please help friend's thinkpad T480 NM-b501 dead, VSYS_OUT 9.2v, thank you
  • fredyjbi
    • Feb 2021
    • 157
    • malaysia
    Please help sir, this board does not turn on because VSYS_OUT is 9.2v, I compared it with a normal board VSYS_OUT is 10.2v, I have replaced the PQ101 and PQ102 mosfet and BQ 25700 which is known to be good, but the results are still the same, thank you
    VSYS_OUT 9.2v
    Meter in resistance mode auto range 6M ohm ok
    NORMAL BOARD VSYS_OUT 10.2V
    LINK to schematic -> https://www.badcaps.net/forum/troubl...b501-schematic
    PQ101
    PIN 2 20V
    PIN 7 0.004V
    PIN 6 6V
    PIN 5678 0V
    PQ102
    PIN 567 0V
    PIN 9 0.004V
    PIN 234 9.2V (VSYS_OUT)
    PU101 BQ25700ARSNR
    1 VBUS 20V
    2 ACN 20,21V
    3 ACP 20,21V
    7 VDDa 6v
    5 chrg_ok 0v
  • mon2
    • 16621
    Share the voltage to ground of:
    I2C_CLK_CHARGE
    I2C_DATA_CHARGE
    I2C_CLK_BT1
    I2C_DATA_BT1
    • fredyjbi
      • Feb 2021
      • 157
      • malaysia
      I injected 10.2v on VSYS_OUT everything looks fine, please sir mon2 help me complete this board thank you
      • mon2
        • 16621
        Be very careful about high voltage injection because if there is a leaking high side mosfet, the high voltage will enter the low voltage devices and can cause damage.
        From this last test, the unit powers up ok with 10v2 injection?
        This voltage is configured using the I2C / SMBUS lines so do review their voltage to ground.
        • fredyjbi
          • Feb 2021
          • 157
          • malaysia
          I2C_CLK_CHARGE
          I2C_DATA_CHARGE
          I2C_CLK_BT1
          I2C_DATA_BT1
          Thank you sir for your help. I have 2 boards with the same case
          I2C_CLK_CHARGE 001.4v
          I2C_DATA_CHARGE 001.4v
          I2C_CLK_BT1 R10255 pin 1 0v
          I2C_DATA_BT1 R10256 pin 1 0v
          • mon2
            • 16621
            Remove all power -> meter in DIODE mode -> red meter probe (yes RED) to ground. Black meter probe on point to test.
            Test:
            ​PD7
            PD8
            Post each diode mode measurement.
            • fredyjbi
              • Feb 2021
              • 157
              • malaysia
              Test:
              PD7
              PD8
              dioda mode
              PD7 870
              PD8 870
              • fredyjbi
                • Feb 2021
                • 157
                • malaysia
                Test:
                ​PD7
                PD8
                Sorry, I'll correct you in advance, sir, I don't have VCC3M 0v, thank you
                • mon2
                  • 16621
                  That was my next question
                  With no power, what is the resistance to ground of VCC3M ? Do you have a voltage @ M_ON which is the enable for this power rail ? If this power rail is shorted or is drawing too much current, then M_ON will be OFF.
                  • fredyjbi
                    • Feb 2021
                    • 157
                    • malaysia
                    ha.. saya tidak memiliki tegangan M_ON 0V pak, VCC3M PL202 dioda mode 822 baik baik saja
                    • fredyjbi
                      • Feb 2021
                      • 157
                      • malaysia
                      Thank you very much for your help sir. I have been working with this mobo for 4 days and it still won't turn on hi...
                      VCC3M 0V
                      M_ON_1 0v
                      Remove all power -> meter in RESISTOR mode
                      VCC3M 10K ohm
                      M_ON_1 3m ohm​
                      • mon2
                        • 16621
                        To confirm your post # 2 - with an external power supply injection of 10v2, the board works fine?
                        How is the operation of this board using a charged battery?
                        • fredyjbi
                          • Feb 2021
                          • 157
                          • malaysia
                          Sorry sir, I'm late in giving an answer, the battery is damaged so I can't try, but I installed an adapter and injected 10.2v into VSYS_OUT, the result is the same, it still won't turn on, where else should I check, is there a problem with the charging IC circuit, thank you
                          • mon2
                            • 16621
                            With no power to the board. Meter in resistance mode. Measure the resistance to ground of each inductor on the board. Usually they are grey in color. Checking for a shorted power rail on the logic board. Post any suspects that you find.
                            • fredyjbi
                              • Feb 2021
                              • 157
                              • malaysia
                              OK, wait a minute, I'll take measurements
                              • fredyjbi
                                • Feb 2021
                                • 157
                                • malaysia
                                PL201 VCC5MP 989 ohm
                                PL202 VCC3M 900k ohm keeps dropping
                                PL701 VCC1R0_SUS 18 ohm
                                PL301 VCC1R2AP 350 ohm
                                PL702 VCC1R8_SUS 1,2M ohm keeps dropping
                                PL101 17K ohm
                                PL403 VCCGFXCORE_I 10 ohm
                                PL401 VCCCPUCORE 7 ohm
                                PL402 VCCCPUCORE 7 ohm
                                PL404 VCCSA 21 ohm
                                L6 VCC0R9_TBT_SVR 1,6 k ohm
                                L51 VCC3_SUS 700k ohm keeps dropping​
                                • mon2
                                  • 16621
                                  These look like good values to me. Suggest for you to (carefully) review the voltages to ground of these same inductors on the known good board -> make a table of these measurements. Then compare the same measurements on this non-working board.
                                  • fredyjbi
                                    • Feb 2021
                                    • 157
                                    • malaysia
                                    Oh, that means sir, it's not a problem with the charging block, because the charging IC produces the VSYS_OUT vin, and sir, I compared it with a normal board which is different only on the PL701 VCC1R0_SUS 18 ohm, on the normal PL701 board 28 ohm, thank you very much sir for your help
                                    • mon2
                                      • 16621
                                      IMO, the 10 ohms difference is very small. To completely rule out the charging IC -> carefully (!!) measure the voltage to ground of each pin on both boards and post the full table of values.
                                      It is possible that the working board is sending out a 'power good' signal to inform the rest of the board to power up and the non-working board is missing such a signal. Be sure of your soldering of the replaced parts. As far as I know, the actual output voltage is configured using the I2C / SMBUS SCL & SDA lines. The ultimate would be to monitor this bus traffic to understand what communication is ongoing from the SMBUS master and this SMBUS slave chip (charger IC). If there is a fault condition, the SMBUS analyzer logs will reveal them.
                                      Consider to measure the voltage to ground of each pin on the charger IC with a known good power adapter on this board. Then repeat with the working board.
                                      • fredyjbi
                                        • Feb 2021
                                        • 157
                                        • malaysia
                                        Sir, I just measured the normal board on the U101B VREGIN20, it measured 9.6v, and on the problematic board it was only 1v, maybe this is the problem, please help me investigate this, sir, thank you
                                        • fredyjbi
                                          Please help friends, thinkpad t480 nm-b501 is dead
                                          by fredyjbi
                                          Please help friends, thinkpad t480 nm-b501 is dead, help me fix it, thank you
                                          usb meter 20v 0.00 amp, after I took the VSYS measurement the drop was only `9.2v which should have been 10.2v I measured from a normal matherboard machine, the VSYS path resistance to ground diode mode is 1900 thank you
                                          LINK to Schematic -> https://www.badcaps.net/forum/troubl...b501-schematic
                                          04-16-2024, 08:34 AM
                                        • Boardview and Schematic Bot
                                          Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 03:21 PM
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 02:28 PM
                                          09-06-2024, 12:30 PM
