MACBOOK PRO 820-02020 STUCK AT 5V
  • phantomEVO
    • Mar 2013
    • 488
    hi to all, please help.
    motherboard is perfect, no signs of corrosion or anything else.
    both usb ports stays at 5v@0,04/0,05amps
    PP3V3_UPC0/1_LDO & PP1V5_UPC0/1_LDO presents
    PPBUS_AON 12.28v
    PP3v8_AON 3.8v
    PP3v3_S2 "bootloop" 2,8/3,0/3,1
    PP1V8_S2 0V
    PP5v_S2 0v
    PP1v25_S2 0V
    any hints? thanks​
  • mon2
    • 14355
    Check the voltage to ground of each ldo rail on each cd321x ace controller.
    remove all power and measure the resistance to ground of:
    • phantomEVO
      • Mar 2013
      • 488
      In diode mode, i have 0,400 on PP3V3_UPC0/1_LDO & PP1V5_UPC0/1_LDO
      no problem on PP3V3_UPC0/1_LDO and USBC0/1_3V3LDO_EN
      PP3v3_S2 is 3,2kohm 0,300mv
      • phantomEVO
        • Mar 2013
        • 488
        i0ve check some voltage arounf u8100 PP3V8_AON_MPMU_ISNS_VIN 3,8v
        PP1V2_S2 0v
        PP3V3_S2_UPC floating 3v/2,5/1,6/0
        PP1V8_AON_MPMU 1,7
        PP1V5_VLDOINT_MPMU 1,5​
        • mon2
          • 14355
          Check the resistance to ground of PP1V2_S2.
          • phantomEVO
            • Mar 2013
            • 488
            2,9k
            • phantomEVO
              • Mar 2013
              • 488
              i've done a mistake: 1,2 is present but floating like 3,3s2
              • Bmet
                MacBook Pro 13 inch A2238 M2 stuck on 5V
                by Bmet
                I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                04-02-2025, 05:02 PM
              • Steven Pieter
                Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                by Steven Pieter
                hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                11-24-2024, 10:02 AM
              • Clarify4082
                Macbook Air 2018 A1932 Bootloop
                by Clarify4082
                I have a A1932 Macbook Air with Bootloop.
                I already replaced the battery with a new one and reset NVRAM and SNC.
                When I start the Macbook the Screen is coming on (no Logo) and switches of after a few seconds. If I start without the trackpad and keyboard it stays on longer.
                If I use diagnostic (Option+D), recovery (Option+R) I always get the Apple logo and it go into online-Recovery. Even if I boot the installer from a USB-stick it ends up in online-recovery. Sometimes it crashed short after entering the wifi password, sometimes it loads the recovery...
                01-07-2025, 09:41 AM
              • DATATECH85
                Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                by DATATECH85
                I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                Here are the values...
                07-24-2024, 06:34 AM
              • martyjelen
                Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
                by martyjelen
                Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
                PP3v3_G3H_RTC_X is present - 3,3V
                PP3v3_G3H_SOCPMU is present - 3,3V
                ​What else should I check?
                Thank you for your help.
                05-05-2025, 01:34 AM
