Toshiba L450 Completely dead - hot MOSFETs
  • spleenharvester
    • Mar 2010
    • 902
    Got this one this morning, board's clearly had a rough life. CMOS battery removed, lots of sticky residue (looks like some is from a reflow attempt and some is from the removal of mylar tape but I need to get it scrubbed off eitherway)
    Full schematic is here:
    Component PF2 (on battery connector) appears to be missing. According to this picture it's some kind of fuse, I should be able to grab it off another board. (Bottom left by batt connector)
    Voltage at the adapter oscillates from 1.4v to 1.6v. The adapter works fine (I am using my L300 from it now). A high pitched oscillating squeal comes from the board a few seconds after plugging adapter in.
    Components PQ6 and PQ7 (shown below) get very hot. PQ7 appears to be short. Nothing nearby seems to get hot.
    To do:
    Replace PQ7 - AO4407 MOSFET
    Replace PF2 - 15A 65v Fuse
    Replace CMOS battery
    Any other suggestions?
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 902
    Re: Toshiba L450 Completely dead - hot MOSFETs
    Update, Northbridge is also getting quite hot.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Is this after you replaced the mosfets?
      Muh-soggy-knee
      • spleenharvester
        • Mar 2010
        • 902
        Nah, haven't replaced the MOSFET yet. Can I replace the AO4407A with an AO4407?
        I was quite surprised since there is almost no voltage across the rest of the board. Also, the sticky residue appears to be nonconductive (probably flux).
        • fddizon
          • Sep 2011
          • 555
          • Philippines
          i think you can
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            yes you can. any 30v P channel mosfet would fit.
            • spleenharvester
              • Mar 2010
              • 902
              Sweet, I'll get right on it.
              Also, found another two, these are both scalding hot, and 0v through both PQ24 and PQ26. PQ26 is shorted (single digits on diode test, same as before). neighbouring PQ23 and PQ25 are fine so it doesn't appear to be related to TPS51124.
              It's also worth noting that PQ24 and the adjacent ceramic cap are sort of misplaced, like they've slid during a reflow.
              • spleenharvester
                • Mar 2010
                • 902
                Also, is it normal for the non-shorted MOSFET to be hotter in the pair? It's the same in both cases.
                • spleenharvester
                  • Mar 2010
                  • 902
                  Ignore
                  • spleenharvester
                    • Mar 2010
                    • 902
                    Replaced PQ6 and PQ7, ACIN is now 4.2~4.7 volts. PQ7 nearly burnt my skin off when touched - should I replace it again?
                    PQ24 and PQ26 also heat up.
                    There's now a stable 3.1v near the BIOS chip (as opposed to 0.45 before), though. That irritating 0.8~1.1v oscillation is still there.
                    • whaldsz
                      • Apr 2013
                      • 395
                      • Philippines
                      What's the resistance of B+ to ground?
                      • spleenharvester
                        • Mar 2010
                        • 902
                        Seems to be infinity. There is a brief flicker on the DMM display when changing to 200ohm or to 200kohm settings but nothing reliable.
                        Also, PQ26 changed, no change whatsoever. I think this low ACIN is key though, what could be dragging it down from 19v to 4~5v?
                        Only thing I can think of doing is replacing PQ7 again, the AO4407 that practically burns your skin off when touching it.
                        • whaldsz
                          • Apr 2013
                          • 395
                          • Philippines
                          Resistance at VIN, PL3? Check PQ8, PQ9.
                          • spleenharvester
                            • Mar 2010
                            • 902
                            VIN resistance to ground appears to be about 56kohm.
                            PL3 resistance to ground appears to be infinity, with only very brief displays on the DMM when changing settings.
                            Resistance across PL3 is 1.2ohm.
                            PQ8, the diode test is working both ways? Is this normal?
                            PQ9 not present, this seems to be normal looking at images of other identical boards.
                            • whaldsz
                              • Apr 2013
                              • 395
                              • Philippines
                              PL3 is not normal. There's a short somewhere there. You got to desolder one side of PL3 and check the resistance on the pads on both side to locate where the short is coming from.
                              • whaldsz
                                • Apr 2013
                                • 395
                                • Philippines
                                Ignore my previous post. I misunderstood your message.
                                Try to test the resistance between gate to drain, gate to source of the mosfets.
                                • spleenharvester
                                  • Mar 2010
                                  • 902
                                  I think you may be onto something with PL3. I didn't notice before but it gets very hot. Should I change it?
                                  I think I measured them earlier today and they were okay, I'll check again in a sec
                                  • whaldsz
                                    • Apr 2013
                                    • 395
                                    • Philippines
                                    Not yet. Do a resistance test on all the mosfets first. There could be a short in gate-source pins. Most likely, you will have to change those mosfets including PU5.
                                    But make sure all mosfets are ok and shorts dont exist before powering the system.
                                    • spleenharvester
                                      • Mar 2010
                                      • 902
                                      Checked every FET on the board, only ones I found shorted are PQ26 (which has been replaced as it showed as shorted before) and PQ25.
                                      EDIT: Also, the ticking sound I mentioned earlier - it's not just coming from the above fets, it's coming from loads of different areas on the board.
                                      • whaldsz
                                        • Apr 2013
                                        • 395
                                        • Philippines
                                        PQ8, gate-source and gate-drain resistance?
                                          09-06-2024, 05:27 AM
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                          09-06-2024, 05:59 AM
