[Acer 6930G] Lower +5V problem.
Re: [Acer 6930G] Lower +5V problem.
No, no i guess you misunderstand, i talk about PQ16 because, this FET like PQ14. Both gates connected same 15V. But, PQ16's all voltages are ok but PQ14's not. So i meant if the problem is 15V which is you thiking about 15V cold be a problem as a 13.5V. So i just wondering if the 15V is the problem, so should both of get some voltage decraasing on them. But only PQ14 has problem...Comment
I checked 3 of them, all working fine. :\
P.S: Maybe you want to know, i replaced PQ19 too . And i checked now all MAINON_ON_G line resistors, PR94, 95, 100 , 92, 96 , 98 etc.. all working fine. PQ19 working fine.Last edited by nomorebeer; 05-22-2013, 07:21 PM.Comment
Yes MAINON is OK on stand by mode, 6V. When i run the computer, voltage goes 0V.Comment
Thank you so much your suggestion but, is those 2 Fets for 5VPCU side right? I mean 5VPCU is always FINE. 5.07. do you thinking still those ones could be a problem?Comment
The way i see it, this has got nothing to do with the switching transistors. It shouldn't, either - a transistor only runs in 2 states in a switching power supply: fully ON (low resistance) or fully OFF (open). So if the transistors have gone bad, it won't work at all. Besides, the power supply has feedback, which should prevent this kind of thing from happening.
You should trace the affected 5v rail down to the feedback pin of the controller. Then solder a little wire wherever you have a pad available on that trace (as the controller will be QFN and impossible to probe), and probe there. If the feedback voltage also drops, and the controller does not take action (which it seems it does not), replace the controller chip.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
First, ISL6237'S out pin, pin10(OUT1) always stable 5.07V.
when the cpu fan is running: Pin16 is like running between 1.50V - 3.2V. Changing very fast, not stable.
when the cpu fan is stopped: Pin16 running between 0V. - 1V. Not stable, changing fast.
additional information, there is PC45 connected Pin16 to Pin17(BST1);
when the cpu fan is running: PC45's other leg is like running between 4.90V - 5.80V. Changing very fast, not stable.
when the cpu fan stopped: PC45's other leg is like running between 3.0V - 4.10V. Changing very fast, not stable.
What do you think? The problem is ISL6237's itself?Last edited by nomorebeer; 05-27-2013, 11:39 AM.Comment
If you have a stabilized 5 volts at drain terminal of PQ14, and is not stable at source terminal, probably the voltage at gate terminal also fluctuates. (could be there is some ripple)
Try to short-circuit drain and source of PQ14, to evaluate if voltage is stabilized at both terminals.
You can not check voltage at pin 16 of ISL6237, because it is the output of a PWM circuit, so there is a square wave that should be checked with an oscilloscope.Last edited by Francisco.s; 05-28-2013, 03:18 AM.Comment
Actually, i tried to check pin25 too, ( its other phase for 3.3V i guess. i check ISL's datasheet and mainboard's datasheet it's looks like that.) So, pin25 is PHASE2(LX2) is always stable , 11v. But phase1 (pin16) is not stable. Any idea?Last edited by nomorebeer; 05-28-2013, 10:56 AM.Comment
Short-circued voltage is 5.07V.
But phase1 (pin16) is not stableComment
Short-circued voltage is 5.07V.Comment
Thank you for your answer but, Laptop is working properly before starting voltage drops. So, when shotcuited, voltage will never drop so should work always i guess.Comment
Edit: You say the computer resets when trying to check MAIND. That indicates a problem there, it means that whatever is driving the MAIND signal has a very high output impedance... To drive the gate of a FET you would need a relatively low impedance source. Instead of shorting the FET you could do a more elegant solution: Pull the gate up via a 1k resistor to 5V_ALW. That should do the trick, and also have the circuit that's controlling MAIND work properly. There's a good chance that it's still able to drive the signal LOW when the computer is turned off.Last edited by Th3_uN1Qu3; 06-06-2013, 05:09 AM.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
This specification for the Acer Aspire Aspire 9920 G-933G64HN can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire 9920 G-933G64HN boardview and Aspire 9920 G-933G64HN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:00 AM
This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:00 AM
This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:10 AM
This specification for the Acer Swift SF314-511-79X5 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-79X5 + Pack Gold Acer 14'' boardview and SF314-511-79X5 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 03:10 AM
- Loading...
