Surface Laptop 4 no USB (Intel i5)
This topic has been answered.
  • Vanillaboard
    • 15
    • Kärnten
    After my Surface Laptop 4 was rejected by Microsoft repair due to an alleged water damage. As a result, I've decided to tackle the issue myself. Unfortunately, after a use involving a self-soldered USB board, the USB port (not USB-C, which still works) is no longer functioning.
    Now, I suspect that a short circuit may have damaged something on the motherboard. I've checked for any visible damage according to the schematics but couldn't find any. So, I decided to check if there's any voltage on the Vbus. Sadly, it's reading 0V. I've traced the supply and came across the NO-MSPN-00312 controller. Initially, it has a 3.3V input voltage, but there's no output voltage anywhere. Now, my question is: could a faulty ic be the cause? The IC has a 'SENS' circuit as well; what is this for? Could anyone provide a hint as to its purpose?
    i also attachted PDF Shematics .
    [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...ntel-schematic
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/troubl...f-this-section
    ​Maybe someone can help me here, would be awesome
  • Answer selected by Vanillaboard at 02-17-2024, 04:49 PM.
    mon2
    • Dec 2019
    • 14259
    If there is no short at the output and you have the input at +5v then the usb load switch at u4503 is defective. Review it but it should be replaced. You will need proper tools + flux + some experience on another board before attempting this replacement. Or ask your local phone repair shop that can handle board level repairs.
    • Ken123
      • Oct 2021
      • 58
      • Sverige
      Im not an expert but where you had 0v, did you check for short there?
      • Vanillaboard
        • 15
        • Kärnten
        on USB VBUS i have 0 Volts. so after the ic i havent any Voltage. Only on IC input.
        No short here. :/
        have to reverse my measurments.
        I have this chip: NCP380HMUAJAATBG
        https://www.mouser.at/datasheet/2/30..._D-2317053.pdf
        Its U4503 on Shematics.
        On Input PIN 5 i Have 5Volts.
        Output PIN 1 is 0V (No short to Ground),
        On En PIN 4 i have 1.8V
        on SIDE GRound Pin 5 I also have GND
        and on Flag PIN 3 i Have 3.3V
        SO i Have no Output.
        The 3.3V should say me that there must be a problem on putput right?
        • Vanillaboard
          • 15
          • Kärnten
          short to ground.
          Maybe this s the issue? i desoldered t but still have 3.3V on FLag Pin.
          The short on output is not present Anymore.
          The weird thing is that after i turn laptop on for check i have short again.
          Click image for larger version  Name:	Unbenannt.jpg Views:	0 Size:	80.3 KB ID:	3218533
          • mon2
            • Dec 2019
            • 14259
            • Vanillaboard
              • 15
              • Kärnten
              i did have short. I was wrong in the first measurment.
              So i desoldered the Kapasitors first but no solve. after i disoldered u4503 and short is gone.
              as you said i need replace this.
              Thanks for all
                Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 08:47 AM
                Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-07-2024, 06:11 AM
