MacBook A1989 missing rails PP3V3_S5 and PP1V8_S5
This topic has been answered.
  • Nikan.e
    • Nov 2023
    • 17
    Greetings and Salutations,
    I have gotten an A1989 Macbook board number 820-00850-A which has two missing rails -> PP3V3_S5 and PP1V8_S5.
    PBUS is at 12.6V every other voltage made by the PMIC is just fine.
    Resistance to ground -> PP3V3_S5 ~ 220Ω
    Resistance to ground -> PP1V8_S5 ~ 220Ω
    PP1V8_S5 and PP3V3_S5 are not shorted together.
    Voltages up to PP2V5_NAND_SSD0 seem to be fine.
    Can anyone confirm if these resistances are normal for this board?
    What could be causing this issue?
    Is there a way to rule out a defective PMIC without replacing it, as I do not have a donor.
    Thanks in advance and best regards from Germany,
    Nikan​
  • Answer selected by Nikan.e at 12-04-2023, 05:09 AM.
    mon2
    • Dec 2019
    • 13921
    T2 has booted since ppbus_g3h is 12v6.
    try dfu on this unit.
    what is the voltage and current draw on the usb c meter?
    https://repair.wiki/w/A1989_2018_13”_Touchbar_MacBook_Pro
    • mon2
      • Dec 2019
      • 13921
      • Nikan.e
        • Nov 2023
        • 17
        DFU does indeed work; it shows up on a PC running a virtual machine - Sonoma, with the latest Apple Configurator installed.
        However, the restore option does not complete. Could this be due to the virtual machine, or is it because the trackpad is missing?
        The schematics also show that a sensor is located on the trackpad. Is that relevant for a restore, or does the software not check for the trackpad while trying to restore?
        The voltage does go up to 20V but the current draw is very funky. It stays sometimes at 44mA, sometimes it goes up to 300mA, and sometimes it goes all the way up to 1.9A. But it is always cutting off after some time and - power cycling. Disconnecting and reconnecting the power supply does get the current draw back up, if it is stuck at 44mA.
        • mon2
          • Dec 2019
          • 13921
          Yes. Had exactly this case with A2141 last week. Killed too much time on it but yes, the trackpad MUST remain connected. If missing, the sensors will not be detected over smbus lines which will result in high fan spin and power cycling. We thought that some part was overheating but nothing was over 52 degrees C. We used the same board in target mode to extract the client's data off which was very valuable to their company. Attempt the same process with the trackpad. For us, the dfu process did complete (4/4 steps). We applied a revive process.
          btw - press T key during boot and you should see the logon screen on the remote unit. If that works then your nand is ok. Login to see the drive letter and contents.
          Also, we used a known good A2141 for the dfu process which the client purchased after the data migration.
          • Nikan.e
            • Nov 2023
            • 17
            I do not get any fan spin or a hiccup on the fan, not even when it is trying to revive/restore. Does the fan kick in even without the trackpad?
            Wow, that is crazy. I really did not expect this, but well, what do I know? It's Apple after all...
            • mon2
              • Dec 2019
              • 13921
              Yes, we had normal fan spin with trackpad and hyper fan spin without the trackpad. Had boot chime always on the A2141. Attempt the target mode using your external remote unit to check for the logon screen.
              • Nikan.e
                Nikan.e commented
                Editing a comment
                The configurator does not show anything at all when holding the t key while booting, but I am able to see it as an apple macintosh peripheral device.
                Also, I do not get the boot chime. But DFU does show up, when using the debug jumper as well as the keyboard combination.
            • mon2
              • Dec 2019
              • 13921
              It is our belief that the quality of the usb cable and the host are important. We attempted to use an A1534 and that failed to logon to the Sonoma target. We did use a 40G rated usb cable from Amazon. Do test other quality cables unless this cable is a known good one used for the dfu process. The use of the fresh A2141 was key for us.
              • Nikan.e
                Nikan.e commented
                Editing a comment
                I was finally able to test it, but unfortunately, it did not work.
                The trackpad does indeed function, and the haptic feedback works while the device is not in DFU mode.
                - The trackpad was connected while trying to revive and also restore.
                - A similar Mac, just with a different RAM/SSD configuration, was used.
                - Different cables were tested, from Apple and other brands.
                I always get an error saying the following:
                "Gave up waiting for the device to transition from DFU state to DFU state. [com.apple.MobileDevice.MobileRestore - 0xFCA (4042)]"
                I am thinking that this error means the following:
                The device is in DFU mode -> the host device restarts the target device -> the host device is waiting for the target device to turn on the rails so that the CPU can be used.
                What are the next steps to take on this Mac?
                I really want to get this working; it is really bugging me. I hate it whenever I can't figure out what's going on!
                Even if it is doomed to be unreparable, I want to know the reason -> what is hindering the S5 Rails from showing up...
            • Nikan.e
              • Nov 2023
              • 17
              Alright, Thank you very much!!! I'll try it as soon as I get the trackpad cable!
              • SarcasticOP
                General question about MacBook power rails for repair.
                by SarcasticOP
                I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                • PPBUS_G3H (12.6V-12.8V)
                  • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                • PP3V42_G3H (3.42V)
                  • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                • PPVRTC_G3H (3.3V)
                  • This
                12-12-2024, 05:50 PM
              • skwarszczow
                Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                by skwarszczow
                This is my first post on the forum
                I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                Before completing the purchase, we decided to erase...
                03-23-2025, 06:04 PM
              • Cemal Odabasioglu
                MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                by Cemal Odabasioglu
                I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                Observations...
                01-14-2025, 03:54 PM
              • ErinV
                MacBook Pro A1989 820-00850-A not powering on
                by ErinV
                Hey everyone!
                I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                The diode voltages around all 4 CD3215's seem fine.
                For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                09-30-2024, 10:21 PM
              • Madoy104
                Macbook Pro A1989 - No image, working fine with external monitor
                by Madoy104
                I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                08-15-2024, 10:01 AM
