Satellite L645 ATI GPU Shutdown Every 20 seconds
  • degutji
    • Dec 2012
    • 173
    • Indonesia
    Hi All,
    I've Toshiba Satellite L645 with ATI GPU, the laptop turn on and boot normally and shutdown every 20 seconds, when I turn on again it will boot normally and turn off after 20 seconds, need your advise who have found problem like this. Already try to :
    - Reballing both Chipset GPU and HM55
    - Flashing Bios
    - Replace thermal IC
    Do I have to replace new chipset ? GPU or HM55 first ? or the problem is somewhere else ? Any idea....
    Regards
  • are-red
    • Feb 2013
    • 24
    • malaysia
    Re: Satellite L645 ATI GPU Shutdown Every 20 seconds
    its this model got proadlizer on it? if it have, try to change that
    • degutji
      • Dec 2012
      • 173
      • Indonesia
      No, there is no TOKIN on it
      • dj_ricoh
        • 2073
        • uk
        same on battery?
        • degutji
          • Dec 2012
          • 173
          • Indonesia
          Same DJ
          • dj_ricoh
            • 2073
            • uk
            O wait just fix a Toshiba 2 weeks ago. It had i7 shuts down after less then a min.
            I swap the CPU with a i5.
            The i7 it's it's working fine in another one.
            • khaahk
              • Dec 2013
              • 766
              • Estonia
              You can try to change bios. Might be a ME problem. This is for Quanta TE2.
              • degutji
                • Dec 2012
                • 173
                • Indonesia
                Hmm..I'll try it tomorrow and post the result
                • degutji
                  • Dec 2012
                  • 173
                  • Indonesia
                  Still same
                  • dj_ricoh
                    • 2073
                    • uk
                    what cpu do you have?
                    nvm change it.
                    if you see some change that means the problem its related to caps near the cpu
                    • spidey
                      climbs
                      • Dec 2012
                      • 644
                      • Cyprus
                      it is ME region problem, you have to integrate a clean ME region to your existing bios file and upload it to your spi eprom.
                      • degutji
                        • Dec 2012
                        • 173
                        • Indonesia
                        nvm change it.
                        Core i5
                        what you mean "nvm" ?
                        +VCC_CORE = 1.0v
                        +1.5V_CPUVDDQ = 1.3v
                        is it normal ?
                        ME region ?? do you mean Main Eprom..? Toshiba Satellite L645 - PSK0LL model, do you have it? try downloaded from toshiba site and extract it but the file bigger than 4MB (4.50MB). Already try with the original one from the laptop itself with no success
                        • degutji
                          • Dec 2012
                          • 173
                          • Indonesia
                          I've got another Toshiba , same type and model. Same problem, just different CPU only. This is Core i3, any idea all...?
                          • khaahk
                            • Dec 2013
                            • 766
                            • Estonia
                            The earlier uploaded bios might not have been correct. I downloaded the version from Toshiba website. Did you save the original bios? If so post it here, then the ME region can be compared. Try these from toshiba site. First bios and if it does not help, reprogram the EC bios also.
                            • are-red
                              • Feb 2013
                              • 24
                              • malaysia
                              Its same in safe mode? If yes, u need change your gpu
                              • degutji
                                • Dec 2012
                                • 173
                                • Indonesia
                                You are the man
                                It's Working, just flash Main bios from yours. Finally Problem solved
                                Sadly the core i3 need to replace HM55 cause trial and error before I get your bios file, anyway problem solved spend a week to solve this who made me hopeless .
                                I think this is what Spidey mean above . Btw how did you do to extract bios file from toshiba site ? use a same working laptop or just doing by software ? Cause I've do that using extracting tool like I said before but the file much bigger and no EC file ?
                                Thank you Khaahk for safe my ass
                                Already try it before with no success , problem solved Thank's
                                • degutji
                                  • Dec 2012
                                  • 173
                                  • Indonesia
                                  Done
                                  Anyway how to extract this file ( Dell Latitude E6520 Bios ), Universal Extractor and command /writeromfile failed
                                  Best Regards
                                  • nazrul145
                                    • Jan 2014
                                    • 335
                                    • BD
                                    Thanks Khaahk very much. now i have solve same problem with ur bios.
                                    • mgmasus
                                      • Nov 2014
                                      • indonesia
                                      Thanks to Khaahk too, my problem with toshiba l645 has solved, thanks very much bro
                                      • msl77
                                        • Jun 2014
                                        • 10
                                        • yemen
                                        Very thankes
                                          Dynabook Satellite Pro Satellite Pro R40-D-11P Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro R40-D-11P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R40-D-11P boardview and Satellite Pro R40-D-11P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 12:08 PM
                                          Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A50-E-209 boardview and Satellite Pro A50-E-209 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          Dynabook Satellite Pro Satellite Pro C50D-B-11Y Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C50D-B-11Y Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C50D-B-11Y boardview and Satellite Pro C50D-B-11Y schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C40-G-13E boardview and Satellite Pro C40-G-13E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          Dynabook Satellite Pro Satellite Pro C40-J-11G Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C40-J-11G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C40-J-11G boardview and Satellite Pro C40-J-11G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 04:30 AM
