Toshiba c855 - Hannstar E89382
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Toshiba c855 - Hannstar E89382
    I have a the same laptop here but my problem seems a little different, when i plug in the adapter the kbc chip starts to heat up and laptop wont power on but the AC led i will be on, i was thinking it is the nouvoton chip.
    • botero
      • Nov 2010
      • 23
      • Italy
      I'm searching IRF8707 but i didn't found it in my zone. Someone could you suggest me some "common" equivalent? I attach the datasheet.
      • panikos38
        • May 2009
        • 4
        hi for all.
        i try to repair toshiba c855-10j.
        the laptop not turn on,only white led its flashing,on the motherboard mosfet F8707 its very very hot this fet is near GPU i mesure out of the bord and its ok.
        do you belive my gpu is off?
        if this mosfet is controll power gpu ?
        thanks
        • atsio
          • Oct 2013
          • 819
          • Greece
          It is near the coils of CPU VCORE POWER (probably you have a short on VCORE POWER rail). You need the boardview to find out, because without numbering printed on the board is just guesswork.
          You can check for short (impendance) on pads 1,2,3 relative to ground.
          • panikos38
            • May 2009
            • 4
            thanks for your replay,,,,,i need the schema maybe some know where i find.
            my laptop is TOSHIBA satellite C855-10j part no PSKCCE-004005GE
            and the motherbord on the sticker say H000050770.
            if you know where i find schema or service manual pls tell me.
            thanks...
            • atsio
              • Oct 2013
              • 819
              • Greece
              #26
              From pictures of the motherboard I can see that my assumption was wrong and the fet has to do probably with PCH power. For schematic and boardview have a look at https://www.badcaps.net/forum/showthread.php?t=33101 to see if it is for your board.
              • panikos38
                • May 2009
                • 4
                #27
                atsio thanks,,,,this schema its not same to my bord,,thanks again.
                patrida se efxaristo .
                • wifi
                  • Feb 2013
                  • 6
                  • Czech Republic
                  #28
                  Hi, I have a Toshiba notebook model PSKCCE-011002CZ (Toshiba Satellite C855-148), the fault is: notebook goes on, the fan spins, the hard disk is not rotating and there is no image on the screen. He could anyone help? Motheboard H000050770. Excuse my English.
                  • panikos38
                    • May 2009
                    • 4
                    #29
                    atsio hello.
                    this fet is power to gpu chipset, i take out pch chip (SLJ8E) and now the power is ok.
                    the mb have ac power led on have chg led on if i conect the battery.
                    do you belive if i replace this chip the motherbord work again?
                    thenks
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      #30
                      Originally posted by panikos38
                      atsio hello.
                      thenks
                      If the short is gone probably the problem was with PCH.
                      • peppeinutile
                        • Sep 2014
                        • 7
                        • Italia
                        #31
                        Hey OP, i've the same exact problem.
                        Did you solve or you changed the motherboard?
                        This is my https://www.badcaps.net/forum/showthread.php?t=43719
                        Thanks!
                        • vedoza
                          • May 2015
                          • 37
                          • newyork
                          #32
                          help satellite c855 power on not working with display help please
                          • hh56
                            • Aug 2015
                            • tunisia
                            #33
                            I've a Toshiba c855 with Hannstar E89382 J MV-4 94-0,I've searched the ISL6237,UP6111A,TPS51116 but i haven't found theme
                            • kadi144
                              • Aug 2015
                              • 690
                              • algerie
                              #34
                              Thank you
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3628
                                • slovakia
                                #35
                                if u havent found u must have other vendors ic
                                look on mark and search for their datasheet
                                • hh56
                                  • Aug 2015
                                  • tunisia
                                  #36
                                  Thank you ktmmotocross, i mean that i can't locate their in laptop motherboard.
                                  • dommu
                                    • Nov 2016
                                    • 3
                                    • italy
                                    #37
                                    hi. i have a motherboard plf/plr/csf/csr dsc. My problem is that pc look dead . no led blinking, even if the battery plugged is charged by another identical laptop. Gate and source of FDMC 8884 are shorted. can is it the cause? Thanks in advance
                                    • shaykthdey
                                      • Feb 2018
                                      • Bangladesh
                                      #38
                                      charger power and chargering but battery no power pls help
                                      • Main2
                                        • Feb 2018
                                        • 5
                                        • morocco
                                        #39
                                        thank you so much
                                        • neurevt
                                          Need BIOS for Toshiba L775-13K (PSK3WE) Hannstar J MV-4 94v-0 e89382
                                          by neurevt
                                          Hi everyone! I need BIOS for Toshiba L775-13K (PSK3WE) Hannstar J MV-4 94v-0 e89382 (4MB BIOS) with nvidia gpu. I searched the forum a lot but couldn't find it.
                                          BIOS i backed up from motherboard with ch341a.
                                          Many thanks to all who will help!...
                                          12-21-2022, 03:34 AM
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
