hp x360 gidget 8L 203038-1 has shorted +3vL
  • kjchatman
    • Dec 2012
    • 213
    • united states
    this board had liquid damage and wouldn't power up. It now powers up after a ultrasonic bath but i've discovered the +3vl rail is shorted directly to ground. now it doesn't power up with the battery but it stays on if you unplug the charger and the battery shows 100% and the percentage never drops
  • mon2
    • Dec 2019
    • 14659
    Check the SMBUS lines on the battery connector. Measure the voltage to ground on each battery connector.
    • kjchatman
      • Dec 2012
      • 213
      • united states
      the smbus is working because the battery detects but the capacity stays at 100%. the problem is the +3vL power rail which is shorted directly to ground
      • wolba123
        • Jan 2017
        • 4
        • NRW
        I have the same device and exactly the same problem. Do you have any new findings here? I have not yet been able to find an original circuit diagram or a board view.​
        • mon2
          • Dec 2019
          • 14659
          Look for this IC on the board. Share pics if it is found.
          https://ascnb1.ru/forma1/viewtopic.php?f=232&t=148836
          • barry101
            Apple 820-3662 VCore shorted to ground.
            by barry101
            Hi, Would appreciate some help.
            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
            Get charger light but no fan spin or chime. No liquid damage.
            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
            06-24-2025, 07:34 AM
          • mkdj
            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
            by mkdj
            Dear all,
            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
            Both N-Channel Mosfets: nothing odd
            P-Channel MOSFET number 1:
            source - drain : 117 kOhm
            source - gate: 96 Ohm
            gate - drain: 117 kOhm
            P-Channel MOSFET...
            08-20-2025, 06:08 AM
          • mkdj
            Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
            by mkdj
            Dear all,
            Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
            I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
            I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
            08-11-2025, 04:55 AM
            HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
            This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
            09-07-2024, 05:50 AM
