Dell 1564 Dead
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Dell 1564 Dead
    Recently a customer gave me a DELL 1564 core i3 which is dead. When i connect the charger the power LED turn on for a while then it turns off. But when i press the power button there is no power. I've checked the voltages on Power switch, it shows 4.96 volts rather than 3.3 Volts. I've changed ITE8502 but there are same voltages If anyone knows Which part is faulty then i'll be very thankful to him. Or plz give me any hint to check which part is faulty?
    Thanks a lot.
    I'm eagerly waiting for the reply.
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Re: Dell 1564 Dead
    I'm still waiting from anyone who give me the solution.
    Plz help me out.
    Thanks a lot. . . .
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      Re: Dell 1564 Dead
      try flashing bios
      • sasser
        • Dec 2012
        • 365
        • Malaysia
        Re: Dell 1564 Dead
        if 19v,5v and 3.3v is present always prob with bios.try flashing bios. or do reset processor pull and place back
        • dspok
          • Jan 2014
          • 553
          • Nepal
          Re: Dell 1564 Dead
          can anybody share me EC and Main BIOS dump for this model please.
          It is intel VGA.
          • nazrul145
            • Jan 2014
            • 337
            • BD
            Re: Dell 1564 Dead
            Hey try this bios.
            • dspok
              • Jan 2014
              • 553
              • Nepal
              Re: Dell 1564 Dead
              Originally posted by nazrul145
              Hey try this bios.
              Thanks for the files nazrul.
              • dspok
                • Jan 2014
                • 553
                • Nepal
                Re: Dell 1564 Dead
                Very hardwork for me.
                Reflashed BIOS same problem, reflowed nch same problem, changed SIO same problem.
                Problem is no display, no fan spin, just turns on.
                Anybody please suggest.
                • ridamouh159
                  • Nov 2014
                  • 365
                  • maroc
                  Re: Dell 1564 Dead
                  many thanks
                  • ravi_1617
                    YY Solutions
                    • Jan 2012
                    • 348
                    • India
                    Re: Dell 1564 Dead
                    Hi Same board .
                    no charging
                    no turning on,3.3V_ALW_ON present.
                    no +5V_ALW
                    3.3 present at bios pin 3
                    4.98 volts present at power switch.
                    replaced TPS51427A.
                    should i repace IO chip
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: Dell 1564 Dead
                      IO chip has nothing to do with 5V-so dont replace it. What is the impedance on 5v coil??
                      • ravi_1617
                        YY Solutions
                        • Jan 2012
                        • 348
                        • India
                        Re: Dell 1564 Dead
                        reference to ground
                        Pl5 27.71 k ohm
                        pl4 .550k ohm
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Re: Dell 1564 Dead
                          +5V_EN, +15V present at tps 51427?? I hope you checked pq28/32.
                          • ravi_1617
                            YY Solutions
                            • Jan 2012
                            • 348
                            • India
                            Re: Dell 1564 Dead
                            Sorry for late reply , +5V_EN not present pq 28/32 ok
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Re: Dell 1564 Dead
                              Schematic is avlbl for this mb. You need to find out why 5V EN is missing. I've given you the clue and now you need to dig it further.
                              • BTubbs200
                                Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                by BTubbs200
                                Dell Latitude 5420 P137G
                                Board: LA-K491P REV A01
                                I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                Board seems to have no shorts, all power rails are fine and show high resistance.
                                When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                01-24-2025, 08:15 PM
                              • gugutm
                                Dell Latitude 5410 dead help please.
                                by gugutm
                                hi everyone,
                                need some advice i am not professional just junior , but maybe someone could help me please
                                i have
                                Device : Laptop
                                Brand : DELL
                                Model : LATITUDE 5410
                                Board Number: FDZ41 LA-J371P Rev:1.0
                                i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
                                my problem is its not turning...
                                08-28-2025, 02:24 PM
                              • Francesc V.
                                Dell dockstation WD15 is dead
                                by Francesc V.
                                Hi:
                                A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                                Here are the findings, followed by good pictures. :-)
                                When pluged in, LED3 glows
                                Measuring some voltage in the circuit.
                                Inductors
                                - PL202 has 5V
                                - PL201 has 3.3V
                                - PL300 has 1V
                                V. Regulators
                                - UT30 has 19v as input and 6V as output. It seems ok.
                                - UT27 (same reference as UT30, has no input/output voltage).
                                Thermal find...
                                07-09-2025, 12:12 AM
                              • YellowJacket
                                DELL Latitude 5410 - dead; pwrbtn flashing
                                by YellowJacket
                                Hi folks,
                                DELL Latitude 5410, board number FDZ41 LA-J371P Rev: 1.0 (A00), schematic uploaded in different post, here is the link --> https://www.badcaps.net/filedata/fetch?id=3484415
                                When I connect it to a power ( DELL round charger, or USB-C ), LED on the power button starts flashing white, and the laptop doesn't do anything ( flashing slows for a very brief time in time when I press it, but it continues again ). Battery is not charging. While the charger is connected, I have few voltages present, but some of them are fluctuating, see attached pictures.
                                All I was able...
                                04-26-2025, 07:05 AM
                              • tracks
                                Dell 3080 Micro BIOS dead
                                by tracks
                                Hello all,
                                I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
                                Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
                                I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
                                04-19-2025, 03:42 PM
