ASUS TUF FX516PM - no power
  • Gigabyte_PL
    • Dec 2021
    • 36
    • Poland
    Hi Everyone,
    I have problem with ASUS TUF FX516PM-HN023T. I checked all resistances on coil and all looks fine. I checked motherboard a microscope and I didn't see anything disturbing.
    When I soldered the plus and ground to the input plug, I noticed that on the first mosfet there was 19V at the input but behind it there was 0.020V
    the second mosfet has 0.020V at the input and 4V at the output.
    The main measuring resistor at the input is 4V.
    When I soldered the measuring resistor, I saw that power was supplied to the 3 and 5V coil for a moment and then disappeared. The power supply consumption when the coils are powered is 0.100A
    Using thermal imaging, I can see that the point that will only light up is the main 3/5V converter.
    Does anyone have an idea?
    Thank you.
    [Mod. Edit] Boardview (pdf) -> https://www.badcaps.net/forum/troubl...r-asus-fx516pc
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/showthread.php?t=117483
    Last edited by Vesko356; 01-18-2024, 03:17 AM. Reason: Attached BV removed and replaced with link
  • mon2
    • 14664
    Review the above sticky post about charger circuits by piernov.
    measure the voltage to ground of the gate pin #4 on the first 2 dcin mosfets. Share the topside markings of these dcin mosfets and also the charger ic that should be nearby. The dcin mosfets are driven by the charger ic. If the mosfets are n-channel type then the gate pin voltage must be higher than the voltage on source / drain pins to enable and typically ~ 25v.
    • Gigabyte_PL
      • Dec 2021
      • 36
      • Poland
      First mosfet it is: PKCH2BB
      Second mosfet it is: QM3058M6AC
      PWM CONTROLLER it is: SN51285ARUKR
      Battery charger it is: ISL9238BHRTZ-T
      1 mosfet
      ​Drain on first mosfet: 19V
      Source and gate - 0,02V up to 0,65V
      2 mosfet
      Drain 0,02V up to 0,65V
      Source and gate ~4V
      pin #4 on first and second mosfet have 0,02V up to 0,65V
      pin #4 on first and second mosfet have 7,3M ohm resistance to ground
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You need to measure resistance of dc in mosfets between
        01.Source-Gate
        02.Source-Drain
        03.Gate-Drain
        Meter in 200K scale or more. Post the readings.
        • Gigabyte_PL
          • Dec 2021
          • 36
          • Poland
          1 mosfet
          01.Source-Gate 4,7M ohm
          02.Source-Drain 4,94M ohm
          03.Gate-Drain 7,41M ohm
          2 mosfet
          01.Source-Gate 3,16M ohm
          02.Source-Drain 2,10M ohm
          03.Gate-Drain 6,89M ohm​
          • mon2
            • 14664
            With these high resistance readings, the mosfets are not shorted. Yet the mosfets are not being enabled. The charger IC is responsible to enable these mosfets. The next suggestion is to carefully (very carefully) measure the voltage to ground of each pin on the charger IC. This part appears to be in the witness protection program by Intersil (Renesas?) so we will have to hunt down the gory details from other schematics.
            The points of interest are:
            1) Is the charger IC being powered? Vcc voltage to ground.
            2) What is the voltage of the ACOK pin? It should be a logic '1' to denote that the adapter is deemed to be ok?
            3) The DCIN mosfets onboard are N-channel type. Respectively, the GATE voltage on each of these mosfets should be higher than the source/drain voltages. The gate voltage should be ~25 volts to enable. This boosted voltage should be supplied by the charger IC through the ACDRV pin. The operation of this charger IC is similar to that from Texas Instruments (BQ series).
            For now, you can use the boardview file for this Asus to locate each pin # and post the measurements. Often there will be a 3 legged (dual common cathode diode) used to power this IC. One leg is from the power adapter as the input; other pin is from the battery. This dual diode is used to power the IC by the adapter or the battery; either can power the charger IC. It is possible this dual diode is defective. Power a clear top side pic of this area to study from.
            • Gigabyte_PL
              • Dec 2021
              • 36
              • Poland
              ISL9238BHRTZ
              P_CH32_ACOK_10 - 0,0046V
              P_CHG2_CSOP_5 - 0,23V
              SMB3_CLK_R_10 - 0,70V
              SMB3_DAT_R_10 - 0,70V
              P_CHG2_DCIN_20 - 0,04V
              P_CHG2_PROCHOT# - 0,57v
              P_CHG2_VBATSENSE - 0,23v
              P_CHG2_HG1- 0,017V
              CHG2_BOO1 - 0,023V
              CHG2_HG2 - 0,30V
              N-MOSFET PJX138K
              CHG2_ACOK_10 -0v
              CHG2_ACOK# - 0,05 -UP TO 0,27V
              BQ24800RUYR
              P_CHG_ACDRV_20 - 0,020V up to 0,65V (the same value as on drain on first mosfet)
              P_CH32_ACOK_10 - 0,0022V up to 0,03V
              CHG_SDA_5 -
              CHG_SCL_5 - 0,60V-0,70V
              CHG_CMPIN_10 -0,27V
              CHG_CMPOUT_0,60-0,70V
              CHG_BATSRC_20- 0,24v
              CHG_BATDRV_20 - 0,27V
              CHG_SRN - 0,27V
              CHG_SRP - 0,27V
              CHG_ILM - 0,15v
              CHG_VCC - 19V
              CHG_BST - 0,60V
              CHG_BST - 0,23V
              CHG_HG -0,23V
              CHG_LG - 0,80V UP TO 1,30V
              CHG_REGN - 0,60V
              CHG_ACN - 4V
              CHG_ACP - 4V
              CHG_CMSRC -0,60 UP TO 0,75V
              CHG_ACDRV - 4V
              CHG_IADP - 0,27V
              CHG_ACDET - 2,56V
              DIODE BAV99W SOT-323
              P_CHG_ACDET_R_10 - 4,16V
              AC_BAT_SYS - 2,58V
              P_AC_SHORT_PRO_10 - 4,70V​
              • mon2
                • 14664
                Is the BQ24800RUYR also onboard your logic board? Where is it on the boardview file? PU**** ?
                NM - found it @ PU8900.
                • mon2
                  • 14664
                  Start with CHG_REGN - 0,60V. This should be 6v0. Can you confirm this measurement again?
                  • Gigabyte_PL
                    • Dec 2021
                    • 36
                    • Poland
                    mon2 yes, my mistake
                    on REGN is 6V
                    P_CH32_ACOK_10 should be 3.3V but there is 0,02V up to 0,05V
                    • mon2
                      • 14664
                      If P_CH32_ACOK_10 is not a logic high since it is @ 0,02v, this means you should review PR8901. This 100k resistor is mated with this same open-drain pin and also the REGN (CHG_REGN) voltage feed which you have confirmed to be @ 6v0. Is PR8901 defective? Check the voltage to ground on each side of this pull-up resistor. Do check by removing all power -> meter in resistance mode (200k or higher scale) -> measure the resistance ascross this PR8901 part. It should be ~100k ohms.
                      • Gigabyte_PL
                        • Dec 2021
                        • 36
                        • Poland
                        PR8901 - 0,002 up to 0,05V and I checked reststance -> 154K ohm after removing all power.
                        when I checked this resistor I had 101K ohm after removing all power.
                        • Gigabyte_PL
                          • Dec 2021
                          • 36
                          • Poland
                          Maybe IC charger BQ24 is damaged ? Can I check more to confirm it ? or maybe you have more idea to check
                          • mon2
                            • 14664
                            CHG_SDA_5 -
                            CHG_SCL_5 - 0,60V-0,70V​
                            Check the voltage to ground of these pins again. Each should be ~3v3.
                            • Gigabyte_PL
                              • Dec 2021
                              • 36
                              • Poland
                              I confirm that last measurement was correct and the values ​​are within the limits 0,5 -0,8V
                              • mon2
                                • 14664
                                Locate the pull-up resistors on these SMBUS / I2C pins. You can do this through the boardview file -> select the IC pin with the SDA / SCL function. The net will light up and reveal the pull-up resistor(s). Confirm these pull-up resistors are present on the board. Check the voltage on the other side of these pull-up resistors. If the voltage is present, these pins should be ~3v3.
                                Next, remove all power. Meter in DIODE mode. Red meter probe to GROUND; Black meter probe onto these SMBUS pins. Check SDA first and then SCL. Post each DIODE mode measurement. No power in checking resistance or diode mode scale on your meter. Diode mode will confirm if these pins are being shorted or not.
                                • jasko_jacker
                                  • Oct 2014
                                  • 1140
                                  • italy
                                  I have noticed that usually when an IC like the bq780s or similar does not enable the mosfets of the 19V line even if all the signals are in order, there is no attempt to understand if the communication with the host is correct. This problem is more common than people think. I understand that a logic analyzer is needed but even a low-cost one is enough.
                                  • Gigabyte_PL
                                    • Dec 2021
                                    • 36
                                    • Poland
                                    mon2
                                    I'm probably having trouble locating the pull-up resistors. I have boardview but in a .pdf file and I cannot select these pins.
                                    I tried to check the SDA and SCL path and I find, for example, PR9066 and here I have 0.6-0.7V. I don't have a stable 3V voltage. Maybe you can help me locate it?
                                    I am very grateful to you for your help and attempt to save this motherboard.​
                                    • mon2
                                      • 14664
                                      Did not realize that the posted boardview is a PDF version only. Go and grab a fresh download just posted that is a searchable version of the Asus FX516PM file. Will catch up on the other request after a quick trip to the grocery store. Using this inside of a BV viewer, you can click on the SDA pin and the entire network of parts will light up that are mated with the same.
                                      https://www.badcaps.net/filedata/fetch?id=3202546
                                      The SMBUS pull up resistors are @ R3020 (P_SMB0_DAT) and R3013 (P_SMB0_CLK). Check the voltage to ground on both sides of these parts - very carefully.
                                      • Gigabyte_PL
                                        • Dec 2021
                                        • 36
                                        • Poland
                                        I checked these resistors yesterday.
                                        Today I tested again and here are the results:
                                        Diode test:
                                        R3013:
                                        +3V - 0,440V
                                        SMB0_CLK - 0,480V
                                        R3020:
                                        +3V - 0,424V
                                        SMB0_DAT - 0,439V
                                        Voltage test:
                                        R3013:
                                        +3V -0,5V up to 0,8V
                                        SMB0_CLK - 0,5V up to 0,8V
                                        R3020:
                                        +3V - 0,5V up to 0,8V
                                        SMB0_DAT - 0,5V up to 0,8V
                                        Thank you for new boardview.
                                        Additionally, I would like to mention that I make measurements on a motherboard removed from laptop case. Service power supply supplies power through cables that I soldered to power socket.
                                        Battery is disconnected as well as other tapes.
                                        __
                                        EDIT
                                        Is there any proven solution to check whether the BQ24 IC is damaged?
                                          ASUS TUF Dash FX516PM-HN023W Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Dash FX516PM-HN023W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN023W boardview and FX516PM-HN023W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 04:30 AM
                                          ASUS TUF Dash FX516PM-HN072T Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Dash FX516PM-HN072T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN072T boardview and FX516PM-HN072T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 03:10 AM
                                          ASUS TUF Dash FX516PM-HN010T Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Dash FX516PM-HN010T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN010T boardview and FX516PM-HN010T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 02:00 AM
                                          ASUS TUF Dash FX516PM-HN023T Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Dash FX516PM-HN023T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN023T boardview and FX516PM-HN023T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 01:30 AM
                                          ASUS TUF Dash FX516PM-HN023 Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Dash FX516PM-HN023 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX516PM-HN023 boardview and FX516PM-HN023 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
