Blown Inductor - HP Envy 17 - J184NA
  • mon2
    • Dec 2019
    • 14634
    Right - shared my local Canadian version of the Mouser links. They are in Texas but ship worldwide. You could probably also source the same from RS Electronics in the UK or pick some up from @SMDFlea's house
    • pjzz2000
      Phil_2000
      • Jan 2024
      • 24
      • United Kingdom
      Damn, if @SMDFlea's house is anywhere near London, that might have worked out a lot cheaper!
      Oh well, it's my first interest and attempt at a motherboard diag and fix and the board is of high sentimental value (believe it or not 🙂), so I'll just have to take the hit as an investment £££££££.
      Really appreciate your, and everybody else's help.
      • pjzz2000
        Phil_2000
        • Jan 2024
        • 24
        • United Kingdom
        Latest update: I found soldering the inductor with pads underneath the body and no side contacts difficult and never confident that I had not bridged underneath.
        Bought similar spec inductors with side contacts and I think they are soldered ok this time.
        No short either side, as before. Not surprisingly, symptoms remain the same. But I've gathered more diagnostics:
        Symptom: charger light on, power button light on, doesn't boot to BIOS
        Diags:
        1. 19.5V rail present all over as input to all other power rails
        2.. With charger connected (no battery), 3.3V and 5V present at respective co-located inductors, but after about 20s disappear. Weirdly 3.nV present at various locations, including BIOS and around SIO and power button. Where is that power coming from?
        3. When short power button pins, power led lights and says lit
        4. Only other sign of action, a 1s flicker of CPU fan
        5. After that, no progress. If I short the power button again, the fan kind of high-pitched buzz like it wants to turn but in sufficient power. It has Something like 1.7v on the + connector
        6. With power LED on, the 3.3V, and 5V inductors are reinstated and steady
        7. Lots of 3.nV and lower present around and directly below the PCH,
        8. CPU is cold, like it has done nothing, or next to nothing, which makes sense as no power to them through the various CPU neighbouring Inductors.
        So, any thoughts on my theories, or any other ideas?
        a) SIO and/or PCH fails to "read" BIOS so don't bother turning on the CPU rail power rail(s), in order to initiate POST.
        b) CPU power rails dead for some other reasons (have not felt any heat around that area)
        c) CPU dead (or other chips dead)
        I have not been tempted yet to try re-flashing the BIOS chip yet because of the way the priblem developed at the beginning: i got the problem sporadically, then it died for a significant time, then it booted to BIOS a few intermittent times. It felt more like a solder joint problem, working sometimes at different temperatures. Not sure how BIOS could have been corrupted and then fine again, then corrupted, then fine.
        So Im pretty stuck on what to do next. Im a beginner but learning a lot and determined!!: Any help much appreciated!
          HP ENVY ENVY Desktop - 750-510 ENVY 750 i5-7400 Specification for Upgrade or Repair
          This specification for the HP ENVY ENVY Desktop - 750-510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-510 boardview and ENVY ENVY Desktop - 750-510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-12-2024, 03:44 PM
          HP ENVY ENVY Desktop - 750-524 ENVY 750 i7-7700 Specification for Upgrade or Repair
          This specification for the HP ENVY ENVY Desktop - 750-524 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-524 boardview and ENVY ENVY Desktop - 750-524 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        • swerg
          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
          by swerg
          Hey everyone,
          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
          06-06-2024, 03:39 PM
        • silver60618
          Blown Inductor on WD My Passport
          by silver60618
          Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
          Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
          Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
          Lastly am I correct in thinking there is no polarity on the smd component?
          Thanks!...
          04-05-2024, 09:54 AM
          HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
          This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
          09-06-2024, 12:18 PM
