Macbook Pro A1990 820-01814-01 no power
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    I have a problem with a MacBook with 820-01814-01 mainboard, the Macbook gives no signs of life, I have tried different power supplies.
    I noticed a short (6ohm to ground) on the capacitors near the CPU, from board view the short is on the PPVCCGT_S0_CPU line. The very kind and super user mon2 has already told me that we can't consider short circuit 6ohm on CPU rail.
    Another short (20ohm to ground) on other caps near CPU on the PPVDDCI_S0_GPU.
    Is this normal?
    Is there anything I can test?
    There are no signs of water contact or other visible damage on the mainboard
    Really thanks​
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    Hi Guys.
    I found this topic and before I open a new one I would like to ask for help here.
    I have a problem with a MacBook with the same mainboard, the Macbook gives no signs of life, I have tried different power supplies. I noticed a short (6ohm to ground) on the capacitors near the CPU, from board view the short is on the PPVCCGT_S0_CPU line.
    Is this normal?
    • mon2
      • Dec 2019
      • 14672
      6 ohms to ground for the cpu power rail is not considered to be a short. Start a new thread for a review.
      • mon2
        • Dec 2019
        • 14672
        Meter in DC volts mode (20v or higher scale is ok). Measure the voltage to ground of PPBUS_G3H @ fuse F7000 or F7001. Do measure both sides of these fuses with the power adapter connected (for now, disconnect the battery).
        If there is no voltage present here, remove all power (no adapter / no battery) -> meter in resistance mode. Measure the resistance to ground on each side of these same fuses.
        Post each measurement.
        • ryogadan78
          • Nov 2021
          • 66
          • Italia
          Hi mon2, thanks for your valuable help and sorry for the delay, I only have access to the lab in the morning these days.
          I measured the voltage both sides of the two fuses, always measuring 12.6V​
          • mon2
            • Dec 2019
            • 14672
            This is a good voltage. T2 has booted and the SMC has boosted this rail to 12v6.
            does the caps key led toggle?
            is the power adapter voltage at 20v ?
            Use of a usb-c meter will be very helpful. You can probably get one from Amazon. To view the adapter voltage and current draw.
            Suggestions are to check the voltage to ground at each inductor on the board. Each inductor is linked to a local power rail. Note any inductor with 0v or incorrect voltage. The schematics will list the proper voltage for each inductor. If not practical, remove all power and check the resistance to ground of each inductor.
            Check to see if the SSD power lines (0v9, 1v8, 2v5) have voltage.
            If they have voltage try to put into DFU and attempt revive using another machine.
            What was the history? Just stopped working?
            • ryogadan78
              • Nov 2021
              • 66
              • Italia
              Hi, thank you again.
              - the caps key led is off
              - the power adapter is the original one, 20v, that works on another macbook
              - I had a usbc tester, but it no longer works. I bought a new tester two days ago, it should arrive within a few days.
              - I am having difficulty reading the schematics (but I can try), here are the measurements of the resistence to ground of each inductor
              L7410 6.4ohm
              L7420 6.4ohm
              L7211 3.2ohm
              L7221 2.9ohm
              L7231 2.9ohm
              LA340 2.7ohm
              LA640 2.7ohm
              LA650 2.7ohm
              LA350 22.1ohm
              LA350 217ohm
              L8102 48ohm
              L9080 1.5ohm
              L9081 1.5ohm
              I think these are the principal inductors, if further measurements are needed I'll do them right away
              I am not sure where to take the measurements you requested for SSD lines. I tried:
              P0V9_LX0_SSD0 (on L9021 inductor): 0.9V
              P1V8_LX0_SSD0 (on L9030 inductor): 1.8V
              PP2V5_NAND_SSD0 (on L9080 inductor): 0.2V
              I notice that in this area the mainboard gets very hot
              The notebook suddenly turned off; I'm pretty sure it still had a charged battery. Then it did not turn on again, I tried other power supplies but to have no success.
              • ryogadan78
                • Nov 2021
                • 66
                • Italia
Name:	Immagine 2024-02-09 114711.jpg
                Notably, doing the test with isopropyl alcohol, capacitor C9089 seems to be the hottest one
                • mon2
                  • Dec 2019
                  • 14672
                  this could be the deal breaker. The nand flash may be defective or someone on this power rail is shorted.
                  you noted the hot capacitor. Flux it and remove the hot capacitor. Then measure the resistance to ground again for this power rail. Then power up without this hot capacitor. Low air pressure but enough heat to melt the solder.
                  • ryogadan78
                    • Nov 2021
                    • 66
                    • Italia
                    Removed C9089... everything works wonderfully!
                    I also found a capacitor from a donor board that I put in place of the shorted one. But out of curiosity I could have also not put it in?
                    Thank you very much for the invaluable help. You are the best
                    • mon2
                      • Dec 2019
                      • 14672
                      The part could have been left off without a problem. Well done!! Good team effort.
                      • Patrick501
                        MacBook A1990 PPBUS_HS_CPU short
                        by Patrick501
                        I have a A1990 which had a blown inductor next to the display connector. There was no short at this spot, so I replaced it.
                        I noticed that the big coils above the GPU/CPU (PPVCORE) had a pretty low resistance (2.2Ohms). I already talked about this with mon2.
                        PPBUS_G3H, PPBUS_HS_CPU showed 1.8ohm to gnd. So I removed the R5400 to seperate the two rails. PPBUS_G3H is fine again but the short is unfortunately on PPBUS_HS_CPU. Sounds like a no fix to me.
                        Plus I can't find any particular spot which his heats up when I inject 1V@max2A
                        02-06-2025, 02:52 AM
                      • Stephen
                        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                        by Stephen
                        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                        02-06-2025, 12:03 PM
                      • sdogs
                        macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                        by sdogs
                        Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                        First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                        I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                        06-27-2025, 01:58 PM
                      • sdogs
                        by sdogs
                        06-27-2025, 11:26 AM
                      • defdjamel
                        internal short cut - 820-02935 -A2992 - macbook pro 16" m3 max
                        by defdjamel
                        820-02935 - a2992 - macbook pro 16" m3 max
                        Laptop: 5V - 0A
                        Issue: PPBUS_AON_SPKRAMP_ABC and PPBUS_AON shorted.
                        • On PPBUS_AON_SPKRAMP_ABC, capacitor CR635 was damaged (melted) and created an internal short circuit to ground.
                        • I removed faulty components (CR635, CR634, CR633) and also chip UR630.
                        • Result:
                          • PPBUS_AON_SPKRAMP_ABC → still shorted
                          • PPBUS_AON → still shorted
                        When I inject 3 V / 1 A on PPBUS_AON_SPKRAMP_ABC, heating occurs on pad CR635.
                        I suspect that during the failure, the pad and line PPBUS_AON_SPKRAMP_ABC melted into ground( i try to...
                        09-20-2025, 06:16 AM
