Blown Inductor - HP Envy 17 - J184NA
  • pjzz2000
    Phil_2000
    • Jan 2024
    • 24
    • United Kingdom
    Hi
    Totally new to this website/forum, so apologies if not the appropriate place to ask, but.....
    I'm trying to diagnose my son's laptop motherboard.
    Power jack led on, power button led on, but I think post fails. CPU cold and no voltage around CPU graphics card.
    I start to suspect power rails, or PCH or CPU.
    I did a close visual check and find an inductor that looks in a sorry state, next to what I think might be the PCH. I can only see 2R2 I (or L), but from reading, this is not enough to identify the various specs required to get a like requirement.
    I have no board schematic or board view.
    Can anybody help with what to look for? I don't want to blow up the PCH, CPU and/or graphics card by guessing!
  • pjzz2000
    Phil_2000
    • Jan 2024
    • 24
    • United Kingdom
ID:	3206134 Location of PCH and bad inductor
      • 22264
      Post the motherboard model number
      https://www.badcaps.net/forum/troubl...r-s-guidelines
      1.1.3 Motherboard model number
      • pjzz2000
        Phil_2000
        • Jan 2024
        • 24
        • United Kingdom
        Wider view Click image for larger version
        Not the bad board, I lost the photo. But this is the same location on the actual board
        • pjzz2000
          Phil_2000
          • Jan 2024
          • 24
          • United Kingdom
          I believe the bad board with bad inductor is:
          For HP ENVY 17 - J184na
          SPS 720266-501
            • 22264
            SPS 720266-501
            Inventec 17SBGV2D 6050A2549801​ ,there`s no schematic available. The inductor is 2.2uH ,desolder it completely or on one side and lift it so the its not touching the pad, then measure the exact resistance to ground on both pads and post your results
            • pjzz2000
              Phil_2000
              • Jan 2024
              • 24
              • United Kingdom
              Thanks very much. Tried with an old soldering iron and it didnt go very well. Will need to get proper equipment, so will respond as soon as possible.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Usually an inductor blows when there is excessive current draw.Follow smdflea's advice and remove the inductor. However, I'm afraid that very likely you'll find a short to Ground on the PCH side of inductor.If so,Then PCH has to be replaced and there may be even more damaged components. But first the resistance to GND readings on both pads of the blown inductor(after removal of inductor,no power attached).
                • pjzz2000
                  Phil_2000
                  • Jan 2024
                  • 24
                  • United Kingdom
                  Thank you so much.
                  This is going to take time; limited soldering skills and no proper equipment, yet.
                  I'll be back!
                  • mon2
                    • Dec 2019
                    • 14837
                    To me, the inductor does not appear to be defective. The broken corner looks like the shield casing was chipped from a physical drop of a tool or similar event. Inductors are available in shielded and non-shielded variations. This is a shielded version.
                    remove all power. Meter in resistance mode. Measure the resistance across this inductor. It should be close to 0hms.
                    measure the resistance to ground to check if the power rail is shorted or not.
                    • pjzz2000
                      Phil_2000
                      • Jan 2024
                      • 24
                      • United Kingdom
                      Interesting, thank you.It's easy to jump to conclusions!
                      I guess the reason I suspected this one particularly, was not only that it looked sick but also that I thought it could be shorting to ground before PCH which may be preventing power or any signals to CPU to do anything.
                      Total guess, but sounded logical. I dont know WHEN we should expect to see voltage at all the inductors near the CpU, graphics, PCH.
                      The now "bad" inductor is hanging half off the mobo pending some better soldering equipment. I may have bridged the two pads in attempt to desolder, so will wait to get it off clean and then take the measurements.
                      I had checked resistance across all these inductors around the processors and pch and they were all 0v.
                      I also checked them all for resistance and all around 0.06ohms, which I gather is good (which maybe confirms what you suggest).
                      I'll get back to you again on once I've tidied up!
                      Thanks loads for your interest and help.
                      • pjzz2000
                        Phil_2000
                        • Jan 2024
                        • 24
                        • United Kingdom
                        Miraculously, the board looks like it might have survived.
                        I tries taking some measurements from the two sidea of the inductor, after removal.
                        In resistance mode, hardly anything useful; stays at "1", on both sides to ground, which i think is "out of range", or open loop?
                        I tried in diode mode to ground, left pad "554", right pad, "1".
                        Any ideas?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          The resistance is high enough. proceed to solder the rated inductor.
                          • pjzz2000
                            Phil_2000
                            • Jan 2024
                            • 24
                            • United Kingdom
                            Problem is, the inductor looked broken which is what drew my attention to it, among other things.
                            And it got broken further in my desoldering, so I need to replace it.
                            I read somewhere that a 2R2 L can have different specifications, such as amps and, as there are no product markings and no schematic I have no idea what to buy.
                            it is very close to the PCH, so does that give any clue?
                            thanks
                            • mon2
                              • Dec 2019
                              • 14837
                              Share the physical size of this inductor. We know with 2R2 = 2.2 uH. We have found that brands like Bourns / Pulse and a few others offer higher current rated parts than offshore companies. Do also measure the height of the part. Then can go on the hunt for a suitable device. The inductor will have a normal operating current rating and then a saturated current rating. At the saturated point, the current will heat up so will be an increase in temp over ambient. We do not want this logic board to become an air fryer so best to find the highest rated device for the physical footprint.
                              • pjzz2000
                                Phil_2000
                                • Jan 2024
                                • 24
                                • United Kingdom
                                Thank you, I'll get on to it tomorrow.
                                • pjzz2000
                                  Phil_2000
                                  • Jan 2024
                                  • 24
                                  • United Kingdom
                                  The measurements seem to be around:
                                  4.6mm x 4mm x 1.5mm
                                  I tried, ac adaptor connected and shorting power button pins.
                                  Now that the inductor is off the board, the behaviour has changed a little:
                                  Original problem: ac adapter led on and power button led on, a 0.5 second spin of fan, then nothing else, just frozen
                                  With damaged inductor adjacent to PCH off the board, the fan now spins for 2 seconds, noticibly longer, followed by repetition in loop every 3 seconds.
                                  If you know how to find a suitable 2r2 inductor with a reasonable current rating, that would be very helpful.
                                  Many thanks
                                  • mon2
                                    • Dec 2019
                                    • 14837
                                    The inductor is required to complete the DC-DC switching regulator (BUCK mode) design. Without it, this power rail will be off.
                                    The following should be suitable (just a bit taller) - do confirm if the height is acceptable to your enclosure.
                                    SRP4020FA-2R2M Bourns Inc. | Inductors, Coils, Chokes | DigiKey
                                    • pjzz2000
                                      Phil_2000
                                      • Jan 2024
                                      • 24
                                      • United Kingdom
                                      I think that will fit fine, thanks
                                      • pjzz2000
                                        Phil_2000
                                        • Jan 2024
                                        • 24
                                        • United Kingdom
                                        Just tried to order a few but looks like they only deliver to Canada.
                                        I'm in: London, United Kingdom
                                        Update: have managed to order same from a UK importer, mouser.co.uk
                                          HP ENVY ENVY Desktop - 750-510 ENVY 750 i5-7400 Specification for Upgrade or Repair
                                          This specification for the HP ENVY ENVY Desktop - 750-510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-510 boardview and ENVY ENVY Desktop - 750-510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:44 PM
                                          HP ENVY ENVY Desktop - 750-524 ENVY 750 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP ENVY ENVY Desktop - 750-524 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-524 boardview and ENVY ENVY Desktop - 750-524 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        • swerg
                                          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                          by swerg
                                          Hey everyone,
                                          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                          06-06-2024, 03:39 PM
                                        • w00pz
                                          Identify blown component on HP ENVY X360 13-arxxxxx, Motherboard G1 13 AMD X360 18740-1 448.0GA03.0011
                                          by w00pz
                                          I have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
                                          Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
                                          I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
                                          Hope someone will be able to identify the component.
                                          Many thanks for your help!
                                          Edit: High-res picture added on a normal board (not mine)...
                                          11-08-2025, 02:48 PM
                                        • silver60618
                                          Blown Inductor on WD My Passport
                                          by silver60618
                                          Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
                                          Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
                                          Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
                                          Lastly am I correct in thinking there is no polarity on the smd component?
                                          Thanks!...
                                          04-05-2024, 09:54 AM
