Macbook Pro A1707 820-00281 Stuck @5V
  • JasonC89
    • Apr 2023
    • 17
    • Ireland
    So I have an Macbook Pro that came in for no power (I dont do a lot og Macbook repairs). After some testing I found it was only getting 5V with very little current draw, if any.
    I searched around for shorts, and didnt find any. No real signs of liquid damage etc.
    Following a couple of questions from other members here I was able to further test voltages etc. Im now at a point where PP3V3_G3H is showing, but only at 2.23V.
    I have 5v on the Enable pin.
    Also the dual diode D6902 is showing :
    5.19V @ Pin 1
    0v @ Pin 2
    4.15V @ Pin 3
    L6900 is measuring @ 2.23V.
    I thought mayber a problem with the diode D6902, or the regulator, but I removed R6923 to isolate it,and now I get the expected 3.4V out from L6900, and also pin 3 on D6902 is showing 5V also.
    Im not sure where to go from here? ISL problem or problem with one of the CD3215?
  • mon2
    • Dec 2019
    • 14147
    Remove all power. Meter in resistance mode (not diode).
    Measure the resistance to ground of PP3V3_G3H.
    Post your measurement. With an output low voltage, there may be a heavier than normal load on this power rail.
    • JasonC89
      • Apr 2023
      • 17
      • Ireland
      I get about 60k and it rises slowly as I keep the probes on it.
      • mon2
        • Dec 2019
        • 14147
        This resistance is fine - no short here.
        5.19V @ Pin 1
        0v @ Pin 2
        4.15V @ Pin 3
        That is a large voltage drop on pin # 3. Remove all power. Meter in resistance mode, not diode mode. Measure the resistance to ground of pin # 3 of D6902.​
        • JasonC89
          • Apr 2023
          • 17
          • Ireland
          Yes I thought that too, removed D6902 and it still had the same power drop? I then removed R6923 and I got 5V on pin 3 of D6902 (D6902 still removed), I then resoldered D6902 back and the voltage stayed at 5V on the pin 3 output.
          testing the resitance of pin 3 D6902, I again around 300k, which again rise slowly as I keep the probe on it.
          • mon2
            • Dec 2019
            • 14147
            U6903 sounds to be defective. Confirm the FB resistors @ R6910-R6913. U6903 may need to be replaced. Keep R6923 off the board till this rail is stable and matches the schematic voltage. BTW, yours is the 2nd case in the 2nd day with an identical fault @ U6903.
            • JasonC89
              • Apr 2023
              • 17
              • Ireland
              me
              Okay, so you think U6903 is defective even though after I remove R6923 off the board, pin 3 on D6902 seems to be normal and also pin 2 of L6900 shows the correct 3.4V, instead of the 2.2V I was getting with R6923 on the board?
              I thought removing this resistor is isolating the circuit from the rest of the board, and since it seems to be working properly now, the issue must be part of the circuit after R6923 pulling the voltage down?
              I may be completely wrong as I think this may be the first macbook board Ive worked on, so Im learning as I go.
              I will try remove the FB resisitors and test (they're so tiny Im afraid I will lose one lol).
              Oh wow 2nd in a couple of days, I must have missed that post, can you link me?
              Thanks for your help so far.
              • mon2
                • Dec 2019
                • 14147
                Missed that - my bad. Then this regulator is OK but if 2v2 then something is wrong. If you add R6923, the voltage tanks to 2v2? That is, under normal load, this rail should remain stable @ 3v42. Your FB resistors are fine - do not mess with those.
                • mon2
                  • Dec 2019
                  • 14147
                  820-00281 - Badcaps
                  • JasonC89
                    • Apr 2023
                    • 17
                    • Ireland
                    No worriee, just making sure in my thinking. Yes, if I add R6923 back, voltage drops back to 2.2V? Something must be pulling it down?
                    Ive checked resistance again with R6923 removed and get over 500k on pin 2 so no sign of anything short that side.
                    • JasonC89
                      • Apr 2023
                      • 17
                      • Ireland
                      Ive done a bit more testing on U6903 just to check voltages coming out.
                      With R6923 in place :
                      1. P3V3G3H_VBST = 4.88V
                      2. PPVIN_G3H_P3V3G3H = 4.14V
                      3. P3V3G3H_LX = 2.23V
                      8. P3V3G3H_BIAS = 4.13V
                      9. P3V3G3H_FB = 0.66V
                      10. PM_EN_P3V3_G3H_R = 4.91V
                      With R6923 removed :
                      1. P3V3G3H_VBST =7.63V
                      2. PPVIN_G3H_P3V3G3H = 5.01V
                      3. P3V3G3H_LX = 3.4V
                      8. P3V3G3H_BIAS = 4.98V
                      9. P3V3G3H_FB = 1.02V
                      10. PM_EN_P3V3_G3H_R = 4.99V
                      Not sure how significant these are but just thought I would test both with and without R6923 so it can be compared. ​
                      • mon2
                        • Dec 2019
                        • 14147
                        I would consider to replace this regulator and also D6902. If practical, start with D6902 and test again. It appears that this regulator wimps out upon applying a typical output load.
                        • JasonC89
                          • Apr 2023
                          • 17
                          • Ireland
                          Yeah I may just replace the diode.
                          ​​​​​​I do actually recall it getting hot (using thermal camera) when I first started testing. Found a low resistance on pin 3, that went away when I removed one of the 2 caps on the line.
                          Jow I just need to find a replacment as I have no macbook boards, but plenty of windows laptop donors.
                          • mon2
                            • Dec 2019
                            • 14147
                            The diode is a jellybean dual common cathode type. For testing, remove this diode and bridge pins # 1 to # 3 on the PCB. Then test again to see if the voltage is stable with the load.
                            Consult the datasheet of this diode to note the pinout for this bridging.
                            • JasonC89
                              • Apr 2023
                              • 17
                              • Ireland
                              Okay I'll try this when I'm back working on it in the morning.
                              Thank you 🙏
                              • JasonC89
                                • Apr 2023
                                • 17
                                • Ireland
                                Unfortunately still the same, which I thought it may be as I was thinking about it last night. I removed diode previously and still got the drop on pin #3 until I removed R6923.
                                I removed the diode again and ran a wire from pin #1 to pin #3, plugged in charger and I'm still only getting 5v. Pin #3 on D6902 is still getting pulled to 4v, resulting in only 2.2v on R6923.
                                Could it still be the regulator?
                                Could 3.4v be injected on R6923 to see if we get 20v on the charger, or is that risky?
                                • JasonC89
                                  • Apr 2023
                                  • 17
                                  • Ireland
                                  Anything else you suggest mon2 before I send this out?
                                  • mon2
                                    • Dec 2019
                                    • 14147
                                    What is the exact voltage of PPBUS_G3H ?
                                    With no power, what is the resistance to ground (not diode mode) of PPBUS_G3H @ F7000 / F7001 (check both sides).
                                    • mon2
                                      • Dec 2019
                                      • 14147
                                      Given that there is no short on this low current rail, you could consider using your DC power supply and limit the current of your external power source to 500mA and inject as you are considering @ R6923 (without R6923 installed). This will confirm that U6903 is defective since it wimps out upon attaching the downstream (consumer side) load.
                                      • JasonC89
                                        • Apr 2023
                                        • 17
                                        • Ireland
                                        It's 2.2V when R6923 is on the board.
                                        I'll double check the resistance when I'm back.
                                        (I did notice that when testing one of the left side type c port, the voltage dropped from 2.2v down to 1.7V. I get 2.2V on R6923 on from the other 3 ports.
                                        • vanromic
                                          Macbook a1707 - 3 ports cycling and 1 stuck on 5v
                                          by vanromic
                                          Hello! I'm trying to resuscitate a Macbook that the local tech gave up on. I have the board view and schematic and have the main board out of the case.
                                          Of the 4 usb-c ports, 3 cycle at 5V - they all go up to about 1.5A, then seem to switch off, back to 5V 0A, up to 1.5A, and off again. The cycle lasts a few seconds - maybe 3s.
                                          The 4th port doesn't cycle and draws ~0.5A at 5V consistently. It seems it's the port linked to U3100 - it's on that side of the board and is the port closest to the battery and the CD3215C00 chips.
                                          I've read that the CD3215s are...
                                          05-01-2024, 06:46 AM
                                        • leonemax81
                                          Macbook a1707 820-00281 Battery no Power
                                          by leonemax81
                                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                          08-23-2024, 09:24 AM
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
                                        • Steven Pieter
                                          Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                                          by Steven Pieter
                                          hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                                          11-24-2024, 10:02 AM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
