Dell Latitude 3390 short on power adapter.
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello.
    I bought a faulty 3390 for my self, it has shortcircuit upon inserting the power supply and the led of it goes off immediately.
    I found a blown mosfet PU4301 that i replaced, after than with the use of a thermal camera i found a nearby capacitor PC4306 to be "burning", replace it too but the short is still there and the new capacitor is burning too.
    What am i missing?
    Boardview and Schematics https://www.badcaps.net/forum/troubl...-cad-boardview
    Thank you!
  • Sephir0th
    • Oct 2020
    • 1289
    You likely forgot to check the health of the main power rail before starting with your work at this capacitor. At PR4402 for example.
    FairRepair on YouTube
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      Thank you for replying and yes that's true, after desoldering of PR4402 i got short on top pin to GND.
      What do you suggest next? Power injection 1v 1a?
      • Sephir0th
        • Oct 2020
        • 1289
        Yes, start with 1A and raise the current in 1A steps if necessary. Don't raise the voltage as long as it is not clear whether it is a short to GND or a short to a high-current buck converter (CPU/GPU). The clue about this question usually comes from the exact resistance compared with the resistances of aforementioned buck converters.
        • Andreasbest
          • Aug 2014
          • 1196
          • Hellas ( Greece )
          I tried with 1v 1a but nothing got hot, then i raised V until 3v but never managed go more than 0.7v, so i raised A to 3, this raised correctly so i inject a total of ~3w but still nothing got warm.
          I was affraid to go more than that, i don't want to burn the copper trace.
          • Sephir0th
            • Oct 2020
            • 1289
            Share the exact resistance to GND please. If it ia a capacitor, it should warn up. Iirc correct I have advised to not move with the voltage above 1 Volts, since it can be the case that the voltage feed more or less directly the CPU or GPU.
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              I'm away from the bench for the next 2 days, i'll check the resistance Monday morning and i'll share the measurement.
              Yes, i rarely go over 1v too, thankfully it was impossible to go over 0.7v thanks too the short )
              • Andreasbest
                • Aug 2014
                • 1196
                • Hellas ( Greece )
                The exact resistance of upper PR4402 to GND is 0.8Ω, practically 0.
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  Someone? Anyone???
                  • Andreasbest
                    • Aug 2014
                    • 1196
                    • Hellas ( Greece )
                    Bump
                    • Andreasbest
                      • Aug 2014
                      • 1196
                      • Hellas ( Greece )
                      Bump
                      • Andreasbest
                        • Aug 2014
                        • 1196
                        • Hellas ( Greece )
                        Bump
                          • 21932
                          Originally posted by Andreasbest
                          Bump
                          Post a link to the schematic/boardview
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            Is there any inductor present on the mainboard which reads the same 0.8 Ohms or similar resistance to GND?
                            • Andreasbest
                              • Aug 2014
                              • 1196
                              • Hellas ( Greece )
                              I measured all coils (if this what you mean by inductor) but no, no 0.8Ω anywhere.
                              • Sephir0th
                                • Oct 2020
                                • 1289
                                Then, In theory, there is no reason against to raise the voltage in small steps. The short-circuit is strong, so normally you should find a capacitor at some point. Better advice would be of course to observe the board with thermal camera while injecting 1Volts.
                                • Andreasbest
                                  • Aug 2014
                                  • 1196
                                  • Hellas ( Greece )
                                  Yes this is what i do, with thermal camera i go up until 1v 3a but no heat at all, both sides.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1196
                                    • Hellas ( Greece )
                                    Bump
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      Bump
                                      • Sephir0th
                                        • Oct 2020
                                        • 1289
                                        Alright, then, we likely need to collect more informations. Share what current the short-circuit takes with 1V, to start with.
                                          DELL Latitude 3390 Hybrid (2-in-1) 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 3390 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3390 boardview and 3390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 12:36 PM
                                          09-06-2024, 08:01 AM
                                          09-06-2024, 07:14 AM
