dell lattitude 5310 2 in1 , short on 3d3v_S5
  • adin
    • Aug 2021
    • 39
    • australia
    Who suggested you to inject 8V? I advised to inject 1V
    i only had a 9v battery so i used that , i dont have a voltage injection.
    • adin
      • Aug 2021
      • 39
      • australia
      Originally posted by Sephir0th
      The main issue here right now is that you did not read what was repeatedly advised and even worse you formed wrong conclusions caused by lack of experience. Example: A quick look at the actual physical location of Pin17 would have clarified instantly that it is tied to Pin16 by design. And from where the hell originated the idea to inject 8V into a power rail which is supposed to run with 3.3V max?
      Now you likely don't deal with only a dead EC but also with a lot more dead components..
      im using an 18723-1 schematic it about same as mine which is 19752-1 but the chips on there are the same on both motherboards. i think the ec was dead and is the short ? laptop no power no led dead , is ec fault ?
      • adin
        • Aug 2021
        • 39
        • australia
        the ec is heating up quick, i didnt inject into the pin 17ldo because i have 8v , but injecting into capacitor is safe ?
        • adin
          • Aug 2021
          • 39
          • australia
          i inject it into the capactiroe on the 3d3v_s5 line circuit, and ec is heating up real quick
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I think with 8V injected on a 3.3V rail, the mb is very likely beyond repair . Not only EC, PCH is also likely fried.
            • Sephir0th
              • Oct 2020
              • 1283
              When you don't have the right tools amd not able to follow clear advise, you can't approach such a repair attempt successfully. Now you have very likely fried a board which was repairable before and now is probably not anymore. Hopefully it is not a customer from you who has now to deal with the consequences.
              Share resistance to GND of 3D3V_S5 please.
              FairRepair on YouTube
              • adin
                • Aug 2021
                • 39
                • australia
                #27
                its my own board , the cpu core inductore were already shorted, is sio and cpu short on same circuit?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  Cpu core inductors resistance to GND will show very low values like 3-6 ohms and its normal. It seems you are making conclusions in a haphazard manner without grasping the technicalities involved-perhaps 'coz of lack of experience.That's why i dont like the idea of a non technical person attempting a sophisticated repair and blowing things away.Its always better to seek help from an expert in the field and most often it turns out cheaper then the expensive damage.
                  What i've stated is a general observation and in no way under estimates your capability (honestly i dont even know about your technical understandings).
                  • adin
                    • Aug 2021
                    • 39
                    • australia
                    #29
                    3d3v_S5 is reading 4.5ohm on resistor near EC
                    • adin
                      • Aug 2021
                      • 39
                      • australia
                      #30
                      continuity shows the row of inductors are short ? or is this normal?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #31
                        You cant check cpu coils on diode mode.It'll always buzz. Set your meter to ohms lowest scale(say 200),short your meter probe,note the resistance between probes and then put black probe to GND,red on coil. What's the reading on coil and reading when you shorted the probes.
                        As stated earlier, cpu coils will show very low resistance and thats normal.
                        • adin
                          • Aug 2021
                          • 39
                          • australia
                          #32
                          so do i have a short to ground on the 3d3v_s5 ? or is it IC EC
                          • adin
                            • Aug 2021
                            • 39
                            • australia
                            #33
                            should i still get psid and 3valw and 5valw , if cpu is dead?
                            • adin
                              • Aug 2021
                              • 39
                              • australia
                              #34
                              2 (PSID_DISABLE#_R_C) - 0V
                              3 (PSID) - 0.490mV​
                              • adin
                                • Aug 2021
                                • 39
                                • australia
                                #35
                                coil from top to bottom in the pic
                                3.9ohm
                                3.9ohm
                                3.9ohm
                                5.9ohm
                                shorting probes is .7 ohm
                                device qm1321
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #36
                                  So that proves there is no short on cpu coil. However, since you injected 8V on a 3.3V rail, your PCH is very very likely fried.
                                  • adin
                                    • Aug 2021
                                    • 39
                                    • australia
                                    #37
                                    so replace the cpu i7 whiskeylake willl repair the problem?
                                    • adin
                                      • Aug 2021
                                      • 39
                                      • australia
                                      #38
                                      is there a way to check pch short without voltage injection ?
                                        DELL Inspiron 5310 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Inspiron 5310 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5310 boardview and 5310 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5310...
                                        09-07-2024, 02:00 AM
                                        09-07-2024, 01:00 AM
