Toshiba Satellite C650 D AMD mas10ad no power
  • Dimitrios
    • Nov 2013
    • 127
    • Greece
    Hello there guys! I need some help here from the experts please! I have a Toshiba C650D AMD that does not have any signs of life.
    I was able to trace voltages across the mobo and find out that DC Battery out was 3.5V instead of the usual 10-12V. Also since this circuit is the main power supply of dc always on voltages there is no 3.3V and 5V.
    I read that there is a problem with Q6002 but I am not getting any voltage in its Gate pin and that confuses. Output is 3.5V. Should that be 19V??
    Please have a look at my picture. It has all my readings:
    And for reference I am missing 11V on Source of Q6001:
    Originally posted by fddizon
    hi,
    I have here the same issue toshiba satellite c655-s5128. works on battery but not charging, does not work using AC adapter. Q6002 tested good.
    max17435E
    acin 19v
    acok 5.27v
    acin 1.68v
    battery connector
    pin 6-7 3.4v
    pin 5 .12v
    pin 4 0v
    pin 3 fluctuates
    pin 1-2 11v (unit off with battery)
    q6002 drain 19.24v
    q6002 source 10.96V (unit off with battery)
    gate 0v
    is max7345E faulty?
  • khaahk
    • Dec 2013
    • 806
    • Estonia
    Re: Toshiba Satellite C650 D AMD mas10ad no power
    Q6002 is a P channel mosfet, so it should be fully opened (conducting) when gate is low. Change it and see if it fixes the problem.
    • Dimitrios
      • Nov 2013
      • 127
      • Greece
      Oh, is it activated on zero voltage or low voltage (1-2 Volts)? If it is on zero voltage it is definitely defective.
      Actually this is a N4800ls N-channel mosfet.
      http://www.diodes.com/datasheets/ds31736.pdf
      • khaahk
        • Dec 2013
        • 806
        • Estonia
        My mistake, yes it is an N channel mosfet. So it is ok. The max17435 should bring ACOK to low state, when ACIN is over 1.4 V (as it is). Beacause the ACOK is high, then max17435 should be faulty. I believe i have seen a couple of Toshibas with faulty 17435 ic-s.
        • Dimitrios
          • Nov 2013
          • 127
          • Greece
          Yes you are right! I thoroughly inspected MAX17435 datasheet and indeed it is defective. DC power jack was shorted some time ago and maybe it caused this chip to become faulty. Ok then will try to replace it but there are almost 50 little SMD components right next to all sides of the chip and should not be easy. Will try with hot air and a preheater and definitely cover the components with aluminum tape. It is tricky though! Maybe this video will help others too.
          http://www.youtube.com/watch?v=c_Qt5CtUlqY
          Thank you very much for your help, highly appreciated!
          When I have the new chip and solder it will post back the results, will take a while though!
          • Dimitrios
            • Nov 2013
            • 127
            • Greece
            Ok, new chip arrived and already replaced the faulty one. I am not sure if I did it right but it seems so. Now I am getting variable and not stable voltage at ACOK, between 1.4V-8V. Did I solder it correctly or the problems lies somewhere else I wonder. I think it may needed new solder there...
            What do you think guys?
            • lord
              • May 2011
              • 319
              • Croatia
              Did you test Q6002?
              • panos1205
                • Jan 2014
                • greece
                sorry for posting here i'm noob and i need some help. I have a c850 with no power at all, no led lights, i found a schematic here but my laptop kas a hannstar motherboard i check dc jack and it has 19v. Any help will be much appreciated
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  VBAT is also stable or fixed at 3.5v?
                  • Dimitrios
                    • Nov 2013
                    • 127
                    • Greece
                    Originally posted by lord
                    Did you test Q6002?
                    Drain is 19.5V, Gate is variable 0.1-1.8V and Source is variable 5.5-8.3V...
                    VBAT also shows variable 5.5-8.3V constantly changing...
                    Thank you all for your help! I think something is messing my voltages on the battery section...
                    • khaahk
                      • Dec 2013
                      • 806
                      • Estonia
                      Measure some voltages on MAX17435 without battery
                      Pin 3 (DCIN) -
                      Pin 4 (LDO) -
                      Pin 19 (ACIN) -
                      Pin 10 (ACOK) -
                      Pin 22 (VCC) -
                      • Dimitrios
                        • Nov 2013
                        • 127
                        • Greece
                        MAX17435 without battery:
                        Pin 3 (DCIN) - 18V R6016 drops it from 19.5V??
                        Pin 4 (LDO) - 5.5V
                        Pin 19 (ACIN) - 1.7V OK
                        Pin 10 (ACOK) - 0V
                        Pin 22 (VCC) - 0.2V ?Not soldered properly?
                        Weird. Noticed that R6014 gets 5.5V from LDO and exits 0.2V. Same with R6014.
                        • khaahk
                          • Dec 2013
                          • 806
                          • Estonia
                          R6014 - resistance 10 ohms ?
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            Pin 4 (LDO) - 5.5V
                            Pin 10 (ACOK) - 0V
                            In your first post, pin 10 is 5.5v. After new chip is soldered, pin 10 is 0v or variable? R6014 could have changed resistance or the new chip is shorted (in this case R6014 could be getting very hot), hence, pin 22 is .2v only?
                            Also, it's highly possible that there's shorted/failing capacitor along VBAT rail. A quick resistance test between SOURCE of Q6002 to ground would confirm this.
                            • Dimitrios
                              • Nov 2013
                              • 127
                              • Greece
                              R6014 has 10K ohms [20K scale multimeter], should be 10 Ohms and R6016 has 230 Ohms should be 10 Ohms ,right? The rest of the resistors are measured ok within specs!
                              Pin 10 is 0Volts. So is and D6001 pin3. I think there is something wrong with the solder there. It seems empty without solder. Will clean flux tomorrow and see with a magnifier glass. Also Q6002 to ground tested negative no continuity.
                              What about the resistors? It is strange to have changed values...
                              • whaldsz
                                • Apr 2013
                                • 395
                                • Philippines
                                about the resistors, try to replace them if possible or check the resistance out of circuit. these resistors should not read GREATER than their rated value when out of circuit.
                                But you should find the shorted component before you power on again, or these resistors might be busted again.
                                • Dimitrios
                                  • Nov 2013
                                  • 127
                                  • Greece
                                  UPDATE: I bought a new motherboard and posting the correct values of MAX17435 charger plugged in without battery just for reference and to help others!
                                  Pin 3 (DCIN) - 19V
                                  Pin 4 (LDO) - 5.5V
                                  Pin 14 (PDSL) - 27V
                                  Pin 10 (ACOK) - 0V
                                  Pin 22 (VCC) - 5.5V
                                  Q6002 S-D 19V
                                  Q6002 Gate 27V
                                  R6036 27V
                                  • elpelado
                                    • Mar 2014
                                    • 8
                                    • united states
                                    Where can I buy this ic chip. Mine is n4800ls 10 34
                                    • Dimitrios
                                      • Nov 2013
                                      • 127
                                      • Greece
                                      You can replace it with AO4422 just like stated at this thread https://www.badcaps.net/forum/showthread.php?t=27041
                                      • glykas
                                        • May 2014
                                        • 6
                                        • Athens
                                        hello i have problem with c650d main board with power button connector in board im broke the board connectors where the connector is gone to make a jumber?
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:10 PM
