Packard Bell Easynote Hera C
  • Ozito
    longtime lurker
    • Oct 2012
    • 6
    • Sweden
    Hi
    I have this PB Easynote that i need help with.
    Info;
    MB: DAOPE1MB6D0 or HannStar J MV-4 94V-0 0830
    I do find schematics that matches the components on the laptop if i use the first name. But they are not free and i do not completely understand them... yet.
    Problem;
    It won't power on with either battery or ac the only led i get is when the battery is in and the ac is connected, only then do i get a solid orange led.
    But the battery doesn't charge and as mentioned the laptop won't power on.
    I need help with how to diagnose this, where do i start?
    I read another thread where the user had similar symptoms and the culprit seemed to be the power management controller, but that was Toshiba and the PWM controller was a max17435etg where as mine is a max8770gtl832.
    It makes me doubt if it could be the same failing component in my case?
    I appreciate any enlightenment and please tell me what else i can provide you with to make this diagnose easier.
    Thank you for reading
  • tomodachi
    • Apr 2012
    • 604
    • Turkey
    Re: Packard Bell Easynote Hera C
    I guess this one fits your mobo,
    • Ozito
      longtime lurker
      • Oct 2012
      • 6
      • Sweden
      Thank you! I really appreciate it!
      It seems to be my mobo, a lot of components on the schematic are the same.
      On the last page i could read;
      P31
      PQ33, PQ39, PQ35, PQ36, PQ37, PQ38 change parts to solve shortage issue
      Page 31 has the title CPU CORE and is showing just the MAX8770.
      I believe the logic course of action is to test the "PQ" components?
      Also on page 28 i can find the Power on sequence flow chart, after the power button comes "EC/87541". I don't know if that's a circuitry or a single component, is it something that you guys with more experience are familiar with?
      I was thinking i could check it out (test it) but i don't know what I'm looking for.
      Thanks again
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        it is embedded controller, and is a single component. it is the bigger component on the board after cpu/gpu and/or south/north bridge or a hub.
        • Ozito
          longtime lurker
          • Oct 2012
          • 6
          • Sweden
          Thanks.
          Is it possible to find some kind of schematic/diagram showing pin voltages and such?
          Tried to Google but end up with the same pdf with the general description, features and dimensions.
          Or shall I just proceed buying a new one and see the results?
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            check page 27 of schematic posted by tomodachi.
            • Ozito
              longtime lurker
              • Oct 2012
              • 6
              • Sweden
              Thanks spidey.
              I didn't think that EC/87541 and IT8512 was the same IC.
              Observing the flow chart, I believe NBSWON should be what I will be testing first?
              • ctlab
                • Dec 2014
                • 5
                • bangladesh
                thanks for your support
