hi i have dell 1564 With no power. when its come to me i saw a caps is burn. so i removed it replace it with new one. but i cannot power up it. when i connect battary the charging led flashing as 4 orange than white. i cannot know what problem with charging led. pls help.
dell 1564 no power with charging led flashing.
by rob_henHello!
This is my first post for help, and I am quite newer to board repair, so bear with me.
I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)... -
Assuming...7 Photos -
by ScoffLooking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection... -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... - Loading...
