macbook A1707 Board (820-00928) (Board Schematic 820-00281) U3905 BGA Corroded pin 21
  • abajor
    • 175
    I'm trying to get this A1707 macbook working. There was some liquid damage under U3905 and corrosion around the Tantalum capacitors C3502 C3504.
    Removing the U3905 (PN66VEU3-A101D004) shows that the pad is somewhat damaged. I'm not reading continuity between pin 21 and the filter cap C3919.
    Researching that part shows that its an NFC chip, which makes me go huhhh? And Why??? Why does a macbook even have and NFC chip, and if I just leave it out will it cause issues?
    If I can get away with just replacing the tantalum caps and ignoring the NFC chip that would be great since It appears the pad was on top of a via, and I'm not certain how to repair that.
  • abajor
    • 175
    I was able to boot into a clean OS leaving the NFC chip off; however, there appears to be something wrong with the Touch bar, giving me the dreaded can't install critical update error.
    I'm assuming it has nothing to do with the touch bar the Section of the schematic it's in is referred to as "Stockholm".
    • reformatt
      • Feb 2020
      • 1416
      There's no NFC function in the MAC, however some functions of it are needed for the T1 (as it's a CPU design borrowed from the iPhone). Critical update refers to the firmware for the T1 CPU and this handles things like Touch ID and Touchbar etc. You'll have to run a jumper to the broken pad 10,21 to fix and reinstall the IC.
      • abajor
        • 175
        Interesting that the part number shows up as being an NFC device. I wonder who at apple thought "Stockholm" was a good choice for controlling those components. We love our fruity captors.
        I will try to find a nice fine wire for making a jumper. Very fortunate it is on the edge of the BGA.
        Do you know if that chip is paired to match serial numbers?
        Thank you very much.
        • reformatt
          • Feb 2020
          • 1416
          About the only connections to it is via SPI from the T1. Likely they couldn't bother reworking the whole CPU to omit it as it doesn't appear to go anywhere else. Dunno, but the fact that its on the board means it's needed for something. AFAIK, the only thing that is serialized on T1 one machines is Touch ID and that's linked to the T1 itself and it's ROM.
          • abajor
            • 175
            BTW not sure what you mean by broken pad 10, 21. It's pad 21 It's a 3V rail and pad 44 appears to be the same rail. Not sure if its redundant power connection. The problem I'm having right now is I only have 36 AWG wire and it's still to thick to create a trace from C3919 to pad 21. I could try to make a groove to accommodate wire, but worried about damaging a layer. The trace for pad 44 is exposed but I'm not sure how important the connection to that filter capacitor is, I did run the jumper there just in case.
            I accidentally took out R5851 and C3915 in the process, so now I need to wait for those parts before testing.
            BTW has anybody make any tutorials on repairing a BGA pad, at least one on the perimeter? I know Rossman recommends using battery wire from old macbook pro batteries for extra fine work.
            Thanks for the help!
            • mon2
              • 14271
              Yes, review this video - Wylie started this repair BGA ball pad kit:
              https://www.youtube.com/watch?v=I_6xZVY7sFM
              Mobile sentrix (USA / Canada) sells them.
              https://www.mobilesentrix.com/wylie-...-soldering-lug
              • reformatt
                • Feb 2020
                • 1416
                Having an elderly moment and looking at the wrong chip, so yes only pin 21 needed. As it's at the edge of the chip, you can just run small jumper and tack it down with conformal coating to hold it in place. This is what I do with other chips like the backlight IC on airs when the feedback pin is corroded.
                You can use 0.01 or 0.02 Mechanic jumper wire. It's enameled though so can be a PITA to tin when it is very short like that. I have used a single strand from my desoldering braid when it's only a very short jumper and doesn't need to be insulated. It is a hack, but the resistance of such a short wire is negligible.
                If you want to look at the Wylie style pad repair, check out some of the videos on the KrisFix or NorthWest Repair YT channels, where they fix ripped pads on the edges of GPU's. They do make it look rather easy.
                I also recommend the Mechanic KA-11 tweezers for the finer work with jumpers, and where components are closer together. I haven't have much success with the Titanium 'flyline' tweezers myself, the tips always seem to deform and bend for me. The KA-11 are ultra fine but are quite resistant to bending.
                • abajor
                  • 175
                  Thanks for the tips I will probably need to order another one of those chips just in case I killed it. It didn't seem like there was a nub of a trace under where the pad is, my biggest concern is there are other critical paths on a layer underneath that are now compromised, but I suppose I can just trace it out and see if any voltages are missing since it's just a 3v3 rail.
                  I just have some Wiha 7a SA-ESD right now They're pretty sturdy but maybe a bit CHONKY compared to the KA-11. I should probably pick up some finer tips straight tweezers.
                  • abajor
                    • 175
                    Thanks for the tweezer recommendation, the KA-11 are sharp literally. I was able to repair that pad it certainly is receiving the 3.3V I put in a replacement chip and as far as I can tell the bga flowed well snapping itself into place with surface tension, annnnnd still gets the dreaded can't install critical update error.
                    Interesting things of note. If I don't power up the laptop with the battery disconnected first so I see the Low battery logo, then connect the library and power it up, the machine does a weird power cycle loop where it draws up to 1.4~1.5 A idles around .8A then goes to zero and cycles with this behavior.
                    It boots into the OS setup if I power first before connecting the battery. I'm still stuck at the critical update needed.
                    I don't know much about the history of this laptop, all the moisture stickers are red; however, there was only one tiny area of corrosion on the Stockholm chip.
                    Are there any signals I should try to observe from this chip?
                    I have no real way of knowing what the condition of the touch bar is my next step is to just try changing bodies and seeing if it's a bad touch bar.
                    • leonemax81
                      Macbook a1707 820-00281 Battery no Power
                      by leonemax81
                      Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                      08-23-2024, 09:24 AM
                    • sofles
                      Macbook a1707 2017 model 820-00928 GPU issue
                      by sofles
                      Hello there
                      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                      11-21-2024, 05:25 AM
                    • tommy97
                      Apple MacBook A1707 No Audio/Sound
                      by tommy97
                      I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                      I've also replaced U6300, but the problem persists.
                      Here are the current voltage readings:
                      • PPV18_S0: 1.8V
                      • R6402: 1V
                      • R6405: 1V
                      • R6403: 1V
                      • AUD_SPKRAMP_RESET_L: 1.3V
                      • PPBUS: 12.6V
                      03-10-2025, 11:22 AM
                    • Cemal Odabasioglu
                      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                      by Cemal Odabasioglu
                      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                      Observations...
                      01-14-2025, 03:54 PM
                    • Herby94
                      MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
                      by Herby94
                      I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
                      • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
                      • When connected, the fans spin for about 30 seconds before shutting off.
                      • No display, no audio, and no signs of life during this time.
                      Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
                      08-07-2025, 08:59 AM
