ASUS TUF FX516PM - no power
  • Gigabyte_PL
    • Dec 2021
    • 36
    • Poland
    mon2 I'm counting on your help šŸ™„ā€‹
    • mon2
      • Dec 2019
      • 14672
      The pull-up voltage for the smbus lines is linked to a local load switch from uPi with part number uP9030. This load switch requires the main power rail which is absent so back to the basics. Trace the dcin mosfets.
      remove all power. Meter in resistance mode.
      check resistance of:
      source & drain
      source & gate
      gate & drain
      post each measurement. Repeat for the 2nd dcin mosfet.
      • Gigabyte_PL
        • Dec 2021
        • 36
        • Poland
        tHello mon2 ,
        I again test it:
        First mosfet:
        source & drain - 5,18M ohm
        source & gate - 3,17M ohm
        gate & drain - 4,83M ohm
        Second mosfet:
        source & drain - 5,28M ohm
        source & gate - 4,70M ohm
        gate & drain - 7M ohm
        Additionally, last time I replaced the first and second mosfet, but there was no change. I tested the original mosfet and all the resistance and test diode were fine.
        I checked motherboard with a thermal imaging camera and only one element that lights up is PR9024. I checked its resistance in circuit and it is 13.7K ohm (that is, as much as in diagram).​
        • mon2
          • Dec 2019
          • 14672
          Flux and carefully remove PR8918 = ~4k ohm resistor which is in series with the ACDRV pin on the charger IC. Do not lose this part.
          Then power up and check the voltage to ground of the ACDRV pin # 4. Measure it carefully. What is the voltage to ground now?
          • Gigabyte_PL
            • Dec 2021
            • 36
            • Poland
            After remove PR8918
            ACDRV - 0,17V #4
            Source and gate on first mosfet - 0,07V
            I checked resistance of PC8916 and its value is 4.65 M ohms (measurement in circuit)
            • mon2
              • Dec 2019
              • 14672
              Consider to replace the charger ic. Be sure the replacement is the same as the original. Purchase a few spares.
              • Gigabyte_PL
                • Dec 2021
                • 36
                • Poland
                #27
                Ok, I will buy new charger IC. I belivie BQ24800RUYT it's same that BQ24800RUYR? I checked and I saw different information in the packaging. Can you confirm ? Thanks.
                • mon2
                  • Dec 2019
                  • 14672
                  Yes, they are the same. They only vary in the shipped quantity on a reel. That is 250pcs vs 3000pcs.
                  we use suhms on AliExpress but you should be able to receive as a free sample from the ti.com website.
                  • Gigabyte_PL
                    • Dec 2021
                    • 36
                    • Poland
                    #29
                    I bought a BQ24 yesterday and replaced it now. The same situation - on the measuring resistor 4V.
                    Maybe new chip is damaged...​
                    • mon2
                      • Dec 2019
                      • 14672
                      Confirm the soldering.
                      carefully measure on this charger ic - each pin’s voltage to ground. Post each measurement.
                      • Gigabyte_PL
                        • Dec 2021
                        • 36
                        • Poland
                        #31
                        After soldering, I checked all pins and everything looks good.
                        I checked again by measuring BQ24:
                        CHG_ACN - 4,15v
                        CHG_ACP - 4,15V
                        CHG_CMSRC - 0,7v UP T0 1,10V
                        CHG_ACDRV - 0,85V UP TO 1,4V
                        CHG_ACOK - 0,002V UP TO 0,05V
                        CHG_ACDET - 2,64V
                        CHG_IADP - 0,03V
                        CHG_SDA - 0,57V UP TP 0,9V
                        CHG_SCL - 0,56V UP TO 0,9V
                        CHG_ILIM - 0,02V UP TO 0,14V
                        CHG_LG - 0V
                        CHG_REGN - 6V
                        CHG_HG - 0,22V
                        CHG_LX - 0,22V
                        CHG_VCC - 19V
                        when I turn on power supply from the service power supply, consumption of 0.08A appears every now and then and drops to 0 and so on.​
                        • mon2
                          • Dec 2019
                          • 14672
                          These measurements were with both the battery and power adapter attached?
                          • Gigabyte_PL
                            • Dec 2021
                            • 36
                            • Poland
                            #33
                            I connected service power supply without a battery. I don't have the original power supply
                            • mon2
                              • Dec 2019
                              • 14672
                              Trace these pins using board view file:
                              CHG_ACN - 4,15v
                              CHG_ACP - 4,15V​
                              these signals are after the dcin mosfets which are off yet you have a voltage on each. Be sure the soldering is ok. Best to review the voltage to ground on each of the dcin mosfets again.
                              source
                              gate
                              drain
                              without the high gate voltage to enable the mosfets, the referenced pins should be at 0 volts since the battery is not connected.
                              • Gigabyte_PL
                                • Dec 2021
                                • 36
                                • Poland
                                #35
                                Mosfet #1
                                source 0,02V up to 0,8V (up and down - it's unstable)
                                gate 0,02V up to 0,8V (up and down - it's unstable)
                                drain 19V
                                Mosfet #2
                                drain 4,10-4,20V ​
                                • mon2
                                  • Dec 2019
                                  • 14672
                                  Can you confirm that the mosfet pins being measured are:
                                  source (1-2-3) ; any will be ok
                                  gate (4)
                                  drain (5-6-7-8) ; any will be ok
                                  • mon2
                                    • Dec 2019
                                    • 14672
                                    Do confirm that the DCin mosfets you are measuring are located @ PQ8901 and PQ8902. Interested in the voltage to ground of each pin on these parts.
                                    • Gigabyte_PL
                                      • Dec 2021
                                      • 36
                                      • Poland
                                      #38
                                      Yes, I confirm.
                                      Check attached files.
                                      • mon2
                                        • Dec 2019
                                        • 14672
                                        In tracing the current sense resistor appears to be from the drain pins on PQ8902.
                                        Can you confirm the following measurements?
                                        CHG_ACN - 4,15v
                                        CHG_ACP - 4,15V​
                                        • Gigabyte_PL
                                          • Dec 2021
                                          • 36
                                          • Poland
                                          #40
                                          Please check attached files.
                                            ASUS TUF Dash FX516PM-HN023W Notebook F15 Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Dash FX516PM-HN023W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN023W boardview and FX516PM-HN023W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 04:30 AM
                                            ASUS TUF Dash FX516PM-HN072T Notebook F15 Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Dash FX516PM-HN072T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN072T boardview and FX516PM-HN072T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 03:10 AM
                                            ASUS TUF Dash FX516PM-HN010T Notebook F15 Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Dash FX516PM-HN010T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN010T boardview and FX516PM-HN010T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 02:00 AM
                                            ASUS TUF Dash FX516PM-HN023T Notebook F15 Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Dash FX516PM-HN023T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN023T boardview and FX516PM-HN023T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 01:30 AM
                                            ASUS TUF Dash FX516PM-HN023 Notebook F15 Specification for Upgrade or Repair
                                            This specification for the ASUS TUF Dash FX516PM-HN023 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN023 boardview and FX516PM-HN023 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
