MacBook Pro A1706 - Stuck at 5V and 0.09A
  • BMCappelletti
    • Nov 2021
    • 151
    • Brasil
    Hi everyone.
    MacBook Pro, model A1706, EMC 3071. Charger shows only 5V and only 0.09A drawn. Board is 820-0239-A. Mint condition. Pretty sure no one ever opened it and was not used much.
    I tested all steps from the table here https://logi.wiki/index.php/CD3215_Bootup_Sequence changing the CD3215 lines as I moved from one USB-C to the other.
    What I found was:
    - on step 3, I have the voltages as 10V and 7.8V, indicated as "Air" on this table, which I suppose would be for a MacBook Air. But this one is a Pro. Same on all DC3215s.
    - on step 11, on diode mode, I have 0.47V to 0.48V, not the 0.8V. Again, for all DC3215s.
    - the ones marked as 20V there is no reason to test, as the board does not pull 20V from the charger. But I do have 5V in them.
    - step 15 says 5V on TBA_AUX_DET. I have 1.3V.
    The schematic for this board shows this.
    The board does not have that C7016 cap, but has the resistors. They are hard to measure, as are really small. And I know I should remove them from the board. But, on circuit, R7016 is measuring 150k ohms and R7015 is measuring 1.3M ohms.
    Any help on what I should try or measure next is much appreciated.
    Thank you.
  • mon2
    • Dec 2019
    • 14663
    Do not remove any parts till more is known about the logic board's condition.
    What is the voltage to ground of PPBUS_G3H @ fuse F7000 ? Check each side.
    • BMCappelletti
      • Nov 2021
      • 151
      • Brasil
      13V on both sides.
      • mon2
        • Dec 2019
        • 14663
        13v is a good voltage to ground reading.
        Step 11 is a voltage to ground reading - not a diode mode measurement.
        Do you have each of the LDO voltage readings to ground for the active CD3215 ACE controller? Do they match the referenced article on CD3215 boot sequence?
        What is the voltage to ground of PP3V3_G3H @ L6900 ?
        Review this webpage:
        https://repair.wiki/w/MacBook_Pro_A1..._of_20V_repair
        • BMCappelletti
          • Nov 2021
          • 151
          • Brasil
          Yes, I do have the LDO voltages. They are all equal the ones from that table.
          Voltage on L6900 is 3.4V.
          The link you sent seems to be all around PP3V3_G3H, which I do have. I can't see any corroded componentes, from the ones mentioned in there. The board is really clean.
          Checked CC1 and CC2 again. I do have 0.8V on it. Small components. Has a bad measure before.
          • mon2
            • Dec 2019
            • 14663
            The CC1 / CC2 lines are the single wire BMC interface lines. Each is used by the host logic board and the external power adapter to select the power delivery contracts. Respectively, the LDO must be operational on that CD3215 being tested to power this leg of the circuit. Note - you will only measure a voltage on the CC1 / CC2 pin if that side of the type C blade and that type C connector is in use. That is, you may measure something on CC1 but nothing on CC2 till you rotate the power adapter type C connector. Then the CC pins will reverse. It is the CCx pins that become active during the respective orientation of the cable head.
            Believe it is the 1v0 LDO rail used for the BMC interface but you can confirm by checking the netnames in the schematic. Respectively, the 5v power delivery contract is the factory default of all power delivery capable power adapters. After a proper communication over the CCx line, a higher pair of voltage / current contract will be selected (ie. 20V @ 5A, etc.).
            Do check the condition of the SPI flash devices which are used as the firmware for the CD321x devices.
            • BMCappelletti
              • Nov 2021
              • 151
              • Brasil
              Yep. I had to rotate the charger connector to get some readings.
              As for LDOs... you mean PP1V1_UPC_XB_LDO_BMC? I do have 1.1V on it, on 4 measurements (each CD3215).
              By SPI flash you mean the MXIC EFI chip? All seems fine. Receiving 3.3V. CD3215 firmware would be the TB ROM chip? Visually fine, too. And getting 3.3V.
              Sorry if I missunderstood something.
              • BMCappelletti
                • Nov 2021
                • 151
                • Brasil
                Ok. Reading again your message. You meant only the thunderbolt part. Ok. Same answer, anyway.
                • mon2
                  • Dec 2019
                  • 14663
                  Yes, ok not BMC CCx pins.
                  Is your logic board power cycling or just climbs to this low current draw of 90mA and stops?
                  • BMCappelletti
                    • Nov 2021
                    • 151
                    • Brasil
                    Climbs and stops. No power cylcing. So I guess there is no issue with a specific CD3215, but with something else.
                    • mon2
                      • Dec 2019
                      • 14663
                      What is the voltage to ground of PP3V3_UPC_TA_LDO ? PP3V3_UPC_XB_LDO ?
                      Also interested in the voltage to ground values for:
                      SMBUS_SMC_5_G3_SCL
                      SMBUS_SMC_5_G3_SDA
                      * although these should be ok since PPBUS_G3H is @ 13v which means the SMC has boosted this voltage rail already using the same I2C interface
                      Suggest to remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor on the board. Checking for any low resistance measurement -> then review which power rail is linked to this low resistance to ground inductor.
                      At this time, the ISL9239, which is a buck/boost regulator is acting in boost voltage mode (5V input -> boosted to 13v output). Would you have a flash IC programmer tool? You can consider to reflash the firmware that resides inside of U2890 and UB090.
                      • BMCappelletti
                        • Nov 2021
                        • 151
                        • Brasil
                        SMBUS_SMC_5_G3_SCL
                        SMBUS_SMC_5_G3_SDA
                        PP3V3_UPC_XB_LDO is 3.3V on all CD3215s.
                        PP3V3_UPC_TA_LDO also 3.3V.
                        Yes, both SMBUS lines at 3.4V.
                        I do have a programmer. Not sure if I have any compatible board to solder those componentes on and read it.
                        I'll check it later. And check the resistances.
                        Need to do some stuff outside home. Will be back later.
                        Thanx a lot.
                        • BMCappelletti
                          • Nov 2021
                          • 151
                          • Brasil
                          The only really low resistances found are on the top coils, with 3V, 3V, 3V, 6V, 6V and 9V. But they are all CPU.
                          The others are:
                          P1VS4 - 79 ohms
                          P1V0PCH - 53 ohms
                          P1V2 - 237 ohms
                          PVCCIO - 49 ohms
                          P2V7NAND - 12K ohms
                          P5VUSBC - 9K ohms
                          PP5V - 41K ohms
                          PP3V3 - 34K ohms
                          TBA - 2,1M ohms
                          PPVIN - 1,08 ohms
                          P5VUSBC - 8K ohms
                          • mon2
                            • Dec 2019
                            • 14663
                            PPVIN - 1,08 ohms
                            Can you confirm this one?
                            • BMCappelletti
                              • Nov 2021
                              • 151
                              • Brasil
                              1.08M.
                              • mon2
                                • Dec 2019
                                • 14663
                                What is the voltage to ground of ALL_SYS_PWRGD ?
                                • BMCappelletti
                                  • Nov 2021
                                  • 151
                                  • Brasil
                                  I got 0 on it.
                                  • BMCappelletti
                                    • Nov 2021
                                    • 151
                                    • Brasil
                                    Going ahead of myself cause... why not? I measured all pgood lines.
                                    CPUVR_PGOOD - 0V
                                    P1V0PCH_PGOOD - 3.3V
                                    P1V8SUS_PGOOD - no test point
                                    P1VSUS_PGOOD - 3.3V
                                    P2V7NAND_PGOOD - 0V
                                    P2V7NAND_PGOOD_R - 0V
                                    P3V3SUS_PGOOD - no test point
                                    P5VS4_PGOOD - 3.3V
                                    P5VUSBC_X_PGOOD - 1.2V
                                    PICCOLO_PGOOD - 0V
                                    PVCCIO_PGOOD - no test point​
                                    • mon2
                                      • Dec 2019
                                      • 14663
                                      Good. This power good line being low means that at least one of your power rail is not at a good voltage. Review the NAND voltage rail from your above list. Measure the voltage to ground of this power rail.
                                      Next, remove all power -> measure the resistance to ground of this same power rail. Post each measurement.
                                      • BMCappelletti
                                        • Nov 2021
                                        • 151
                                        • Brasil
                                        Both P2V7NAND lines are on R9411 resistor. Both show around 12k ohms to ground, with 0V.
                                        P2V7NAND_PGOOD goes to U9300 area.
                                        P2V7NAND_PGOOD_R goes to U9400, right above it.
                                        • Steven Pieter
                                          Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                                          by Steven Pieter
                                          hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                                          11-24-2024, 10:02 AM
                                        • pluggedDan
                                          MacBook Pro A1706 charge stuck at 5v when battery is plugged in
                                          by pluggedDan
                                          I have an A1706 that was liquid damaged, the logic board turns on and works when the battery connector is not plugged in, but when the battery is plugged in, the computer is stuck on 5v @ 30-40 Mah, and USB-C meter will reboot every 5 sec or so, pressing and holding down the power button will make the USB-C meter to stop boot looping, and if you keep holding it, fan will quickly spin up and turn off.
                                          when the battery is unplugged and plug in the charger then plug in the battery it will stay on 20V and 1.6A-2.6A but when you unplug the charger, the computer...
                                          10-29-2023, 02:41 PM
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
                                        • modtool
                                          Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
                                          by modtool
                                          Dear friends,
                                          a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
                                          I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
                                          I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
                                          Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
                                          10-25-2025, 05:09 AM
                                        • MyronViegas
                                          MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                                          by MyronViegas
                                          Hey guys,
                                          I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                                          Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                                          10-06-2025, 08:45 AM
