why they are missing being pull ups for this EEPROM. Does anyone know why ?
    Thank you very much!
Name:	U4770-Res Missing-1.jpg
  • mon2
    • 14476
    Just a logical stab at your raised question
    1) spi is a push-pull style of interface so pull ups are not required since the signal lines are never floating.
    2) most likely the same lines serve as a board ID cluster of pins on power up and afterwards become spi pins. By default there are probably internal weak pull downs and if needed external resistors will change their logic states.
    • Dark_
      • Apr 2023
      • 12
      • Países Bajos
      ohh very thanks for the clarification
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • dmccul2698
        Pioneer DEX-P99rs "No EEProm " diagnostic code.
        by dmccul2698
        Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
        1). Understand the schematic and check the connections between the EEProm and DSP
        2). Check the functionality of the EEProm
        I don't know if this is the unit's problem but it's a place to start.
        I have little to no electronic experience...
        04-08-2024, 05:32 PM
      • edgarmg15
        Damaged EEPROM on TV Vizio E320-A0
        by edgarmg15
        Hi everyone
        I´m trying to repair a TV Vizio E320-A0 that I found in the street
        The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
        The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
        So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
        11-19-2022, 03:46 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • AlexGsmMaster
        Eizo CS2740 eeprom dump, search.
        by AlexGsmMaster
        Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
        07-26-2025, 03:24 PM
