dell inspiron mini 10 cases
  • bowor
    • Oct 2013
    • 36
    • indonesia
    dell inspiron mini 10 cases. do not want to be on. it's going through? I already did flash the bios, changing power ic, changing charger ic, but still it does not want to be on. but plug in the battery going on. roughly where the problem is? thank you
  • Francisco.s
    • 686
    • Spain
    Re: dell inspiron mini 10 cases
    Have you got the schematic?, if so, post it.
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      if starts with battery and doesnt starts whithout battery, that one doesnt detect VIN check acok, acin etc.. check Vindetect circuit, if exists Lm339, 393 chips offen die or a component around.
      • bowor
        • Oct 2013
        • 36
        • indonesia
        schematics dell inspiron mini 10
        • bowor
          • Oct 2013
          • 36
          • indonesia
          conditions during take-battery: voltage alw 3/5v normal, normal voltage vcc ec. but the voltage is 3/5 vs none. where is the control voltage vs? maybe a problem at embeded controler (ec). help me give suggestion!!! thank you
          • bowor
            • Oct 2013
            • 36
            • indonesia
            this schematics vs
            • cyberhack
              • Feb 2013
              • 466
              • Uk
              check the usb's for short
              • bowor
                • Oct 2013
                • 36
                • indonesia
                no short in the usb, or around usb
                • bowor
                  • Oct 2013
                  • 36
                  • indonesia
                  I've change ec, but the problem remains the same. if anyone can add this problem?
                  • bowor
                    • Oct 2013
                    • 36
                    • indonesia
                    hi spidey, how to chek acok, acin? initially in pin voltage battery no. after changing ec out voltage. but still do not want to be on.
                    • dj_ricoh
                      • 2073
                      how to chek acok, acin?.
                      you need to find the isl charging chip.
                      i used my old probe and i got them sharp so i can measure small connectors from chips like this.
                      • dj_ricoh
                        • 2073
                        find PU3 on the mainboard
                        thats the main charging chip.
                        • alihomee
                          • Dec 2012
                          • 1575
                          • malaysia
                          any body have a solition for this problem.i am also faceing same with battery it runs fine but it didt charge battery without battery when power button pressed it shows led light for a while then again turns off.i also tried all which is mention above .i have three units with same problem
                          • alihomee
                            • Dec 2012
                            • 1575
                            • malaysia
                            any body
                            • alihomee
                              • Dec 2012
                              • 1575
                              • malaysia
                              no solution?
                              • Claudio Silva
                                • Feb 2013
                                • 94
                                • Portugal
                                Hello friend, lemme try to help.
                                Ur problem is that the Motherboard doesn´t regonize the the DCJack´s pluged in, so u need to follow the sequence to find the fault.
                                The sequence is:
                                Jp53 pins 1, 2 = 19v, follow de signal VIN and measure the coils PC1, PC2, PC3 and PC5 check for short.
                                The VIN signal (tension i know) goes to charge IC page to create B+ signal, trough 2 Mosfets (PQ2 and PQ3). In this pins 5, 6, 7, 8 (Drain of PQ3). The gate will recieve a low signal from pin 4 /ACDRV. And finally the board will get B+ signal from DCJack
                                The board will need the confirmation that the DCJack´s plugged in. This data goes to EC in form of ACIN. The comparator pu1A will recieve on pin 1 19v from de DCJack, pin 8 nearly 19v, pin 2 nearly 3.3v, pin 4 gnd 0v.
                                When PU1 get voltage on pin 2 and 3 on pin 1 the board will have de signal ACIN, that indicates EC that the DCJack´s plugged in and it´s working.
                                This signal goes to EC
                                Follow all the sequence and post the results
                                  DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                  This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                  09-12-2024, 03:30 PM
                                  DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                  This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                  09-12-2024, 03:28 PM
                                  DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                  DELL Inspiron 3650 Inspiron 3000 i3-6100T Specification for Upgrade or Repair
                                  This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                  09-12-2024, 02:15 PM
