Latitude 7330 motherboard photo near the bios chip
  • trepachka
    • Oct 2022
    • 414
    Hi, while desoldering the bios chip, I accidently knocked off 2 components: a resistor and a capacitor. I am trying to figure out their position. I didn't take the picture prior to this, my bad.
    Could someone, please post a close-up photo of the bios chip, in particular the area where "DC1" and "UC2" are printed on it? There is a capacitor and a resistor there I am trying to find their original position on the motherboard.
    Thanks.
  • djtaotao
    • Nov 2023
    • 22
    • Sweden
    I'm working now on my 7430 - LA-L581P, can you please check if it is the same MB, maybe I can help you?
    • trepachka
      • Oct 2022
      • 414
      Yes, it is the same motherboard. If you could take a close-up photo of the area, in particular the side where "DC1" and "UC2" are printed next to the bios chip, that would help me a lot.
      • djtaotao
        • Nov 2023
        • 22
        • Sweden
        I hope this helps.
        • trepachka
          • Oct 2022
          • 414
          Thank you. Can you post a close-up bird's view of the first photo? Namely, positioning of the capacitor and the resistor just below the bios chip
          • djtaotao
            • Nov 2023
            • 22
            • Sweden
            • trepachka
              • Oct 2022
              • 414
              Hey, sorry. You have a close-up of the other bios chip. I am mostly interested in the area where "DC1" is printed. You can actually see the resistor and the capacitor over there. From the picture it's not clear which one is which. Also, that capacitor has "+" and "-". I need to know which way to solder it.
              Could you, please take a more detail photo of just that area? Thank you kindly.
              • djtaotao
                • Nov 2023
                • 22
                • Sweden
                There are a resistor and a diode to the right of DC1.
                • trepachka
                  • Oct 2022
                  • 414
                  Yes, that's it. Thank you.
                  • djtaotao
                    • Nov 2023
                    • 22
                    • Sweden
                    I'm happy if I helped you.
                    Now if you can help me I'll be even happier.
                    Can you please measure for me the voltage of main power rail on PC715, PJ100 or PJP202 with charger conected but with and then without battery connected?
                    • trepachka
                      • Oct 2022
                      • 414
                      I should resume working on this laptop this weekend. Can you take photos of the location of each of these components and I would be happy to take measurements for you?
                      • djtaotao
                        • Nov 2023
                        • 22
                        • Sweden
                        All those points should be the main power rail.
                        • trepachka
                          • Oct 2022
                          • 414
                          Voltage measurements taken @ PC715:
                          8.5V => Charger is on, battery is off
                          16V => Charger is on, battery is on @ 15% charge. This voltage keeps rising a little as the battery is getting more charged.
                          If you need me to take other measurements, let me know since computer is currently sitting disassembled.
                          • djtaotao
                            • Nov 2023
                            • 22
                            • Sweden
                            I have almost the same voltages except the fact that the battery is not charging, without battery I have +8.6V and with the battery on I have constant +17.2V. Of course the laptop is not powering on and this is my first laptop I'm trying to repair .
                            The charger is negotiating the voltage and the USB meter shows 19.98V and 0.08A so definitely is not charging. The led on the power button light up and stays on for 30s, turns off for 1s and turns on again for 30s and so on.
                            I have 3.3V and 5V present. I don't know who's the suspect.
                            Can you measure the following coils please?
                            PL201 to GND
                            PL501 to GND
                            PL602 to GND
                            PL603 to GND
                            PL604 to GND
                            • trepachka
                              • Oct 2022
                              • 414
                              Ok, I will take the measurements later today.
                              • trepachka
                                • Oct 2022
                                • 414
                                I get the following:
                                PL100 780 Ohms
                                PL201 45 Ohms
                                PL101 10.5K Ohms
                                PL604 125 Ohms
                                I think PL602 and PL603 are obscured by the heatsink and these two are on the side of the CPU. They measure 80 ohms which is what to be expected.
                                • djtaotao
                                  • Nov 2023
                                  • 22
                                  • Sweden
                                  Thanks!
                                  I got different measurements, maybe you have a different processor & ram. I have an i7 + 16 GB of ram.
                                  PL602+PL603 = 12.2 ohms
                                  PL201=32ohms
                                  PL604=21.7ohms
                                  PL501=163ohms
                                  • trepachka
                                    • Oct 2022
                                    • 414
                                    Is your computer running on just battery? In case the battery is down to 0%, do you have a voltage injection tool to charge the battery a little bit? Because if the computer runs on battery, then the charging circuit is definitely the culprit.
                                    I am concerned about PL602+PL603 resistance. 12.2 ohms is somewhat low. I am ok with 40+ ohms. This is just too low. But if computer runs on battery, then I take it back.
                                    Check the battery charging chip pins. One of the pins, REGN I think, is supposed to show 6V. That's a good indicator the chip may be Ok.
                                    • djtaotao
                                      • Nov 2023
                                      • 22
                                      • Sweden
                                      The battery is charged, it has around 16.2V. I tried to inject some voltage on it but it takes no current.
                                      The laptop has this behaviour, is not running and is not charging. I already changed the charging IC which is ISL9538 and the double mosfets PQ700 and PQ701. I don't know where to check the REGN signal on ISL9538.
                                      The schematic is almost the same as the one attached.
                                      • trepachka
                                        • Oct 2022
                                        • 414
                                        Since you have already changed the charging IC, I am just going to assume it's still good. Do you get any power rails, in particular 5V and 3.3V? Are they present?
                                        PU102 is responsible for generating 5V power rail.
                                        PU100 is responsible for generating 3.3V power rail.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          by SMDFlea
                                          Bad...
                                          09-02-2021, 04:40 PM
                                        • AJ847.63e
                                          Latitude 5521 - broadmoor 15 TGL-H 12L 5v 600ma can anyone identify this chip?
                                          by AJ847.63e
                                          got a latitude off of a old colleague which is stuck at 5v and not turning on no signs of life.
                                          ive done some digging and it seems like pu4501 (5193 ti 1a8 adgh is the chip markings) is shorted. Getting up to around 74c. Haven't removed it yet because i haven't been able to confirm what chip it is.
                                          Googling the markings brought up only one result, tps 51396 but the markings are 51393 so I'm assuming it's a tps51393 but googling that it seems like the chip engravings are different to the one I have so I wanted to confirm whether my assumption was right...
                                          07-02-2024, 06:41 PM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • chaos_prevails
                                          Dell Latitude E7470 i7: no TPM + TXT in BIOS/Firmware (but chip is present on the motherboard)
                                          by chaos_prevails
                                          I've purchased 2nd hand Dell Latitude E7470 i7-6600U and it works fine, except ... there are no TPM or TXT/Trusted Execution settings in the BIOS/Firmware. However, looking at the schematics I found the chip handling TPM (NPCT650JA0YX) soldered to the system board. Also, looking at the service tag and the product specifications, this device comes with TPM (and vPro) support (I know that devices sold in China, Russia are not allowed to ship with TPM but this should be reflected in the service tag). I can also login to MBex to configure, etc.
                                          In the produce specs...
                                          02-12-2024, 05:21 AM
