Alienware m15 R1
  • MOCCOR
    • 10
    Alienware m15 R1
    Hi. I was gaming one night and my laptop suddenly shut off. It wasn't a long session, maybe 20 minutes at most after about 24hrs of no gaming inbetween, so it shouldn't have been super hot. The PKCH2BB for sure must have "popped" as it slightly cracked the clear plastic underneath the "A" button. The SM4365A looks a little yellowish from what I seen and also had the black plastic sheet melted to it before I scrapped it off. I ordered replacement components for both of them and I kinda want to give it a try replacing them. But does anyone have any idea if it is worth it or should I check elsewhere for a problem first?
    I am comfortable with soldering, but when it comes to knowledge of components to test for problems, my knowledge is only beginner level. Weirdly, the DC power connector looks untouched, which is right above the 2 components. And the AC Adapter never "shuts off" if I plug it into the laptop, but I am not sure if that is a good or bad thing. I recycled the laptop battery long ago due to pillowing, so that kinda sucks because I feel like that would confirm whether it was just simply the Charger port or something like the CPU/GPU.
    I tested the AC adapter with a meter and it is fine, I tested the AC-DC adapter and it is fine, so its something between that DC-IN connector and the laptop, which surely is one/both chips, but is there anything else I should test? Thanks for any help
  • Sephir0th
    • Oct 2020
    • 1283
    You can test the mosfets by setting the multimeter in Ohms mode and measuring between Source (Pin 1,2,3) and Drain (Pin 5,6,7,8), between Source and Gate (Pin 4) and between Drain and Gate. There shouldn't be a reading below KiloOhms. Orientation of the Probes doesn't matter. And add a resistance measurement of the Second Mosfet Drain compared to GND
    FairRepair on YouTube
    • MOCCOR
      • 10
      Thank you for the response. I measured the two in what I hope was the correct way, and these are the results -
      SM4365A, https://datasheetspdf.com/pdf-file/1...r/SM4365NAKP/1
      Source to Gate = 114
      Drain to Gate = 0
      Drain to GND = 0
      PKCH2BB, https://datasheet.lcsc.com/lcsc/1912...BB_C384597.pdf
      Source to Gate = 115
      Drain to Gate = 115
      Drain to GND = 0.240
      I should also mention, I did give the board a couple look overs and I didn't see anything obviously bad, other than those two mosfets having burning discoloration so I ordered them ahead.
      • MOCCOR
        • 10
        I don't see any edit button anywhere, but I do have another question. Normally my laptop would max around 88-90C, which is decently below the "safe" temps. It's possible other components were hotter than others, but do you know why this component might have burned up? The schematic shows a operator temp of up to 150C, so I find it hard to believe it hit 150C, but not impossible. 2 things might have contributed to it.
        1. Laptop plugged in 24/7 for a couple months, maybe that component only goes "idle" when the charger unplugs?
        2. I designed a 3D printed vertical laptop stand (with lid closed). In my test, it showed slightly less temps for the CPU and GPU. But I didn't take into account that other areas could have gotten hotter. So it is possible the verticality + lid closed = hotter PKCH2BB. It was just kinda weird that I had 3-4hr gaming sessions no problem, and then suddenly during a 15-20min session it burned up
        • Sephir0th
          • Oct 2020
          • 1283
          If the parts were already degraded then it is more question of time than a question of load. It's just coincidence that it happened without heavy load present. Maybe it will result in a economical repair, maybe not.
          Because if the SM4365A reads 0 Ohms to GND (Please confirm!) then you have more problems than just the shorted Mosfets:
          A short-circuited Main Power Rail in addition, which needs to be troubleshooted separately.
          Does any inductor present on the mainboard read the same 0 Ohms to GND?
          • MOCCOR
            • 10
            I redid the test and still got 0s until I used black (COM) on Drain and Red (VmA) on Gate + GND. Pretty sure I used the same colors on the PKCH2BB but idk if that makes any sense. Or maybe I just simply didn't press hard/accurately enough, my mistake.
            So the new values for SM4365A are -
            Drain to Gate = 739
            Drain to GND = 465
            Not sure if those values are good/bad since my knowledge of mosfets is pretty basic, I greatly appreciate your input. And ty for the information of degradation, that makes sense for a 3-4yr old laptop
            • MOCCOR
              • 10
              I tested all of the inductors I could easily see and they all seemed fine, none of them read "0" but some did read 2s, 3s, 7s. But from my research they are usually low numbers. Some of them were 60s, 70s, 160s depending if they were on the outside or near the CPU/GPU. But no 0s
              • tofik
                MOSFET equivalent K8A60DA
                by tofik
                Hello guys,
                I have a shorted MOSFET K8A60DA with the following characteristics:
                Type Designator: TK8A60DA
                Marking Code: K8A60DA
                Type of Transistor: MOSFET
                Type of Control Channel: N -Channel
                Maximum Power Dissipation (Pd): 45 W
                Maximum Drain-Source Voltage |Vds|: 600 V
                Maximum Gate-Source Voltage |Vgs|: 30 V
                Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                Maximum Drain Current |Id|: 7.5 A
                Maximum Junction Temperature (Tj): 150 °C
                Total Gate Charge (Qg): 20 nC
                Rise Time (tr): 25 nS
                Drain-Source
                07-19-2023, 05:18 AM
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • gpx
                HP 250 G5 (LA-D704P with a Core i7-6500U) won't POST
                by gpx
                Hi everyone, I am hoping for a little help with an HP 250 G5 with motherboard LA-D704P with a Core i7-6500U. I am new to board repair but keen to learn.
                I am sorry this post is quite long but I was trying to systematically work my way through things.
                I don't know the history of the board – I bought it as part of a job lot.
                I have attached a number of photos of both sides of the board. I cannot seem to find a schematic or boardview online.
                When plugged in to DC power the power LED lights and the battery seems to charge. It will not...
                06-18-2021, 10:39 AM
                Alienware 13 R3 Notebook Specification for Upgrade or Repair
                This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
                09-06-2024, 06:42 AM
