Sony Vaio FZ21M - Blank screen after logo
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    I'm having a weird problem with a vaio laptop. It powers on fine, shows logo and boot BIOS when F2 is pressed, BIOS recognize HDD and DVD, but won't get pass that. When i turn on, doesn't matter what i try to boot (HDD, DVD, USB), it shows vaio logo and then goes blank, no blinking cursor, nothing, and doesn't boot anything.. I also tried removing all drives and running each one isolated.
    At this point I was convinced the issue was BIOS related, but then a friend told me to test the laptop for beeps without RAM, and in fact it doesn't give any beeps errors without RAM which apparently points to a bad mobo.
    Do you have any idea what might be causing this issue?
    TIA.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
  • tomodachi
    • Apr 2012
    • 610
    • Turkey
    Re: Sony Vaio FZ21M - Blank screen after logo
    That model comes with GPU (G86-750-A2) problem mostly. Try a reflow on it with heater about 10-20 seconds
    then give us feedback and lets see what we can do
    • lefos
      • Nov 2013
      • 321
      • Greece
      Have you tried with the cmos battery disconnected? Yes this vga has problems. Does the screen have any lines or strange characters ?
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        The screen in fine, it seems doubtful the issue is GPU related..
        I left it on the BIOS menu screen for about an hour to rule out overheating.
        Are you sure a reflow is the way to go?
        Thanks.
        Try Harder!
        • Learn2Day
          • Jun 2013
          • 254
          • Portugal
          Sorry, forgot to mention, removing CMOS battery was one of the first things i did. Up until no RAM no beep errors I was convinced the issue was BIOS, obviouslu my first actions were remove CMOS batt, drain battery, load BIOS defaults, etc..
          Try Harder!
          • lefos
            • Nov 2013
            • 321
            • Greece
            You can try to reflow teh gpu and if the problem is there the best thing to do is change it with a new one. But first check for the cmos battery.
            • tomodachi
              • Apr 2012
              • 610
              • Turkey
              Well if you are able to find BIOS dump and flash it, if I were u I d try it.
              • scsblackdragon
                • Dec 2013
                • 7
                • England
                reflow the southbridge
                • Dimitrios
                  • Nov 2013
                  • 127
                  • Greece
                  Most likely a GPU issue. When it tries to load the driver and activate the GPU in its fullest capabilities then it shuts down probably due to bad solder joints underneath GPU.
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    re-flash bios.
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      I'd like to consider reflashing BIOS, problem is I don't have a BIOS programmer available, and obviously i can't access USB or HDD to flash it onboard.
                      Do you know if there's any BIOS recovery procedure available for this laptop? Might be worth a try..
                      I'm not discarding reflow jobs entirely, but right now seems illogical and unnecessary..
                      A couple of reasons - GPU - Laptop screen works fine, no glitches; SB - BIOS recognizes HDD and DVD.
                      Yes they might be failing, but unless someone else has experienced and solved such problem this way, I'd like to rule out some more probable causes before going this path blindly.
                      Thanks.
                      Try Harder!
                      • lefos
                        • Nov 2013
                        • 321
                        • Greece
                        No as far as I know there isn't any recovery process on this one. Also I think that if the gpu failed it will be after loading windows or there would have been lines, strange characters etc (which is usual on this laptop). I guess that you have tried without touchpad and keyboard connected right?
                        • dj_ricoh
                          • 2073
                          • uk
                          Worst case scenario cook the board dam it .
                          If you don't have the tools or the money to give it to some one for a reball and a new chip.
                          Just cook it.
                          Hmmm this will be my motto.
                          • tomodachi
                            • Apr 2012
                            • 610
                            • Turkey
                            Just cook it.
                            Yeah, like MJ says "beat it !"
                            Keep in mind that motherboard is lead-free. and a problem generator if you don't handle right.
                            • spidey
                              climbs
                              • Dec 2012
                              • 644
                              • Cyprus
                              you can find easy to build spi bios programmer by using google.
                                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 05:27 AM
                              • kotel studios
                                Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                by kotel studios
                                Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                State I got it in:
                                Squealing from the PSU
                                After logo I get a blank screen
                                After 10 seconds of having a blank display w/ backlight the TV dies
                                Give it 7-10ish seconds again and it starts to bootloop.
                                What I did so far:
                                Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                Checked all voltage rails:
                                5VSB - 4.8V
                                AMP+13V - 14.4V
                                13V - 12.98V (in manual 12V)...
                                09-21-2025, 02:00 AM
                                Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
