please help friend's thinkpad T480 NM-b501 dead, VSYS_OUT 9.2v, thank you
sir there is good news I replaced the broken PF9 now I have 10.2v on VSYS_OUT but the board won't turn on
SYS_OUT 10.2v
PL201 VCC5M 5v
PL202 VCC3M 3.3v
PL701 VCC1R0_SUS 1.05v
PL702 VCC1R8_SUS 1.8v
The board can't turn on yet, where should I investigate so that this board can turn on, sir, thank youComment
Hi. I have very similar problem with 9.2V on VSYS.
PF7,8,9 and D12-D14 are OK.
I2C_CLK_CHARGE i have 0V
VREGIN20 i have 8,6V
On good board i have:
PQ103:
1-3 10,2V
4 10,2V
5 20mV (almost 0V)
PQ108
1-3 10,2V
4 2,27V
5 10,2V
PR151 0V
Bad board:
PR151 9,26V
PQ103
1-3 9,26V
4 3,3V
5 9,26V
PQ108
1-3 9,26V
4 8V and slowly falling down
5 1,6V and falling down
Faulty PU101?Comment
Carefully measure the voltage on each side of R413 and R422. You should see the same voltage on each side of these resistors and should be VREGIN20 = 9v6. Study the good board for a comparison.
It is also possible that U101B is defective and causing this voltage to be lower than normal.
To confirm, remove all power -> meter in resistance mode. Measure the resistance to ground of the VREGIN20 rail. Then continue to check the same till it reaches U101B and measure directly at the pins of U101B. We are checking if there is a trace break or a partial defective series resistor in the path from VREGIN20 to the U101B IC.
Need to do some shopping..will check back later. PS: The above are following the original posted details but do review the same..
Review the resistance to ground on this rail. Compare it to the working board.
Confirm that the I2C pull-up resistors have the mandatory pull-up voltage.Last edited by mon2; 05-19-2024, 10:38 AM.Comment
Thanks for fast reply
working board":
PQ108 1-3 pins Power supply only 10,2V
Battery only 11,98V (differ after reconnecting in range of 0,5V)
Borh 12,93V
Vregin20 on PD13 pin1
Power supply only 9,7V
Battery only 12,44V
Both 12,4V
I2C_CLK_CHARGE 3,3V
I2C_DATA_CHARGE 3,3V
Damaged board:
Power adapter only
PQ108 1-3 pins 9,23V
I think U101A ans U101B is same chip, just they divide it on schematic due to lack of space. As U101 is BGA, i only could measure this
Vregin20 on PD13 pin1 8,71V
R413 pin2 8,724V pin1 8,720V
R422 pin2 8,724V pin1 8,720V
R8777 pin1 8,691 pin2 8,720V
It don't charge any of batteries
On external battery on PQ108 1-3 pins jumps for a while 11,2V and then voltage slowly drops down, as comething cut off this line.
internalt battery dont show this voltage
1) Have notes in my database that this board requires a charged battery to power on the logic board.
2) Would you have a chip programmer to reflash the bios devices onboard?
3)
4) Remove all power. Meter in resistance mode.
Measure the resistance (not DIODE mode) across the mosfet pins as follows:
source (1-2-3) & drain (5-6-7-8)
source (1-2-3) & gate (4)
gate (4) & drain (5-6-7-8)
Post each measurement in ohms for PQ103. Then repeat for PQ108.Last edited by mon2; 05-20-2024, 10:58 AM.Comment
Unfortunatelly with batteries, tamper switch pushed, power adapter it even don't give led light on board. There is 0,00-0,01A consumption only.
PQ103
1-5 2,49MR
1-4 600KR waiting 2 minutes and it is still rising over 1,2MR. Strange
4-5 11,5MR and slowly rising
PQ108
1-5 2,5MR and slowly rising
rising
1-4 510KR
4-5 3MR
I flashed with outimage with clean ME from working board, but no change in operation.
Working board switch on with only power adapter.Comment
Suggest to replace both of these parts. They are tiny (WLCSP8 package) so buy a few spares. Make a note of location of pin # 1 of this device.
TPS22971YZPT Texas Instruments | Integrated Circuits (ICs) | DigiKeyLast edited by mon2; 05-21-2024, 04:03 PM.Comment
It will take long time to delivery to me, as only aliexpress have reasonable price. Even donor motherboard could be cheaper.
Mayby i will desolder them could connect by wire IN and OUT for test purpose?
Edit- i will check if it give powergood signalLast edited by rbvndonh; 05-22-2024, 08:17 AM.Comment
PU1 and PU2 replaced, but nothing changed.
on power switch i get 3,3V, and it GND when pushed.
On other board from Lenovo A485 i have 9,2V, but all other voltages are on the board. Maybe charger is faulty, as it is thinking it is on battery, cause voltage is on PR151, but on AC adapter it shouldn't?Last edited by rbvndonh; 06-03-2024, 11:51 AM.Comment
TPS22971YZPT Texas Instruments | Integrated Circuits (ICs) | DigiKeyComment
1) In my schematic database, found the attached case study:
NM-B501 BIOS / Battery ONLY case study - Badcaps
2) How are you attempting to power the laptop? Are you using a USB Type C adapter? Is the power adapter suited to power this laptop and has enough power rating for charging of the battery?
3) Confirm the voltage to ground of the fuses at:
PF2 ; check both sides
PF1
PL2
PL1
USBC_CC1_CONN
USBC_CC2_CONN
3) Would you have USB Type C meter? Use it to gauge the voltage and the current draw from the power adapter. If the current draw is low from this external power adapter then the issue is in the power delivery circuit that is between the charger IC and the USB Type C connector.Comment
1) Dalam database skematik saya, ditemukan studi kasus terlampir:
Studi kasus NM-B501 BIOS / Baterai SAJA - Badcaps
2) Bagaimana Anda mencoba memberi daya pada laptop? Apakah Anda menggunakan adaptor USB Tipe C? Apakah adaptor daya cocok untuk memberi daya pada laptop ini dan memiliki daya yang cukup untuk mengisi daya baterai?
3) Pastikan voltase ke ground sekring di:
PF2 ; periksa kedua sisi
PF1
PL2
PL1
USBC_CC1_CONN
USBC_CC2_CONN
3) Apakah Anda memiliki meteran USB Tipe C? Gunakan untuk mengukur voltase dan arus yang diambil dari adaptor daya. Jika arus yang diambil rendah dari adaptor daya eksternal ini, maka masalahnya ada pada sirkuit pengiriman daya yang berada di antara IC pengisi daya dan konektor USB Tipe C.
PF1 KIRI KANAN 0V
PL2 KIRI KANAN 5V
PL1 KIRI KANAN 5V
USBC_CC1_CONN 1.6V
USBC_CC2_CONN 0VComment
by fredyjbiPlease help friends, thinkpad t480 nm-b501 is dead, help me fix it, thank you
usb meter 20v 0.00 amp, after I took the VSYS measurement the drop was only `9.2v which should have been 10.2v I measured from a normal matherboard machine, the VSYS path resistance to ground diode mode is 1900 thank you
LINK to Schematic -> https://www.badcaps.net/forum/troubl...b501-schematic -
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 03:21 PM
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 02:34 PM
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 02:28 PM
This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-06-2024, 12:30 PM
- Loading...
