With 1v and 1a it tops, same with 2A or 3A.
I don't want to go beyond this as the risk of burning the copper trace is very high.
This is a Invalid argument, considering that you can't notice anything so far. More Amps is no problem. But more voltage might or might not turn the board into a no-fix.
When it takes 3Amps and nothing to spot, raise the Amps. When it takes 4Amps and nothing to spot, raise the Amps, and so on.
Are you sure my friend?
I'm not sure so thin copper trace can handle 4 or 5A.
My friend, I don't want to make a showroom for myself here, but I probaby need to convince you that i am experienced on chip-level, working at this level for 4 years, running a repair business, and running a YT-Channel.
And without logical conclusions, you can't be succesful.
It is simple: if the tracks would be a issue here, they would already light up like a new year fireworks. But they don't, no?
I don't know how and from where you learned about these things, but voltage injection can not be seen as a static procedure. You always have to adapt to the circumstances.
So you have two choices now. Either you continue to mistrust my instructions and therefore continue to go round in circles. In that case, I won't pursue this case any further... OR you implement the instructions immediately.
The truth is, either the observations or the measurements must be wrong, otherwise we would have made progress long ago.
Ok so with 1v and 5a a small cap became a little hot, without thermal camera it would be impossible to track it.
All good and laptop power up and charges battery as well, the problem now is that integrated screen doesn't light up, with HDMI i get image juat fine.
I'm not sure if it's only the backlight or the complete screen since the digitizer is not helping me to see clearly if there is image on dark screen or nothing at all.
Only i can see is that screen has some reaction when i power up the laptop (like it's trying to light up momentarily) but unsuccesfully.
What do you suggest?
Hello!
DCBATTOUT_LCD 19v
LCDVDD 3.3v
BLON_OUT 0v (not sure if i measure the correct number 30 pin so i measure all around, all 0v)
LCD_BRIGTHNESS 0v too
No BLON_OUT is likely the issue here. Make sure RN5501 is not internal shorted and that D5503 has not failed too. Clarify whether R5512 is present on the PCB and measure resistance to GND of RN5501 Pin 2 & 7 and of D5503 all pins.
Could be EC fault with some luck or something missed from visual observation.
