Lenovo Thinkpad E15 - FE4A0/FE5A0 NM-C421 REV 1.0 USB C no charging
  • KostiaM
    • Feb 2023
    • 9
    • Ukraine
    Hi camsmons
    Can you tell me if you found a solution? I have the same laptop with the same behavior
    • RaptorHunter
      • Aug 2024
      • Mozambique
      Is it possible to bypass the USB-C PD and use adapt a barrel style charger?
      • mon2
        • 13917
        In theory, yes.
        The PD controller is a stand alone controller that will request the supported power delivery contracts (voltage & current pairs) from the mated power source. Then the PD controller will select the most suitable PD contract to power up the logic board. Often, it will be 20V @ xx current.
        This PD contract is presented on the VBUS rail which is then fed onto the charger leg of the circuit - often at the DCin mosfets. This is where the same circuits as we have all seen are applied like the barrel jack power adapters.
        In theory, the VBUS pin is where the raw barrel jack connector voltage should be applied. Review the charger circuit to study if the DCin mosfets will enable once there is enough voltage at that junction. That is, once 20v is presented, the DCin mosfets must enable to proceed with the power path.
        For now, study the idea but yes, it could work. Sometimes the laptops feature 2 methods to power the boards - traditional / magsafe (macbook) style + USB Type C. Be sure to test each method if the laptop supports it. We have seen 2 of these this week alone. The client had liquid spill so we were able to clean up the corrosion and the $3k macbook was saved.
        • CornholioGSM
          • Feb 2014
          • 263
          • CZECH
          Hello
          By me was today C421 with same problem - input only 5V. After bootup win with precharged battery was visible problem in device manager - Device UCM-UCSI shows error code.
          So i have desoldered rts5455 from donor board (E590), then bios update. After reboot no error in device manager, but still not charging
          So i have replaced 6S30A (SN1710033RUKR).
          ....and now is all fine
          Soo i can confirm, that rts5455 from another board is working after "reflash".
          • huzo
            • Sep 2014
            • 178
            • CROATIA
            Hello!
            i have the same problem, changed the rts5455 and 6sS30A from donor board, but still only 5V charging...The original problem was a bad C-type connector, i replaced that also and still no charging...replaced the two chips, still the same...charged the battery ,did a bios update...still nothing...what next?
            • us to be
              • Dec 2023
              #26
              Originally posted by CornholioGSM
              Hello
              How you made the bios updete please.
              • huzo
                • Sep 2014
                • 178
                • CROATIA
                #27
                You must charge the battery somehow and load windows and let it update the firmware, or update it manually from Lenovo site...
                • us to be
                  • Dec 2023
                  #28
                  Tks , so the laptop does not look for connected charger.
                  • ALeXXBodyz
                    • Aug 2019
                    • 10
                    #29
                    Here is a dump for RTS5455 for anyone who needs it.
                    • mon2
                      • 13917
                      Thanks ALeXXBodyz, very much appreciated.
                      • ALeXXBodyz
                        • Aug 2019
                        • 10
                        #31
                        And here is the connection for RTS5455. After the connection is made, you can use any charger connected to USB Type-C (you just need 5V) to power the programming process.
                        I'm using SVOD4.
                        • us to be
                          • Dec 2023
                          #32
                          You are great.
                          • ThinkpadMounty
                            • Sep 2023
                            • 14
                            Hello
                            what is 6S30A? i have similar issue and not sure if getting new Realtek chip is enough?
                            • ThinkpadMounty
                              • Sep 2023
                              • 14
                              UPDATE : so fitted new RTS5455 now get 20 V but no current - should i try fitting new 6S30A?
                                Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-06-2024, 11:40 AM
