Lenovo Z50-70 ACLUA/ACLUB NM-A273
  • vpower
    • Sep 2022
    • 111
    • italy
    Hi, I have this laptop, it is completely dead, no charging light when connected to a working charger.
    Can anyone help me with some hints for troubleshooting this laptop?
    Thanks in advance
  • mon2
    • Dec 2019
    • 14216
    See attached. Measure and post the voltage to ground of the DCin mosfets @ PQ301 / PQ302. Source / gate / drain pins.
    (review the above sticky by piernov on charging circuits)
    • vpower
      • Sep 2022
      • 111
      • italy
      thank you.
      PQ301
      pin 5-6-7-8=19v
      pin 1-2-3=19v
      pin4=19v
      PQ302
      pin 1-2-3=19v
      pin4=19v
      pin5-6-7-8=PR301=voltage is fluctuating fron 2v to 19v, the board makes a clicking sound each time the voltage value changes
      • mon2
        • Dec 2019
        • 14216
        Replace PQ301 and test again.
        • vpower
          • Sep 2022
          • 111
          • italy
          PQ301? isn't PQ302 failing with voltage?
          ok I'll replace PQ301 and report
          • vpower
            • Sep 2022
            • 111
            • italy
            hi, PQ301 replaced, still not working, same values and still same clicking sound (unable to understand which component is making that sound)
            • mon2
              • Dec 2019
              • 14216
              Remove all power. Meter in resistance mode. Measure the resistance to ground of PQ302 (drain pins 5-6-7-8). This is the main power rail. What is the resistance measurement?
              The clicking sound will be from a local switching power supply that is pulsing on / off and the switching frequency is being heard by yourself. The power supply is pulsing because the mosfet driver (charger IC) is sensing a higher than normal current draw so powering down this main voltage rail. The cycle repeats once it is OFF - aka chirp mode of power supplies.
              • vpower
                • Sep 2022
                • 111
                • italy
                multimeter says open circuit on drain(no value). same on gate and source
                • mon2
                  • Dec 2019
                  • 14216
                  What is the voltage to ground of the gate pin # 4 of PQ302? Is this a stable 19v to ground?
                  Remove all power -> meter in resistance mode. Measure the resistance across this mosfet's pins:
                  source (1-2-3) & drain (5-6-7-8)
                  source (1-2-3) & gate (4)
                  gate (4) & drain (5-6-7-8)
                  With the gate pin @ 19v on this N-channel mosfet, this mosfet should be OFF. N-channel requires a boosted voltage and it should be higher than the voltage being passed between source / drain pins.
                  Checking to see if this mosfet is shorted or not through the resistance checks. A good mosfet should have high resistance readings for each of the above permutation checks.
                  • vpower
                    • Sep 2022
                    • 111
                    • italy
                    gate pin #4 of PQ302 is 19v but not stable. sometimes goes down to 16v
                    source (1-2-3) & drain (5-6-7-8) open circuit
                    source (1-2-3) & gate (4) open circuit
                    gate (4) & drain (5-6-7-8) open circuit
                    • mon2
                      • Dec 2019
                      • 14216
                      You should have a resistance measurement.
                      Is your meter auto scaling or manual? If manual, switch to a higher resistance scale on the meter.
                      No power during these tests.
                      • vpower
                        • Sep 2022
                        • 111
                        • italy
                        sorry. scale to 20 megaohm
                        PQ302 measurements to ground
                        pin 1-2-3 15 megaohm and raising over multimeter range
                        pin 4 same as pin 1-2-3
                        pin 5-6-7-8 3.4 megaohm
                        • mon2
                          • Dec 2019
                          • 14216
                          Ok but not checking resistance to ground. Review post # 9 again.
                          • vpower
                            • Sep 2022
                            • 111
                            • italy
                            source (1-2-3) & drain (5-6-7-8) 5 megaohm raising over multimeter range
                            source (1-2-3) & gate (4) 0,40 megaohm
                            gate (4) & drain (5-6-7-8​ 5.5 megaohm
                            • mon2
                              • Dec 2019
                              • 14216
                              The mosfet is being switched ON / OFF using the gate pin so you are observing the fluctuations to the best ability of the meter. An oscilloscope is needed to properly view the switching action. This power cycling event may be due to the charger IC believing there is too high of a current draw but you are not measuring a short on the main power rail.
                              Remove all power. Meter in lowest resistance scale (required). Measure the resistance between pins 1 & 2 on the charger IC @ PU301. These are the ACP / ACN pins where the charger IC monitors the voltage that enters this main power rail (ACP) and measures the voltage that leaves the current sense resistor @ PR301 @ ACN pin. The small voltage drop is used to gauge how much current is being consumed by the main power rail. If it is too high, the mosfets will be shut off to prevent damage.
                              Post the measurement but be sure to measure the resistance of this path directly on the charger IC pins. Again - with no power to the board.
                              • vpower
                                • Sep 2022
                                • 111
                                • italy
                                lowest scale is 200ohm
                                measured resistance between pin 1 and 2 of PU301 is 1,8 ohm .
                                • mon2
                                  • Dec 2019
                                  • 14216
                                  While using the same resistance scale - short your meter probes. What is the measurement?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Remove the CLR and measure voltage on PQ301/302 gates again.
                                    • vpower
                                      • Sep 2022
                                      • 111
                                      • italy
                                      1,4 ohm
                                      • mon2
                                        • Dec 2019
                                        • 14216
                                        Post # 18. Remove the current sense resistor (CLR) that is after the dcin mosfets.
                                        • atsio
                                          Boardview for lenovo z50-70 nm-a273 (aclua/aclub)
                                          by atsio
                                          In need for the above boardview.
                                          Thanks in advance
                                          06-23-2022, 04:51 AM
                                        • Disaxxx
                                          Lenovo Z50-70 ACLUA/ACLUB NM-A273 - Power circuit shorted
                                          by Disaxxx
                                          Hello
                                          Laptop - Lenovo Z50-70
                                          Motherboard: ACLUA/ACLUB NM-A273 Rev:1.0
                                          Vendor: HannStar
                                          I was doing some stuff on it utill I saw low battery notification. I have plugged AC adapter and immediately screen went blank. I thought that I was too late with plugging. However it stopped working after this. No LED.
                                          I have checked the board for short circuits.
                                          I noticed a malfunctioning mosfet - PQ302, so I have desoldered it. I checked its resistance, and it's really broken - R<1Ω
                                          However, pins 5, 6, 7 and 8 are still shorted...
                                          10-25-2020, 12:41 PM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
