Toshiba Satellite C655 won't run off AC. Need schem.
  • shaker31280
    • Jul 2013
    • 5
    Re: Toshiba Satellite C655 won't run off AC. Need schem.
    Ah I get it, thanks for your help. I am testing with a multimeter. So which legs do I have to touch together to find out if its shorted?
    • rievax_60
      • May 2012
      • 897
      • australia
      A good MOSFET should test open circuit between Drain and Source. Also open between Gate and Source. I found faulty MOSFET lately that had low resistance reading between Gate and Drain, about 2K ohms.
      Some high resistance readings can be expected while its still soldered to the PCB.
      I dont like removing parts until I am fairly certain that they are faulty.
      There is more detail to testing MOSFETs.
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        pin 1 one test probe, and the other probe to pin 6. measure resistance, then reverse. if you can read low resistance in both ways, it is shorted
        • shaker31280
          • Jul 2013
          • 5
          Its 0 from 1-6. The other chip next to it shows like .3 Chips look to be identical. So does this mean its short?
          Who can sell me 5 of them?
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            hi,
            I have here the same issue toshiba satellite c655-s5128. works on battery but not charging, does not work using AC adapter. Q6002 tested good.
            max17435E
            acin 19v
            acok 5.27v
            acin 1.68v
            battery connector
            pin 6-7 3.4v
            pin 5 .12v
            pin 4 0v
            pin 3 fluctuates
            pin 1-2 11v (unit off with battery)
            q6002 drain 19.24v
            q6002 source 10.96 (unit off with battery)
            gate 0v
            is max7345E faulty?
            • rievax_60
              • May 2012
              • 897
              • australia
              #26
              I cant find data on the max7345E . Did you check Gate to Source leakage of Q6002?
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                #27
                Shaker,
                If the reading is the same both ways, it is shorted. What is 0? Try to short your probes and take note of the reading, the. Test again mosfet. If the same reading is the same with shorted probe or near it, it is shorted.
                • fddizon
                  • Sep 2011
                  • 555
                  • Philippines
                  #28
                  My apology. Typo error. Pls refresh page. Its max 17435e
                  • fddizon
                    • Sep 2011
                    • 555
                    • Philippines
                    #29
                    Already replaced Q6002 from a dead toshiba board. The same voltage reading. Q6002, when battery is on with adapter, drain 19volts, source is 10.9volts while gate is 0 volts. The fet is 4410N which is a n-channel fet. Also kinda confused with the replacement irf8113 which is a p channel. I didnt know that it can be inter changeable. (Correct me if im wrong)
                    leakage test has been performed. at 2k no deflection.
                    • whaldsz
                      • Apr 2013
                      • 395
                      • Philippines
                      #30
                      Since ACIN is greater than 1.485V, AC input is detected, therefore ACOK' should be 0V. Also pin 24 should be above 2.4V.
                      Try to replace the chip.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #31
                        The IRF8113 is N-channel also. Is there a link to the schematic of the C655 somewhere?
                        • fddizon
                          • Sep 2011
                          • 555
                          • Philippines
                          #32
                          Close to c655 is c650 at www.lqv77.com
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #33
                            According to the max17435e data, ACOK state should only be affected by the voltage range on ACIN. ACOK should be low while ACIN is between 1.48v and 2v.
                            The IC might be faulty.
                            If you have a DSO, it might be useful to see if Q6002 is being turned on briefly when adapter power is first applied. This IC will permanently turn off the adapter MOSFET, Q6002?, if it senses an overload.
                            I couldnt find the C650 schematic, might be moved.
                            • jtamad44
                              • Apr 2013
                              • 145
                              • israel
                              #34
                              • fddizon
                                • Sep 2011
                                • 555
                                • Philippines
                                #35
                                whaldz,
                                pin 24 got 0v.
                                ive got 3 volts after R6003
                                does that mean max chip is faulty?
                                • fddizon
                                  • Sep 2011
                                  • 555
                                  • Philippines
                                  #36
                                  Originally posted by jtamad44
                                  thanks jtamad44 but not the correct schematic
                                  • fddizon
                                    • Sep 2011
                                    • 555
                                    • Philippines
                                    #37
                                    rievax,
                                    corrections:
                                    max17435E
                                    dcin 19v
                                    acok 5.27v
                                    acin 1.68v
                                    schematic more close to c655 attached
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #38
                                      Vcc pin 22 needs to be 5v.
                                      • whaldsz
                                        • Apr 2013
                                        • 395
                                        • Philippines
                                        #39
                                        PDSL pin 14 is 0V because ACOK' is 5.27V. PDSL provides the voltage needed to turn on Q6002.
                                        But ACIN is 1.68V, so the ACOK' must be low. Therefore, PDSL must be HIGH - which will turn on PDSL.
                                        • fddizon
                                          • Sep 2011
                                          • 555
                                          • Philippines
                                          #40
                                          sir whaldsz, do you have one?
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
