Acer Nitro 5 - CPU Fans spin full speed when turned off
  • IvanAndreevv
    • Apr 2022
    • 24
    • Bulgaria
    Hello guys,
    I need some help with Acer Nitro AN515-54.
    As said in the title, as soon as I shut down the laptop, the screen goes black like usual, lights off, but cpu fans go full speed until the battery is dead.
    This started to happen yesterday after I have done some improvements to the laptop.
    1. Reinstalled new Windows 10 + drivers and updates
    2. Installed new 8GB RAM stick so total 12 now.
    3. Installed additional M2 NVME drive
    4. Installed additional hard drive (here comes my doubts, I installed 10 pin sata cable, because i did not have the original one, but the original is 12 pin, also I forgot to disconnect the battery while plugging/unplugging the cable.)
    It could be coincidence, but the issue started happening after I have made these changes.
    Do you have any advice or suggestions?
  • Bonzas
    • 474
    • Indonesia
    code board ?
    maybe we here can help if we know which board you have
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Very likely a broken dc-dc converter on 3V/5V lines.
      • IvanAndreevv
        • Apr 2022
        • 24
        • Bulgaria
        Board code is EH5VF LA H501P rev:1A
        • IvanAndreevv
          • Apr 2022
          • 24
          • Bulgaria
          But why is it working fine when the laptop is on then?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Its not my job to convince you. Why not measure and see if the enable pin voltage drops to zero or not after shutdown on this dc-dc converter. The enable wont be removed if the converter is defective and hence the fan keeps rotating
            • IvanAndreevv
              • Apr 2022
              • 24
              • Bulgaria
              Sorry, I didn't mean to make it look like that.
              I have measured the voltage at the fan connector and seems like the PWM line is changing from 3.5 - 5v. The only problem is that I couldn't find the chip that is controling the voltage.
              • loopster
                • Sep 2020
                • 80
                check here, maybe this gives you a lead:
                https://www.badcaps.net/forum/troubl...pter-connected
                Maybe you have a similar case with a defective temperature signal mosfet on the smbus lines to PCH...
                • Sephir0th
                  • Oct 2020
                  • 1289
                  Does the issue persist when you revert all hardware changes and install a clean windows again?
                  FairRepair on YouTube
