MBP 2019 16" (A2141) LCD went out.
  • Ajm121
    • May 2024
    Hey Friends,
    I have an MBP 2019 16" (A2141), i9/64Gb/1Tb, and recently the LCD went out. Not flexgate or Dustgate. Backlight is on and works, the board still works and posts to an external monitor. Not a software issue, absolutely nothing shows up onscreen except for backlight glow. opened the bottom cover and resistor L8504, a 120 ohm resistor (I believe) is fried, and fell off the mobo with a gentle touch. after it fell off, same problem with zero change observed which is why I think it is the issue. That resistor, acc to the 820-01700 motherboard schematic, goes straight to pin 46 on the Apple J8500 "EDP" display connector, which goes to the daughterboard on the screen.
    I am seeking help as to how I can fix this, this level of technicality is new to me. Thank you in advance. I am an experienced solderer, but heating up microelectronics is also new to my skill set. That being said, I am willing to do any repair to save the machine.
    73.
  • reformatt
    • Feb 2020
    • 1534
    L8504 is what Apple call a filter. It's not a resistor but an inductor. Its power for the Ambient Light Sensor in the camera assembly. So the MAC may have put your screen brightness to minimum level (see if you can alter it via Fn buttons or in Display settings on external monitor.
    You'd need to ascertain why the filter has detached. Is there a short on this line or was it from some kind of liquid damage. First thing for me would be to check inside the connector for J8500 on the motherboard and on the LCD daughter board. This often gets liquid damaged and destroys U9850.
    • Ajm121
      • May 2024
      Thank you so much my fellow badcaps legend! Does this mean I have to rob a filter part from another device? By the way, I can adjust the backlight brightness with the touch bar and see a visible result. I also was looking at the schematic and wondered why the camera sensor would have such an affect on the screen. thanks again for the reply
      also the liquid damage idea is a good one and I will look right away!
      73
      • anhbanxoi
        • Sep 2021
        • 180
        • VN
        Try to measure EDP_INT_AUX_P and EDP_INT_AUX_N signals in Diode mode. I think you will need to change U9850. I got the same problem in few A2141s.
        • abajor
          A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
          by abajor
          Like title says A2141 came in with Water Damage, customer desperately wants the data.
          The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
          I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
          That said after cleaning up the...
          12-21-2024, 07:16 PM
        • tech_guru
          Macbook Pro 2019 A2141 NAND Shorted
          by tech_guru
          Hello. If you could please help me understand what I am doing wrong...
          This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
          I also replaced the tps power ic for the ssd.
          Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
          08-28-2025, 08:04 AM
        • cheebster
          MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
          by cheebster
          Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
          Nand voltages are missing.
          I've found no shorts at all so far, no signs of heat via thermal camera either.
          PPBUS_G3H 12.31
          PP3V3_G3H_RTC 3.387v
          PP3V3_G3H 12.31v
          PP2v5_NAND_SSD0 0v 58 ohms
          PP2v5_NAND_SSD1 0v 57.8 ohms
          PP1v8_SLPS2R 1.8v
          PP1v1_SLPS2R 1.1v
          P3V3_G3H_SOCPMU 3.37v
          PP0V9_SLPDDR 0.9v...
          10-11-2023, 11:31 AM
        • TimScrawn
          MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
          by TimScrawn
          Hi there,
          This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
          I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
          06-23-2024, 09:41 AM
        • martyjelen
          Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
          by martyjelen
          Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
          PP3v3_G3H_RTC_X is present - 3,3V
          PP3v3_G3H_SOCPMU is present - 3,3V
          ​What else should I check?
          Thank you for your help.
          05-05-2025, 01:34 AM
